STD Tuning Engine should i use a OM 603 or a 606
pako
02-17-2011, 08:27 AM #1
Hi,
everyone i would like to ask you all. Your opinion regarding,
which engine i should use. for a G-wagon Project.
I want to modify the IP too a 7mm element, better Turbo( which
turbo should i use. I want to gain between 300 to 400 HP.
I've been reading on the forum, is really help full. but now i need a
opinion if i should use a om603 or a om606 with mechanical pump with bolt engines having a bigger element in IP.
WHICH ONE SHOULD I USE:p:p:p?????
thanks for reading.
Ali
pako
Hi,
thanks for reading.
Ali
02-17-2011, 09:25 AM #2
606 turbo ftw!
http://www.peachparts.com/shopforum/show...p?t=257481
606 turbo ftw!
