STD Tuning Engine converting to cable from original throttle linkage system on om617
mr_manny
Diesel Offroad Club
91
04-05-2011, 10:43 AM #1
looking for input on converting my throttle linkage over to cable Smile
Have found a few examples, and was curious if anyone has done something similar...
thanks,
manny
[Image: throttleCABLE1.jpg]
[Image: throttleCABLE2.jpg]
[Image: throttleCABLE3.jpg]
[Image: throttleCABLE4.jpg]
[Image: throttleCABLE5.jpg]
mr_manny
thanks,
manny
4rnnr33
04-05-2011, 02:21 PM #2
Heres how I did mine You cant see it very good though
[Image: IMAG0092.jpg]
But I used this carb style adapter end I got from summit
[Image: throttle.jpg]
You just cut the stock ball type end off the cable slide this over and it has a set screw that locks the cable in
4rnnr33
04-05-2011, 03:40 PM #3
Yeah, I'd be interested in doing the same. That dumb throttle rod is so sloppy and cumbersome....
Walkenvol
04-06-2011, 07:32 AM #4
4rnnr33 - are you still able to manually push the stop lever toward the valve cover to stop the motor with the throttle cable connected or does the gas pedal interfere since its tied directly to the lever via the cable?
This post was last modified: 04-06-2011, 07:32 AM by Walkenvol.
Walkenvol
4rnnr33
04-06-2011, 02:24 PM #5
(04-06-2011, 07:32 AM)Walkenvol 4rnnr33 - are you still able to manually push the stop lever toward the valve cover to stop the motor with the throttle cable connected or does the gas pedal interfere since its tied directly to the lever via the cable?
Yep still can
4rnnr33
Yep still can
mr_manny
Diesel Offroad Club
91
04-06-2011, 07:38 PM #6
a few more Smile
[Image: DieselS-10.jpg]
[Image: P1010196.jpg]
[Image: P1010197.jpg]
[Image: c903b9d1.jpg]
[Image: linkage-03.jpg]
[Image: linkage-04.jpg]
This post was last modified: 04-10-2011, 11:37 AM by mr_manny.
mr_manny
a few more Smile
300D50
Graphite Moderator, ala RBMK
04-06-2011, 08:30 PM #7
I was going to , and likely still will, buy the OEM cable setup from a RHD 300D.
300D50
Walkenvol
04-07-2011, 07:45 AM #8
Manny - where did you find the 1st picture in post #6? Is there a build thread?
Walkenvol
mr_manny
Diesel Offroad Club
91
04-07-2011, 08:43 AM #9
(04-07-2011, 07:45 AM)Walkenvol Manny - where did you find the 1st picture in post #6? Is there a build thread?
didn't find one...
If you have specific questions, you might try contacting "Corvette74" :
http://www.dieselbombers.com/diesel-engi...nkage.html
mr_manny
didn't find one...
mr_manny
Diesel Offroad Club
91
04-09-2011, 04:57 PM #10
Picked up some linkage from the yard this morning.
this compact item comes from a volvo...has a build-in return spring:
[Image: linkage-01.jpg]
also grabbed some additional mercedes brackets and linkage which should provide some options towards my conversion:
[Image: linkage-02.jpg]
mr_manny
mr_manny
Diesel Offroad Club
91
04-16-2011, 11:15 PM #11
well, here's what I came up with:
[Image: linkage-05.jpg]
[Image: linkage-06.jpg]
I believe I used one of the brackets associated w/the cruise-control.
will be adding a stop to the skinny peddle to limit the throw...but seems to operate nicely Smile
mr_manny
04-18-2011, 03:09 PM #12
That looks real clean, I like!
