STD Tuning Engine I think I cooked my turbo.
05-24-2011, 12:49 PM #1
Parked it over the weekend. Monday morning no power lots of black smoke. I havent pulled the intake yet but.... last weekend I installed a MBC and kept turning it up until the overboost kicked in. Well the overoost never kicked in, probably because I also backed out the alda at the same time. It was whistling but I assumed it was an air leak somewhere. not the singing of the journals burning up.
Anyone know if the engine would still run if the turbo seized? Could it just be rotating slowly enough to not provide boost?
I have been looking for a turbo but now... well its more imperative.
This post was last modified: 05-24-2011, 12:51 PM by winmutt.
tomnik
05-24-2011, 01:20 PM #2
(05-24-2011, 12:49 PM)winmutt Anyone know if the engine would still run if the turbo seized? Could it just be rotating slowly enough to not provide boost?
yes it will run but the exhaust side blocks the exhaust (high EGT, no power, smoke).
Tom
tomnik
Tom
05-24-2011, 03:28 PM #3
I have that really nice powder coated red rebuilt turbo if your interested in it?
I've got $230 in it so far with shipping
http://www.superturbodiesel.com/std/show...418&page=2
The one on my car isn't bad
05-24-2011, 04:07 PM #4
Oh that is pretty. I was thinking VNT or HY35 etc. Is that one from the rod benders or 3l 603?
05-24-2011, 05:10 PM #5
HY35 and HY35W same turbo?
05-24-2011, 07:26 PM #6
He said in the add it was from an 1986 300sdl after getting it I decided I'm going to save and get a w140 manifold and hy35
This post was last modified: 05-24-2011, 07:28 PM by willbhere4u.
05-25-2011, 12:32 AM #7
(05-24-2011, 05:10 PM)winmutt HY35 and HY35W same turbo?
THAT TURBO IS FAR TO LARGE AND WONT SPOOL WORTH A SHIT
Lol!!!!!!
Tongue Big Grin Cool Wink Angel Blush
Lol!!!!!!
dieselboy
Rotatin 5500 times a minute
680
05-25-2011, 01:38 AM #8
Lol. Putting a hy35 on a friends 85tdt once he gets it.
Yes they only made a hy35w. W= internally wastegated.
An he341 or hy35 are close to the same thing.
They are slow to make boost but it's still drivable and gets better mileage. I need to check my timing as I think it's way out.
I'll let you know what it's like on a car with a untouched pump as soon as we get the turbo.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
05-25-2011, 09:09 AM #9
(05-25-2011, 01:38 AM)dieselboy They are slow to make boost
This is not what I want. However you stated you get 10psi at 2500. What about at 2000? This us going on a 603 so it should spool better than the 617.
dieselboy
680
05-25-2011, 11:48 AM #10
Oh a 603..... Ive yet to work with one of those. It's a cheap turbo that has been proven tough and reliable. 360° thrust bearing, fat shaft, etc.... Couldn't hurt to try it IMO.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
05-25-2011, 04:23 PM #11
Its hard to find a good turbo suited for the 603. Either all to small or too larger or unobtanium.
Dieselboy, what kinds of psi are you seeing at 200rpm?
05-25-2011, 05:10 PM #12
At 200 rpm I bet none!
dieselboy
680
05-25-2011, 05:40 PM #13
I'd need to drive it and report back. I don't remember. I want to say 5 but I've just been driving the thing lately. My car is never at 2k really. 3 is the sweet spot.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
05-26-2011, 07:48 AM #14
Im looking for a hy30 me thinks. Hard to find tho.
dieselboy
680
05-26-2011, 11:50 AM #15
Any other mods done to the car?
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
05-26-2011, 12:07 PM #16
Not to the engine yet. I have a euro manifold I will be using obviously. I want to get a modified pump but with a kid due in July I have other priorities. Also needs a new hg maybe new head so other priorities are first.
05-26-2011, 12:22 PM #17
what's an hg?
This post was last modified: 05-26-2011, 12:22 PM by willbhere4u.
what's an hg?
05-26-2011, 12:29 PM #18
headgasket?
headgasket?
05-26-2011, 02:16 PM #19
duh !
duh !
05-27-2011, 01:27 AM #20
(05-26-2011, 02:16 PM)willbhere4u duh !
It's ok, took me a second as well haha
05-27-2011, 10:25 AM #21
What we really need is a ball bearing turbo comparable to a Holset hy35
05-27-2011, 04:17 PM #22
(05-27-2011, 10:25 AM)willbhere4u What we really need is a ball bearing turbo comparable to a Holset hy35
Right!?! That would make for some super spool!
05-27-2011, 04:19 PM #23
They are ridiculously expensive.
dieselboy
680
05-28-2011, 12:10 AM #24
What's that?
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
What's that?
-Jesse
70 f250 390
66 Volvo amazon
05-31-2011, 04:18 PM #25
Ball bearing anything... So I have looked and looked and it seems the HE341 is the easiest to find replacement upgrade for stock/semi stock 603. I cannot find a HY30W to save my life. Given Lances report ont he HE341VE I am hoping the HE341 is a easy drop in as well.
ps I asked Lance to sell me his turbo and he said he was disappointed in me and had lost faith a long time ago. Talk about pot kettle hello black.
05-31-2011, 04:33 PM #26
The pot calling the kettle African aluminum!
06-01-2011, 08:51 AM #27
Here is the list of possibles I compiled:
Quote:Garrett/AiResearch T3-45 1978-1985 300D/TD/CD/SD (concurrently used with the K26 from 83+)
Compressor
Exducer: 60mm
Inducer: 40.5mm
12 blades
Turbine
Inducer: 62.5mm
Exducer: 43mm
11 blades
.43 A/R
Quote:HY35 off a 98 cummins 5.9 auto.
9cm housing
Compressor exducer: 78mm
Compressor inducer: 54mm
Turbine wheel: 58/65mm
Quote:hy35 from years 00 to 02. it has the smallest compressor wheel of the hy's at 54mm.
Quote:Holset HX/HY30- Various Cummins 4BTa and John Deere applications
Compressor
Exducer: 73mm
Inducer: 44mm
6 blades
36 trim
Turbine
Inducer: ?mm
Exducer: ?mm
? blades
Quote:Schwitzer S2EGL069 (S2E, 103-2085)
Caterpillar 3116 170,185 HP, Various applications (Bus, Semi, GMC TopKick)
Compressor
Exducer: 76.2mm
Inducer: 57.5mm
57 trim
12 blades
0.60A/R
4" mouth, 2" outlet, Map-width enhancement slot
Turbine
Inducer: 69.75mm
Exducer: 60.5mm
10 blades
0.70A/R
T3 flange w/split ports, 4" v-band outlet
Compressor: 69mm exducer, 44.5 mm inducer
Turbine: 67mm / 56mm
Quote:HE341 compressor inducer at 56mm, exducer at 76 mm.
t3 flange
This is the he341ve...
Turbine
Inducer: 69mm
Exducer: 59.4mm
This post was last modified: 06-01-2011, 09:02 AM by winmutt.
Compressor
Exducer: 60mm
Inducer: 40.5mm
12 blades
Turbine
Inducer: 62.5mm
Exducer: 43mm
11 blades
.43 A/R
9cm housing
Compressor
Exducer: 73mm
Inducer: 44mm
6 blades
36 trim
Turbine
Inducer: ?mm
Exducer: ?mm
? blades
Compressor
Exducer: 76.2mm
Inducer: 57.5mm
57 trim
12 blades
0.60A/R
Turbine
Inducer: 69.75mm
Exducer: 60.5mm
10 blades
0.70A/R
t3 flange
Turbine
Inducer: 69mm
Exducer: 59.4mm
06-02-2011, 11:16 AM #28
HE341 is on its way. Measurements are 54/58/9. Still not sure about the 9cm housing but we shall see!
[Image: he341.jpg]
This post was last modified: 06-02-2011, 11:17 AM by winmutt.
[Image: he341.jpg]
dieselboy
680
06-02-2011, 06:36 PM #29
Nice. Where did you end up getting it?
The Garrett turbos originally on our cars is old technology
This post was last modified: 06-02-2011, 06:38 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
06-03-2011, 01:02 AM #30
(06-02-2011, 06:36 PM)dieselboy Nice. Where did you end up getting it?
Well yeah! they're like 30 yrs old!
06-03-2011, 11:23 AM #31
I dont think the wheel geometry has changed on theses older garetts since wwii.
I got it off 4btswaps. If you have time its a good chance you could pick up a hx30 or hy30 from there.
Anyone know what size pipe is used for the exhaust on the 603?
This post was last modified: 06-03-2011, 11:25 AM by winmutt.
dieselboy
680
06-03-2011, 11:55 AM #32
60mm would be my guess.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
06-10-2011, 11:40 AM #33
HE341 is a big turbo. I think the specs I have are incorrect and that its a hair off the HE351 on the comprssor wheel. As there is too much axial play and a guy just replied back about a HY30W I am going to try to return this.
dieselboy
680
06-10-2011, 12:13 PM #34
Hy30? Thats tiny. To be honest I've never seen one.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
06-13-2011, 01:13 PM #35
(06-10-2011, 12:13 PM)dieselboy Hy30? Thats tiny. To be honest I've never seen one.
Its larger than stock. Should be a good fit for a DD. 3" in and out t3 flange. No weird routing issues (since I am not using IC yet).
08-12-2011, 06:51 AM #36
Soooo... Got the left side of the engine off, turbo manifold etc last night. 2 of the studs are snapped Sad....
Once upon a time I took off the wastegate arm and lost the circlip. So I didnt cook the turbo, arm was just hanging off.............
For now I will probably mount the euro manifold and put the stock turbo on for another week or two until I can finalize fitment.
dieselboy
680
08-12-2011, 11:18 AM #37
Been there done that lol.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
