STD Tuning Engine OM617 Oil pressure, any issues going higher than stock?
300D50
Graphite Moderator, ala RBMK
04-13-2011, 03:50 PM #1
I'm redoing the pickup on my oil pump, and have what might be a stupid question.
Stock pressure on the relief valve is 7 bar, or ~ 100PSI.
Are there any issues with raising the max, or is the max ever indeed seen by the engine?
I know for some high-output g@sser engines people shim the regulator, but not sure on these old beasts.
I'll be able to arbitrarily set any pressure I want when I remake the relief valve housing, so figured I'd ask.
300D50
04-13-2011, 04:00 PM #2
Well being as though the gauge always shows 50+lbs I have no clue.... I have always wanted to install a full sweep gauge just out of curiosity...
aaa
04-13-2011, 04:11 PM #3
For what reason?
aaa
For what reason?
yankneck696
395
04-13-2011, 04:17 PM #4
I could see blowing out seals in the turbo & other engine parts. Except for all out race engines (with the specially designed clearances) higher volume or pressure could actually rob horsepower.
Ed
yankneck696
Ed
04-13-2011, 05:00 PM #5
It wouldn't hurt the turbo seals since there is a orifice in-line already...
300D50
04-13-2011, 05:40 PM #6
It's in case I'm of when I recreate the cracking face of the relief valve in the new rear pump housing, and also for personal curiosity.
300D50
04-13-2011, 07:18 PM #7
I personally wouldn't go higher then 7 bar. Gaskets/seals, the plastic IP line and even oil pump is stressed. As long your getting at least 3 bar or 43 PSI @3000 rpm your good.
300D50
04-13-2011, 08:11 PM #8
But does the engine ever hit 7 bar in normal use?
I guess what I'm trying to get at is, would a variation of, say, 5PSI be an issue?
I'm going to do my best to recreate the relief housing dimensions to within a thousandth, but I could still be off.
I'll have to measure the travel of the piston from full-closed to the cracking surface, and run the numbers to find out how the spring rate and preload factor into it.
Oy vey, the things I get myself into!
300D50
04-13-2011, 08:31 PM #9
(04-13-2011, 08:11 PM)300D50 But does the engine ever hit 7 bar in normal use?
Yes it does. It will hit 7 bar past 3,000 rpms. I think 5psi variance is not an issue. Any more then it might.
