STD Other FS / WTB / Buying guides FS: 5 Water injection nozzles
04-03-2011, 09:06 AM #1
For sale: Five 70cc/m nozzles with 90* angles and 1/4 push-lock hose fittings. 1/8npt threads.
That will put flow at 350cc/m, right about perfect for a 617 running stock-ish boost without an intercooler. Using -20 washer fluid will provide a ~10hp increase. They will fit the stock log manifold if installed close to the flanges on the underside, and will fit anywhere in the W115 intake's runners.
Asking $85 for the set, originally cost $120.
I am selling them to reduce the flow in my port injectors from 70cc to 50cc (420cc/m is too much with an intercooler). Unfortunately that means either reducing pump pressure (atomization quality) or buying new nozzles.
