STD Other FS / WTB / Buying guides WTB OM60x compatible injection pump drive sprocket.
E300TSC
Turbo-Supercharged
321
04-09-2011, 08:49 PM #1
Looking for the drive sprocket for an OM60x. Thanks!
E300TSC
totaldisaster
lightly modded OM606
211
04-09-2011, 10:05 PM #2
got one. PM for details.
You are referring to the IP timing device / drive gear, correct?
totaldisaster
totaldisaster
211
04-10-2011, 11:43 AM #3
You can see the separation of the splined section from the geared half in the front view.
totaldisaster
E300TSC
Turbo-Supercharged
321
04-10-2011, 07:56 PM #4
Thanks! And, btw, I have the EXACT same air compressor! Big Grin
This post was last modified: 04-10-2011, 07:56 PM by E300TSC.
E300TSC
totaldisaster
211
04-10-2011, 08:44 PM #5
A pleasure , sir.
Keep us updated.
And its a very small world, isn't it? Where did you get yours / how is it holding up? All of my adjustment knobs are busted and I can't seem to dial in the switchoff valve to the right kick-on/off settings.
totaldisaster
A pleasure , sir.
Keep us updated.
E300TSC
Turbo-Supercharged
321
04-12-2011, 08:22 PM #6
I bought the compressor for $75 from a gentleman about 20 years ago. The regulator knob is missing (always has been) so I just grab the stub of a shaft and turn it with vice grips. It had also been tipped over onto it's aluminum crossover line which smashed it flat. I replaced it with a piece of copper tubing and it's been going strong ever since.
Don't forget to drain the water every so often from the valve under the tank... Smile
Mine kicks on at about 90 and off around 120. I've never fooled with the adjustments.
E300TSC
