STD Tuning Engine 1999 W210 HX-35 performance
gen3performance
I like the smell of No. 2......
89
02-19-2011, 06:16 PM #1
So I just completed installing a HX-35 on my 1999 E300TD. Lemme just say it acts completely different now! It is a bit more laggy at low RPM, but when this thing spools up it comes on like a freight train!
From the feel of the car, it definetely feels faster overall, however I would like to get rid of some of the lag down low tho...I'm thinking of trying out a HE341 or something different on this thing...any thoughts on this?
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
02-19-2011, 06:38 PM #2
Its $500 but...
[Image: supra_2147_28572646.jpg]
Its $500 but...
gen3performance
89
02-19-2011, 07:39 PM #3
I've seen those! Do they work well? Or are they all talk?
gen3performance
yankneck696
395
02-19-2011, 08:41 PM #4
That's real nice. Do you put the valve on the inner or outer scroll? I bet somebody could make them cheaper.... (hint hint)
Ed
yankneck696
Ed
gen3performance
89
02-19-2011, 09:36 PM #5
Somebody like this guy! I have an entire machine shop at my disposal!
gen3performance
dieselboy
Rotatin 5500 times a minute
680
02-20-2011, 02:56 AM #6
Did you change your fueling at all? When/if you increase your fueling you will loose some of the lag.
You know some people say that 20psi from a small turbo is the same as 20psi from a larger turbo. Im not one of them.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-20-2011, 07:52 AM #7
(02-19-2011, 07:39 PM)gen3performance I've seen those! Do they work well? Or are they all talk?
Yes they work. Its the same concept as a VNT turbo but less direct. You're basically cutting the turbine housing A/R in half. So with the 12cm housing you'll effectively have 6cm with the valve closed (which is what the "quick-spool" HY30w uses).
(02-19-2011, 09:36 PM)gen3performance Somebody like this guy! I have an entire machine shop at my disposal!
Get at it! If you could cut $300 off their asking price you could have a real market. The big limitation to selling them would be if they have any patents on the concept.
(02-20-2011, 02:56 AM)dieselboy some people know that 20psi from a small turbo is the same as 20psi from a larger turbo. Im not one of them.
Thats right. Airflow isn't altered one bit by the size of the turbo, its limited by the VE of the engine.
gen3performance
89
02-20-2011, 03:55 PM #8
I have changed the fueling on the car. I had the ecu flashed to 215hp by USA speedtuning. In addition to this I made a small box with a toggle switch, resistors, and a potentiometer that allows me to max out the rack on the electronic IP...here is the link
http://www.superturbodiesel.com/std/full...t-731.html
I dont know what the original wastegate was set at on the car, but this HX-35 is set somewhere around 15-18psi. If the stock turbo was in the same ballpark as 15psi(guessing), then the HX-35 pulls WAAAY harder at 15psi than the stock turbo!
I am going to make one of those plates this week...I already have it drawn on Solidworks and the tool paths programmed.
gen3performance
02-20-2011, 05:27 PM #9
(02-20-2011, 03:55 PM)gen3performance If the stock turbo was in the same ballpark as 15psi(guessing)
The stock turbo peaks at 12psi and is reduced by the ECM as RPM rises to 6psi. That tiny turbo would explode if it were to be pushed to 15psi!
Quote:How are you revving 5500?
He isn't.
This post was last modified: 02-20-2011, 05:28 PM by ForcedInduction.
He isn't.
mantahead
02-20-2011, 07:11 PM #10
hi,
I have hx35 mounted on my 1998 w210 c250 with 20mm spacer between turbo and manifold to allow for quick spool valve. I will dyno the car with both scrolls open, then i will fit my other spacer which has one scroll blocked off. I will dyno car with each spacer and see the difference. There is videos on youtube of a supra which spools 1000rpm earlier with valve. If your going to make a valve like me you can use engine valve guides for the bushes for the butterfly shaft as they will take the heat and won't seize if enough clearance is left. Remember not to let the butterfly open to quickly or you will get a short delay in boost.
I was wondering if i used electronic pump with 7.5mm elements and your resistor set up, would this increase my rpms? Do these resistors increase rpm?
wayne
(02-20-2011, 03:55 PM)gen3performance I have changed the fueling on the car. I had the ecu flashed to 215hp by USA speedtuning. In addition to this I made a small box with a toggle switch, resistors, and a potentiometer that allows me to max out the rack on the electronic IP...here is the link
mantahead
hi,
wayne
gen3performance
89
02-20-2011, 08:09 PM #11
I'm not getting any more RPM out of the engine, it still seems to govern out around 5000 RPM. It just seems to increase fuel up to that point.
The car has been late to shift on a few occasions and the car has not over revved. It just holds around 5000 RPM until the transmission catches up.
I wonder if fooling with the tachometer signal would allow for more RPM?
gen3performance
gen3performance
89
02-21-2011, 01:07 AM #12
Oh! Mechanical pump! I was thinking you had an OM606 with electronic pump.
Is that a stock 617 pump with governor spring mods or will the stock pump go that high? Or is it even a stock pump for that matter?
Just noticed your sig...are you running an auto? Does it still pull at those revs?
This post was last modified: 02-21-2011, 01:10 AM by gen3performance.
gen3performance
mantahead
02-21-2011, 02:13 PM #13
(02-20-2011, 08:09 PM)gen3performance I'm not getting any more RPM out of the engine, it still seems to govern out around 5000 RPM. It just seems to increase fuel up to that point.
hi,
that might work, if the ecu see's less rpm it might rev higher. More resistors needed. lol
Is there no one out there running a big element electronic pump at high rpms on om605/6 ???
wayne
mantahead
hi,
wayne
gen3performance
89
02-21-2011, 02:16 PM #14
I'm not sure off hand, but if there is someone doing it I would also like to know!
gen3performance
mantahead
02-21-2011, 02:36 PM #15
(02-21-2011, 02:16 PM)gen3performance I'm not sure off hand, but if there is someone doing it I would also like to know!
hi,
i have 2 electronic pumps and 1 old cable pump with no alda. I dont know which pump to fit elements to. I am trying to find out of a remapping guy if the tables can be adjusted to run more rpm.
wayne
mantahead
hi,
wayne
muuris
OM605
318
02-21-2011, 02:42 PM #16
Just looking at boost gauge won't tell boost/backpressure ratio, which is a much better meter of airflow.
It won't increase fueling as it isn't a gasser engine. Your increase in performance is due to better breathing. Original turbo was chosen to be responsive, the sacrifice in top end performance was meaningless.
Why try to fool ECU's rpm sensor, why not just remap it? Don't see the point of changing turbo and not doing it, as a clear performance increase is just few hundred bucks away..
muuris
mantahead
02-21-2011, 03:08 PM #17
(02-21-2011, 02:42 PM)muuris Just looking at boost gauge won't tell boost/backpressure ratio, which is a much better meter of airflow.
hi,
do you know anyone has done this successfully and can run high rpm with remap on om605/6?? Do the tables in the map allow for that much rpm? If i knew someone could do this i would go for it.
wayne
mantahead
hi,
wayne
tuikku
02-21-2011, 04:03 PM #18
Muuris is right, this is pressure-controlled engine.
In orig program fuelling rate is 0mm^3 -> 5400rpm.
But, the program is only software, nothing denies to change it how ewer needed.
The program is not the problem, iron is, always.
If I understand right, the first tuning was made to standart engine.
Because of very small original turbo, you cannot rise the pulling revs over 5000rpm.
As I looked very quickly the program, it seems, that 75mm^3 is possible, and that gives +300hp/5500rpm.
tuikku
jonbobshinigin
02-21-2011, 04:31 PM #19
Gen3, I will buy one of those quick spools if you make a batch!
1987 300TDT - 260,000 Miles
jonbobshinigin
gen3performance
89
02-22-2011, 02:04 AM #20
Let me just clarify what I have done to my car so far.
I first installed a 3 inch diameter exhaust system.
Next, I had the ecu remapped from the stock 177hp/330nm to 218hp/412nm. I did not max out the fueling with the remap because I wanted to stay in what was considered a 'safe' zone of egt's, egp's, etc. The car barely, barely smoked at WOT after the remap.
I then made and installed a variable resistor box that will 'fool' the rack travel on the electronic IP. This box allows me to go to what I assume is maximum fuel output with the pump. I do not go WOT for more than a few seconds with it on. Also, the car would smoke quite heavily at WOT with the box turned up.
Lastly, my most recent upgrade was installing an HX-35 turbo. The mid to redline pull of the car has been greatly improved with this turbo, but the low rpm performance has suffered as well. I do understand that the turbo change has not increased the fueling quantity and the increase in performance is most likely from more of the fuel being burnt. The best indication I have seen to confirm this is that the amount of smoke coming from the tailpipe at WOT+resistor box on is significantly less than it was with the stock turbo.
I hope this gives a better understanding of the cars manners since the turbo swap.
And I also agree...a remap would be the better option to adjust the rpm of the engine compared to fooling the ecu.
The best option would probably be a full remap on a dyno
This post was last modified: 02-22-2011, 02:12 AM by gen3performance.
gen3performance
E300TSC
Turbo-Supercharged
321
02-22-2011, 05:26 AM #21
Sounds like a good set of mods! Nice job.
E300TSC
gen3performance
89
02-22-2011, 11:41 AM #22
Thank you E300TSC. I must say your list of mods is also very impressive!
gen3performance
muuris
OM605
318
02-23-2011, 03:27 PM #23
gen3performance, seems I missed your earlier post the last time. Your turbo change makes sense, good thing you're not killing the engine with stock turbo.
tuikku, you should know stock 6mm elements aren't good for 300hp. The best result I know is about 260hp.
muuris
tuikku
02-23-2011, 05:18 PM #24
(02-23-2011, 03:27 PM)muuris gen3performance, seems I missed your earlier post the last time. Your turbo change makes sense, good thing you're not killing the engine with stock turbo.
In orig pump voltage map, the largest fueling rate is 65mm^3.
But there is still also room to increase voltage ~20% without limp-mode, that means still under 5V voltage.
75mm^3/5500rpm means ~300hp, calculate it.
65mm^3/5500rpm is ~260hp..........Angel
So, if you are able to get the full 65mm^3 out from program, you are also able to get more.
If not, you must cheat the program even to get to 65mm^3 level...
There are plenty of limiters.
tuikku
02-23-2011, 05:30 PM #25
This thread is worthless with out: pics, videos and dyno charts!!!!!!!
muuris
OM605
318
02-25-2011, 05:06 PM #26
(02-23-2011, 05:18 PM)tuikku In orig pump voltage map, the largest fueling rate is 65mm^3.
Calculations and real life have a difference Wink A couple of mech pumps have been made by Mynä with 6mm (OM606 stock) elements and they won't give 300hp. Even if you can get enough fuel to theoretically produce 300hp, it won't be injected quick enough to be burnt well. The last mm^3s are just heat and smoke.
This post was last modified: 02-25-2011, 05:08 PM by muuris.
muuris
tuikku
02-26-2011, 05:28 AM #27
(02-25-2011, 05:06 PM)muuris
Tuostapa
... Winter was cold, but car is good...
tuikku
Tuostapa
muuris
OM605
318
02-27-2011, 10:31 AM #28
(02-26-2011, 05:28 AM)tuikku Tuostapa
Starting to get off topic, but I don't see your point. That would be 280hp on 6-cyl and I commented earlier that best I know is 260hp. Both are under 300.
muuris
gen3performance
89
02-27-2011, 02:20 PM #29
Here's some pics of the install.
http://s776.photobucket.com/albums/yy42/...35%20Swap/
gen3performance
gen3performance
89
02-27-2011, 03:38 PM #30
Also the car has a check engine light on now. I believe the light is MAF related due to the symptoms. The car will lose power at around 4000RPM on a WOT pull. Moreover, the car is doing some weird shifting at times. I dont have a connector for my Snap on MT2500 scanner to check the codes, but I will be getting one soon.
Is there anything I should be looking at with the turbo wastegate vaccuum accuator that could be setting off a code? All I did was block the vaccuum port on the accuator after the turbo swap.
gen3performance
E300TSC
Turbo-Supercharged
321
02-27-2011, 04:44 PM #31
I know the ECU want's to see 0 boost at level cruise. When you enter a highway, accelerate to speed then hold a fairly constant speed for a little while, the wastegate opens. As long as the throttle position is varying, it won't go into this "cruise" mode.
E300TSC
tuikku
02-27-2011, 05:11 PM #32
There is simply too large difference to actual, and specific boost pressure.
You have there tuned program, where boost pressure ask is rised.
With a lot of bigger turbo, actual pressure rising don´t reach program ask enough quicly.
Restart repairs the situation.
Happens also with vnt-chargers, easy to repair.
Nothing to do with MAF.
This post was last modified: 02-27-2011, 05:11 PM by tuikku.
tuikku
gen3performance
89
02-27-2011, 05:13 PM #33
Can you elaborate on this a little? So I should constantly be varying the pedal at cruise speed to prevent the computer from seeing boost?
gen3performance
tuikku
02-27-2011, 05:35 PM #34
MB is boost controlled.
All the time, when you press the pedal to ask power, or you just drive, you also ask boost pressure.
Program (orig) asks pressure all the time.
If the difference between the realised pressure and the one, program "wants" comes too large -> limp mode.
Big turbo -> slow boost rise, too slow -> too big difference -> limp mode.
Here you have the orig. map, where you can see, what the programs demand is.
Axels are fuelling rate, mm^3 and rpm.
In map there is specific boost pressure, that program wants.
It is ery easy to change anything that need.
[Image: 1tszdv.jpg]
tuikku
[Image: 1tszdv.jpg]
mantahead
02-27-2011, 05:38 PM #35
(02-27-2011, 03:38 PM)gen3performance Also the car has a check engine light on now. I believe the light is MAF related due to the symptoms. The car will lose power at around 4000RPM on a WOT pull. Moreover, the car is doing some weird shifting at times. I dont have a connector for my Snap on MT2500 scanner to check the codes, but I will be getting one soon.
hi,
have these problems started from you fitted bigger turbo? If so, i had problems with a MAF on a petrol SR20 nissan engine fitted to my opel manta. The problem was caused by air turbulence through the MAF as it was to close to the turbo and because i had increased the pipe size feeding the turbo. It would stop fueling at 4000rpm and wouldn't idle when warm. I know it is petrol but MAF's all work similar.
wayne
mantahead
hi,
wayne
gen3performance
89
02-27-2011, 05:56 PM #36
I never had the engine light come on until after the turbo swap
What would I need for hardware and software to program the ecu on my own?
This post was last modified: 02-27-2011, 06:13 PM by gen3performance.
gen3performance
300D50
Graphite Moderator, ala RBMK
02-27-2011, 06:40 PM #37
Good luck... it's all secret black-ops to program them...
300D50
mantahead
02-27-2011, 06:58 PM #38
(02-27-2011, 05:56 PM)gen3performance I never had the engine light come on until after the turbo swap
hi,
if this is the same as my 98 c250 turbo diesel the chips have to be removed from the ecu and 'read' and new chips 'burnt' with modified file and refitted. New chips are very cheap but i would have to buy files from remap guy. Although my car does not use a MAF it uses map sensor.
The other problem i had with the sr20 was 'boost cut'. The MAF was seeing to much airflow being pulled through and would cut engine off as i was running over factory boost limit. It was seeing this through the MAF and not a boost sensor. I got around this by using a fuel cut defender which clamps the voltage from the MAF to ecu.
wayne
mantahead
hi,
wayne
E300TSC
Turbo-Supercharged
321
02-27-2011, 08:07 PM #39
(02-27-2011, 06:40 PM)300D50 Good luck... it's all secret black-ops to program them...
Yeah, I sure as hell would love to get hold of the mapping software and a PROM queen or some such device... Dodgy
E300TSC
300D50
02-27-2011, 08:39 PM #40
I can burn prom's all day long, the map software is what you become a eunich for...
300D50
dust
03-01-2011, 09:26 AM #41
How difficult was the swap?
dust
gen3performance
89
03-01-2011, 11:24 AM #42
It wasn't too terrible. It took me about a week to do working on it a few hours a day. Its just time consuming making everything line up and fit.
gen3performance
