STD Tuning Drivetrain modified om606 what to do about the transmission
johan84
03-16-2011, 04:01 PM #1
hello
when you have modified the engine om606 12v or 24v
original is a 722.6 i found and it can hold up to 578 ft lbs
when you have around 400hp to 450hp can the transmission easy
hold the power
and the 750nm torque and what about the torque converter
do you need another one
and shifting moments can the transmission keep up with the acceleration
speed
are there also manual's that are a option to use
johan84
hello
hold the power
speed
