STD Tuning Drivetrain 300d transmission
300d transmission
300d transmission
z!!!
05-02-2011, 03:38 PM #1
Where is the number stamped I found an 85 300td in the junk yard and need to know if the trans will work?
z!!!
aaa
05-02-2011, 04:25 PM #2
Passenger side right next to where the dipstick goes into the transmission. Define "will work", with what? Probably yes if I'm guessing your car right.
aaa
z!!!
05-02-2011, 05:18 PM #3
(05-02-2011, 04:25 PM)aaa Passenger side right next to where the dipstick goes into the transmission. Define "will work", with what? Probably yes if I'm guessing your car right.
I have an 84 300D with a bad trans and found an 85 300TD with an assumed good trans
z!!!
05-02-2011, 07:01 PM #4
As long as it a turbo model I don't see any problems
85 models have a different torque converter if I'm not mistaken but it's a more desirable one any ways higher stall speed or something
05-02-2011, 10:15 PM #5
We'll find out on the stall speed here shortly!!!
05-03-2011, 08:02 AM #6
(05-02-2011, 05:18 PM)z!!!
They should swap just fine.
z!!!
05-07-2011, 02:47 AM #7
Ok so I just finnished installing the new transmission, but does anybody have any idea why it wouldn't shift correctly? In first gear if I take off normal it won't shift until I hit around 4k rpms but if I stomp down on it I will shift in to second at about a little over two? Also is shifts very rough.....
So excited to actually drive the car, I've only had this one about a week but for me to buy, find the fix, and install in one week is really an accomplishment! Normally I will buy a project like this one and it'll sit for at least 6 months before I'll even begin to tinker with it! So if anybody has any ideas on the shifting funny please let me know asap
Thanks!
z!!!
Thanks!
Biohazard
Smokin like a champ!
376
05-07-2011, 10:36 AM #8
Sounds like you need to adjust the vacuum modulator (top rear of Injection Pump), Bowden Cable (top of valve cover), and possibly the pressure modulator on the transmission (drivers side, just above the pan). I don't believe the directions are on this website, perhaps someone can link? I'm still trying to find the directions myself as I need to readjust the vacuum modulator on my car and don't remember the settings! Oh, and I'm assuming you have put in fresh fluid and filter as well?
Biohazard
05-07-2011, 10:51 AM #9
modulator instructions
http://www.peachparts.com/Wikka/Trans722VacMod
z!!!
05-09-2011, 10:20 PM #10
So I found a bunch of dry rotted vacuum hoses so I replaced those but still a bit of a rough shift, but it is a little better, I talked to the kid I bought it from and he said it always shifted rough like that so he assumed all diesels shifted that way. No wonder it jad a bad trans...... On the vacuum modulator do I just pop the little dust cap off and adjust is there? I read the other post but I don't quite understand what to do exactly...
z!!!
05-09-2011, 10:26 PM #11
are the levers in that 3/2 switch worn down?
http://dieselgiant.com/trannyleverreplace.htm
05-10-2011, 09:14 AM #12
You can just delete all the vac crap on the valve cover.
z!!!
05-10-2011, 06:31 PM #13
(05-09-2011, 10:26 PM)larsalan are the levers in that 3/2 switch worn down?
I don't have one o those, maybe that's why...
[Image: 690809d1.jpg]
(05-10-2011, 09:14 AM)winmutt You can just delete all the vac crap on the valve cover.
What do I do instead?
Some pics of the car
[Image: bfa2f1db.jpg]
[Image: 292a6193.jpg]
[Image: 45bb327d.jpg]
[Image: e264b0c2.jpg]
This post was last modified: 05-10-2011, 06:37 PM by z!!!.
z!!!
05-10-2011, 07:13 PM #14
Mine always shifted rough when I would forget to plug the vac lines back into the 3/2 switch. But I guess if you have all that sorted then there is another issue. Wink
z!!!
05-10-2011, 08:30 PM #15
(05-10-2011, 07:13 PM)larsalan Mine always shifted rough when I would forget to plug the vac lines back into the 3/2 switch. But I guess if you have all that sorted then there is another issue. Wink
I don't know that it's sorted.... Where all does that vacuum switch connect to?
z!!!
05-10-2011, 08:33 PM #16
Mine had just 2 lines coming of that 3/2 switch. One was black and one was white. I think one went to the pump/alda boost line.
Not for sure, but I'm sure somebody knows what is supposed to be done to delete them.
edit:
maybe you are just supposed to plug the lines related to the 3/2 valve?
http://peterschmidtransmission.com/vacuu...617_91.jpg
This post was last modified: 05-10-2011, 08:45 PM by larsalan.
edit:
z!!!
05-12-2011, 09:11 AM #17
Well I have plugged lines that I don't tink I need like the EGR an some other vacuum line that I found just hanging there I replaced the little vacuum check valve and everything I could think of to change out..... It still shifts really rough and late.... Does any body have any other places to check?
z!!!
05-12-2011, 09:29 AM #18
(05-07-2011, 10:36 AM)Biohazard Sounds like you need to adjust the vacuum modulator (top rear of Injection Pump), Bowden Cable (top of valve cover), and possibly the pressure modulator on the transmission (drivers side, just above the pan). I don't believe the directions are on this website, perhaps someone can link? I'm still trying to find the directions myself as I need to readjust the vacuum modulator on my car and don't remember the settings! Oh, and I'm assuming you have put in fresh fluid and filter as well?
Did you try that cable? I think more slack in the cable means firmer shifting and less slack is softer shifting.
Could be wrong. I believe they say keep it on the firm side of what you can handle.
Biohazard
376
05-12-2011, 10:48 AM #19
From the pictures, it looks like your 3/2 switch is missing from the top of your valve cover. You have the cam part, that is the black plastic piece with the ramps that your throttle rods are connected to. I removed mine from the car in the middle of some other mods/repairs and have had to do some other adjustments.
Now, there is a black plastic line from your transmission pressure modulator that connects to your vacuum modulator on the IP. That needs to stay. The other port on the vacuum modulator needs to have the vacuum-in source from the vacuum pump line. Once that is all plumbed in, you can adjust your vacuum modulator on the IP.
With the engine off, make sure the modulator rod hits the full throttle stop or really close to it (its a little pin). If it is way off, adjust it closer using the threaded part at the bottom of the throttle rod. Once that is set, you can adjust the vacuum. There may be a small white plastic dome shaped cap on the side of the vacuum modulator. It covers the adjuster nut. If there is a cap, carefully remove it. If not, then no worries. This next part is way easier with a helping hand. You also need a vacuum gauge and something to space the adjuster off 10MM from that little pin for the full throttle stop.
MAKE SURE YOU DISCONNECT THE THROTTLE LINKAGE TO THE VACUUM ADJUSTER FOR THIS NEXT STEP!!
Check your vacuum reading from the main vacuum line, where it tee's into the small line. It should be around 20ish InHg at idle. If much lower, check the line to see if it is plugged or getting clogged. Reconnect the vacuum-source line and disconnect the black plastic vacuum line that goes to the transmission and connect your vacuum gauge to its port on the vacuum modulator. With the engine running at idle, use your spacer to hold the vacuum modulator lever 10mm from full throttle. You should have 10-15 InHg on your gauge. With the vacuum modulator at the full throttle stop, you should have 0-2 InHg on your gauge. You are more concerned with the 10mm position though at this point. With the engine idling and the 10mm spacer holding the vacuum modulator lever, loosen the lock nut and adjust the inner rod. This adjustment is a pain, is somewhat easier with a 2nd person, and should not be rushed. A little bit goes a long way on adjusting the inner rod. It's also a pain to get it set correctly and not have it move all over while the engine is idling and vibrating. Once you have the 10-15 InHg set, recheck the full throttle reading. At this point, you can turn off the engine and reconnect everything. Take it for a drive and see how it feels. If it feels ok, then you are done! If not, then you can readjust the vacuum modulator or take it a step further and adjust the transmission pressure modulator. Mine was ok with just the vacuum adjustment. The Bowden cable on mine is set to have just about 2mm of slack at closed throttle.
Biohazard
z!!!
05-22-2011, 09:48 AM #20
Thanks I was able to fix it yesterday! And I fixed the a/c, but it blows the fuse after about 20 minutes so now i gotta chase down why
(05-12-2011, 10:48 AM)Biohazard From the pictures, it looks like your 3/2 switch is missing from the top of your valve cover. You have the cam part, that is the black plastic piece with the ramps that your throttle rods are connected to. I removed mine from the car in the middle of some other mods/repairs and have had to do some other adjustments.
z!!!
Biohazard
376
05-22-2011, 10:16 AM #21
Cool! Glad you got that fixed! Good luck with the AC, hope that works out too! Big Grin
Biohazard
unaleman
05-22-2011, 01:44 PM #22
Biohazard.... Thanks for how to on trans vacuum adjustment. Very Very helpful.
unaleman
Hercules
05-22-2011, 07:38 PM #23
I was paid to do these adjustments for good many years.Little bit of a short cut. Adj.vac.control valve to 9" vac,adj.trans. mod.to firm shift,adj. bowden cable 1/2 ball short at idle position.Cable adj.per mbz.May need to fudge up or down small amount on all adj.but has always been very close. Thanks Biohazard for typing all that!
Hercules
Biohazard
376
05-23-2011, 08:44 AM #24
(05-22-2011, 07:38 PM)Hercules I was paid to do these adjustments for good many years.Little bit of a short cut. Adj.vac.control valve to 9" vac,adj.trans. mod.to firm shift,adj. bowden cable 1/2 ball short at idle position.Cable adj.per mbz.May need to fudge up or down small amount on all adj.but has always been very close. Thanks Biohazard for typing all that!
Thanks for the tips! I can never remember the Bowden Cable adjustment. I'll recheck mine and adjust as needed. Pretty sure it needs re-adjustment. Smile
Edit: Yup, was way off. Adjusted it to about a half ball at idle, will report back after I get lunch.
This post was last modified: 05-23-2011, 11:16 AM by Biohazard.
Biohazard
Biohazard
376
05-24-2011, 08:55 AM #25
So I barely had any tension on the Bowden Cable. Now I'm closer to the half ball worth and it is shifting better. I think I need to pull a little bit more tension though. Thanks again for the tip!
Biohazard
