STD Tuning Drivetrain W124 OM606, manual setup
Pages (2): 1 2 Next
Diesel-Frank
03-16-2011, 07:58 PM #1
hi, i have a W124 with the om606 engine, what parts can i use to a 400+hp engine??
planning to buy a getrag 717 450 from a CE 300-24, and i have a flywheel from a OM603 engine.
sprinter clutch??
is there machinework to get the getrag, om603 flywheel, and sprinter-clutch to fit in my car??
Diesel-Frank
sprinter clutch??
03-17-2011, 11:24 AM #2
The sprinter clutch disc is one solution. They are harder to source over here. You might want to ask around in the W201 forums about how strong the trans are. You will need a solution for the driveshaft I think unless the one from the CE is the proper fit on the front half. Also be aware that the w124s had 2 different types of DS, one larger than the other with larger flexdisks etc.
Diesel-Frank
03-17-2011, 06:39 PM #3
(03-17-2011, 11:24 AM)winmutt The sprinter clutch disc is one solution. They are harder to source over here. You might want to ask around in the W201 forums about how strong the trans are. You will need a solution for the driveshaft I think unless the one from the CE is the proper fit on the front half. Also be aware that the w124s had 2 different types of DS, one larger than the other with larger flexdisks etc.
the only thing i need to know is, how to get this parts together? how much machinework, or is it "bolt-on"?
Diesel-Frank
03-17-2011, 06:53 PM #4
Other than the driveshaft it is all bolt on in my experience and a few others. We dont have many manual 300CE-24s here so I cant really comment on that.
This post was last modified: 03-17-2011, 06:53 PM by winmutt.
muuris
OM605
318
03-18-2011, 02:40 PM #5
You need to change engine internals so it is equivalent to original turbo OM606.
muuris
jeemu
457
03-18-2011, 02:44 PM #6
(03-18-2011, 02:40 PM)muuris You need to change engine internals so it is equivalent to original turbo OM606.
And when that is done. Sprinter cluch cant handle that power wery long.
jeemu
Diesel-Frank
03-18-2011, 03:09 PM #7
hmm.. ok
i have ordered the transmission today, the next i need is the clutch.
i have a flywheel from om603, is this ok, or do i need another part??
give me some good input!Smile
what engine internals?? and why??
my 606 engine is a original turbo engine.
thanks for all help! fantastic forum!Smile
This post was last modified: 03-18-2011, 03:20 PM by Diesel-Frank.
Diesel-Frank
hmm.. ok
jeemu
457
03-18-2011, 03:27 PM #8
(03-18-2011, 03:09 PM)Diesel-Frank what engine internals?? and why??
In first post you say at your engine is from w124.
w124 newer got turbo OM606
jeemu
03-18-2011, 03:35 PM #9
(03-18-2011, 03:27 PM)jeemu w124 newer got turbo OM606
That did not translate properly? I think you meant to say that only models newer than w124 got turbo 606.
Frank, what year is yours?
This post was last modified: 03-18-2011, 03:36 PM by winmutt.
jeemu
457
03-18-2011, 04:26 PM #10
(03-18-2011, 03:35 PM)winmutt
Newer is ever
jeemu
Newer is ever
Diesel-Frank
03-18-2011, 04:33 PM #11
ohh, sorry, i wrote it wrong..
the engine is from a 98 w210.
tha car is a 86 300d OM603 non-turbo.
to the 606 turbo engine i have a myna pump with ALDA and a new cam, KKD header with external wastegate, and å holset HX40.
This post was last modified: 03-18-2011, 04:50 PM by Diesel-Frank.
Diesel-Frank
muuris
OM605
318
03-20-2011, 02:08 AM #12
Good thing it's a turbo-engine. But the Sprinter clutch will slip.
I have Sachs ..765 pressure plate on a custom flywheel. It's 240mm and reasonable price.
muuris
Diesel-Frank
03-20-2011, 04:58 AM #13
(03-20-2011, 02:08 AM)muuris Good thing it's a turbo-engine. But the Sprinter clutch will slip.
ok, i have not ordered the sprinter clutch yet.
can you help me with the flywheel and clutch?? what is the price on this parts??
the 717.450 transmission is on it`s way to me now. it`s from a 300CE-24
Diesel-Frank
aaa
03-20-2011, 05:49 AM #14
The om603 flywheel should already be 240mm.
aaa
muuris
OM605
318
03-20-2011, 01:09 PM #15
(03-20-2011, 05:49 AM)aaa The om603 flywheel should already be 240mm.
Yes, but 765 pressure plate is for BMW M5 (E34) and won't bolt on to Merc flywheel without modifications.
765 cost around 300 euros here. I use normal clutch disc from C250 turbodiesel.
muuris
Diesel-Frank
03-22-2011, 04:34 AM #16
(03-20-2011, 01:09 PM)muuris
what is the difference between the stock 603 flywheel and a dual mass flywheel??
can i use my 603 flywheel for my getrag 717.450??
do you have a link to a shop that have this sachs 765 pressure plate??
This post was last modified: 03-22-2011, 04:35 AM by Diesel-Frank.
Diesel-Frank
jeemu
457
03-22-2011, 12:13 PM #17
(03-22-2011, 04:34 AM)Diesel-Frank
Better to do on 200d FW. Is there any performance parts sale company?
That pressure plate number is 883082 999765 and made by Sachs.
Disk can use MB c250dt. Luk, Sachs etc.
jeemu
erling66
SuperDieselVan
294
03-25-2011, 10:03 AM #18
Hi Diesel Frank
The 60x single mass FW are very different from a dual mass FW. A google search will give you the info you need, and you will quickly find out why you can forget about the dual mass FW for your project.
Where in Norway are you located? I am in Skien
Jeemu; why do you like the 200D(601?) FW? less weight?
HuhCoolTongue
erling66
Hi Diesel Frank
HuhCoolTongue
jeemu
457
03-31-2011, 02:45 PM #19
(03-25-2011, 10:03 AM)erling66 Jeemu; why do you like the 200D(601?) FW? less weight?
It s easy and cheap to get. That can machined better cluch.
Still best way is to machine total new FW CrMo like i have.
jeemu
offroadbakos
04-02-2011, 12:37 PM #20
(03-31-2011, 02:45 PM)jeemu
and how much would a new CrMo macined FW like the one you have cost??
offroadbakos
muuris
OM605
318
04-04-2011, 01:39 PM #21
(04-02-2011, 12:37 PM)offroadbakos and how much would a new CrMo macined FW like the one you have cost??
It costs upwards from 300-350 euros in Finland, but if I were you, I'd ask the local machine shop..
muuris
jeemu
457
04-04-2011, 02:57 PM #22
There is ready model to om6xx and long clutch axle combo CrMo wheel and it cost 250eur asked today. There fit that -765 pressureplate
jeemu
04-06-2011, 09:19 AM #23
(03-20-2011, 01:09 PM)muuris I use normal clutch disc from C250 turbodiesel.
On which flywheel? m103?
muuris
OM605
318
04-06-2011, 02:26 PM #24
(04-06-2011, 09:19 AM)winmutt On which flywheel? m103?
(03-20-2011, 02:08 AM)muuris I have Sachs ..765 pressure plate on a custom flywheel.
Pic.
This post was last modified: 04-06-2011, 02:30 PM by muuris.
muuris
Pic.
300D50
Graphite Moderator, ala RBMK
04-06-2011, 02:35 PM #25
NICE! Do I see a step to increase clamping force, or are my eyes deceiving me?
300D50
Diesel-Frank
04-06-2011, 04:52 PM #26
(04-04-2011, 02:57 PM)jeemu There is ready model to om6xx and long clutch axle combo CrMo wheel and it cost 250eur asked today. There fit that -765 pressureplate
do i have long or short clutch axle on my 717.450 getrag??
I`m interested in this custom FW!
(04-06-2011, 02:26 PM)muuris
Pic.
nice!.)
This post was last modified: 04-06-2011, 04:53 PM by Diesel-Frank.
Diesel-Frank
Pic.
nice!.)
muuris
OM605
318
04-07-2011, 12:42 PM #27
(04-06-2011, 02:35 PM)300D50 NICE! Do I see a step to increase clamping force, or are my eyes deceiving me?
Pressure plate is for a BMW, which has 10mm disc. The Merc disc I use is thinner, so the step is needed in order to achieve the specified clamping force.
muuris
300D50
04-07-2011, 01:00 PM #28
Makes sense, a lot of people don't take that into account when doing a clutch swap-out.
300D50
Diesel-Frank
05-05-2011, 11:14 AM #29
Pic.
hi again! now i have the transmission homeSmile
is the FW on the picture to a short clutch axle??
as i can see, the FW on the picture is the one i need!
Diesel-Frank
Pic.
05-05-2011, 12:00 PM #30
On this thread you can see the solid mass fly wheel I am using on my om603 6spd project it is for a sprinter 2.2 CDI to replace the original dual mass flywheel! http://www.superturbodiesel.com/std/thre...ch-options
Notice the pilot bearing in the flywheel not the crank shaft it's for the shorter style input shaft transmissios
This post was last modified: 05-05-2011, 12:06 PM by willbhere4u.
Diesel-Frank
05-05-2011, 02:47 PM #31
(05-05-2011, 12:00 PM)willbhere4u On this thread you can see the solid mass fly wheel I am using on my om603 6spd project it is for a sprinter 2.2 CDI to replace the original dual mass flywheel! http://www.superturbodiesel.com/std/thre...ch-options
nice! where to buy?? link??
Diesel-Frank
05-05-2011, 03:05 PM #32
I got mine off of eBay as an entire kit http://cgi.ebay.com/BRAND-NEW-SOLID-FLYW...1e6258dcde
VALEO NUMBER IS 835013
I think they make the flywheel?
Diesel-Frank
05-05-2011, 04:21 PM #33
(05-05-2011, 03:05 PM)willbhere4u I got mine off of eBay as an entire kit http://cgi.ebay.com/BRAND-NEW-SOLID-FLYW...1e6258dcde
thank you! interesting!
the kit is in my "watch list"...Smile
Diesel-Frank
05-05-2011, 06:47 PM #34
I bought the same kit but with the concentric slave cylinder http://cgi.ebay.com/SOLID-FLYWHEEL-VALEO...1e5dedfa4b
It's a bit more money! But the shipping was 40 euro's less so it made up for the price a bit plus it comes with the slave cylinder witch I needed any ways
This post was last modified: 05-05-2011, 06:48 PM by willbhere4u.
Diesel-Frank
05-05-2011, 11:37 PM #35
(05-05-2011, 06:47 PM)willbhere4u I bought the same kit but with the concentric slave cylinder http://cgi.ebay.com/SOLID-FLYWHEEL-VALEO...1e5dedfa4b
what is a concentric slave sylinder??
Diesel-Frank
jeemu
457
05-06-2011, 01:30 AM #36
Any Mercedes Cluch kit not hold up there long
jeemu
Diesel-Frank
05-06-2011, 04:13 AM #37
(05-06-2011, 01:30 AM)jeemu Any Mercedes Cluch kit not hold up there long
maybe i will order this FW and modify it for the sachs 765 pressure plate.
what do you think??
Diesel-Frank
what do you think??
jeemu
457
05-06-2011, 09:22 AM #38
(05-06-2011, 04:13 AM)Diesel-Frank
what do you think??
That works. How much it will cost?
jeemu
what do you think??
05-06-2011, 10:01 AM #39
I would call and see if they can get you just the flywheel!
Diesel-Frank
05-06-2011, 01:37 PM #40
(05-06-2011, 10:01 AM)willbhere4u I would call and see if they can get you just the flywheel!
nice, thank you!Smile
Diesel-Frank
mantahead
05-06-2011, 02:29 PM #41
hi guys,
sorry to go away from om606 but what solid flywheel and clutch can i use for my om605 that has standard dual mass at the minute. The clutch is not done but is slipping at 260 hp. This will maybe give you an idea of what power standard clutches can take.
I can get uprated pressure plate made with more clamping force and paddle clutch but i am afraid of the dual mass flywheel.
wayne
mantahead
hi guys,
wayne
05-06-2011, 03:07 PM #42
(05-05-2011, 11:37 PM)Diesel-Frank what is a concentric slave sylinder??
here is pic of one
It a slave cylinder that mounts inside of the transmission. The 6spd I have uses this set up
Its a slave cylinder and through out bearing all in one. no clutch fork!
This post was last modified: 05-06-2011, 03:09 PM by willbhere4u.
here is pic of one
Diesel-Frank
05-06-2011, 03:12 PM #43
(05-06-2011, 03:07 PM)willbhere4u
here is pic of one
i don`t need it on my transmission??
Diesel-Frank
here is pic of one
05-06-2011, 03:14 PM #44
(05-06-2011, 02:29 PM)mantahead hi guys,
wayne
I think the flywheel above would still fit it built for an om611. sprinter
But I think it should bolt up to any om60x engine I'm using it for an om603 turbo
(05-05-2011, 11:37 PM)Diesel-Frank i don`t need it on my transmission??
Only if you transmission was set up for one originally. If not you don't need it
My transmission is out of an 02 C230 kompressor and that's what they came with stockCool
This post was last modified: 05-06-2011, 03:20 PM by willbhere4u.
wayne
Diesel-Frank
05-06-2011, 03:27 PM #45
(05-06-2011, 03:14 PM)willbhere4u
wayne
yes, but i thinking about the slave cylinder, should i order the kit with the "normal" slave cylinder, or the one that is inside the clutch house?
wayne
i`m not sure, but i think you can use the same parts as on the 606 engine.
(05-06-2011, 09:22 AM)jeemu
what do you think??
I`m not sure yet, i will post it here when i have the parts home,
This post was last modified: 05-06-2011, 03:32 PM by Diesel-Frank.
Diesel-Frank
wayne
wayne
what do you think??
05-06-2011, 04:01 PM #46
(05-06-2011, 03:27 PM)Diesel-Frank yes, but i thinking about the slave cylinder, should i order the kit with the "normal" slave cylinder, or the one that is inside the clutch house?
The first link I gave you is just the clutch kit with out any slave cylinder
concentric slave cylinders Will only fit it the transmission originally had one!
All of the sprinters/newer model Mercedes 2000ish? and newer use them stock
don't quote me on the year but that's what on my 02 6spdBig Grin
This post was last modified: 05-06-2011, 04:03 PM by willbhere4u.
mantahead
05-07-2011, 02:33 PM #47
hi,
removed my dual mass flywheel and on the back it has 5 raised markers for the crank sensor and 1 marker is like drilled. Is there any solid flywheel i can use and keep my sensor working?
mantahead
hi,
jeemu
457
05-08-2011, 07:15 AM #48
Hi. I ordered my friend 605 + short axle tranny special made FW
Original sensors work.
jeemu
Diesel-Frank
05-08-2011, 07:26 AM #49
(05-08-2011, 07:15 AM)jeemu Hi. I ordered my friend 605 + short axle tranny special made FW
NICE!
what prussure plate and disc is on the picture??
Diesel-Frank
NICE!
jeemu
457
05-08-2011, 04:11 PM #50
(05-08-2011, 07:26 AM)Diesel-Frank
NICE!
Hi. Sachs Race pressure plate to Bmw m3 and Mercedes 250d disk.
same pressure plate found my own car.
jeemu
NICE!
Pages (2): 1 2 Next
