STD Maintenance General replace bowden cable
06-11-2011, 06:41 PM #1
Ah, this new car has a broken piece on the cable. The threaded plastic adjuster is smashed.
I wish I could get that ball off the end and replace the plastic bit. However it kinda looks like the whole cable and all needs to be swapped.
I have another one on my old trans. Do the cables come in varying lengths? Or does anyone have advice on this repair?
totaldisaster
lightly modded OM606
211
06-11-2011, 07:30 PM #2
thats a nasty job, buddy. You've taken it apart already, right?
You could rig something up with parts from a bike store so that it is adjustable instead of replacing the whole thing.
I might have something, or at least a picture to give you an idea.
totaldisaster
06-11-2011, 07:36 PM #3
I guess I'll have a closer look at jerry rigging it. The cable is totally intact, just that threaded plastic piece is completely smashed.
Could probably make some sleeves of varying lengths to put where the threads would have been. Throw a piece of electrical tape around the sleeve and see how she shifts.
There is also no 3/2 vacuum valve for shifting. But boy it it floats down the road once in fourth.
This post was last modified: 06-11-2011, 07:38 PM by larsalan.
totaldisaster
211
06-11-2011, 08:11 PM #4
I couldn't find what I was thinking of... but imagine this:
A male threaded end is attached to a female ferrule that accepts the bowden cable. (just like the busted plastic) A bike store that does repairs will have this and sometimes they have a big slit down the main axis to accept the steel wire.
Voila... you know the rest.
Sheet, come to think of it, older Volvos have the same thing on them for adjusting the throttle.(memory?)
totaldisaster
06-11-2011, 09:11 PM #5
Need to figure something out. The vacuum system also has some part to do with this clunky shifting. Hate that and it always seems to be confusing.
Yeah a slit right down the side of the collars is what I plan on doing.
totaldisaster
211
06-11-2011, 09:54 PM #6
clunking on upshift?
or just general harshness throughout the entire sequence?
totaldisaster
06-11-2011, 10:02 PM #7
Acts like my last one did when I would forget to plug the 3/2way vac switch in.
There is a way to delete it. I was under the hood today putting an EGR blockoff plate on and I may have messed with some vac connections. There is a mess in there.
Clunk on up and downshift. Where does that modulator on the trans need to get a signal from? Manifold pressure?
totaldisaster
211
06-11-2011, 10:27 PM #8
Trans modulator can take a direct signal from the vacuum control valve (vcv)
Look on top of the valve, one of the ports should be labeled "trans"... if not, I'll hook you up.
edit** thars only one on top... got mixed up with something else. You should be able to send a straight shot from the top of the vcv. Something may need to be bypassed, not sure.... but my '85 does have extra garbage.
There will be a vacuum source from the brake booster line going to the top of the VCV as well as your line to the trans.
This post was last modified: 06-11-2011, 10:43 PM by totaldisaster.
totaldisaster
06-11-2011, 10:50 PM #9
What is the VCV? That is what I'm calling a 3/2way?
[Image: trannyflapper01.jpg]
There isn't one there. I'm sure it can be rigged to work without this part.
Or is the VCV on the rear of the IP? That thing isn't hooked up either.
Vac lines running all over and nothing is hooked up Wink
[Image: VCV_3044.jpg]
This post was last modified: 06-11-2011, 10:53 PM by larsalan.
totaldisaster
211
06-11-2011, 10:54 PM #10
Oh boy. Spaghetti Buffet tonight, boys.
The VCV is on the ip.. you got it. I have never had an engine with that crap on top of the valve cover... but I am pretty certain its the 3/2 valve... or the 3/2 valve is inside there.
It can definitely be murdered.
totaldisaster
06-11-2011, 11:14 PM #11
Yeah, this car is awesome. Got it for 1000 and it is very nice. little rust, has firstaid kit, etc.
Heater and blower motor just started to work. But the wipers stopped working. Have to track that issue too.
And a/c is unhooked, odometer doesn't work, tach sometimes does. Damn tape player doesn't work either.
But the paint is awesome windows and sunroof all open/close with great speed.
totaldisaster
211
06-11-2011, 11:18 PM #12
Those are top priority in my book. That and good compression or at least straight cylinders.
Everything else is DI- whizzey my nizzee.
Congrats... wheres the photos?
This post was last modified: 06-11-2011, 11:20 PM by totaldisaster.
totaldisaster
06-11-2011, 11:26 PM #13
(06-11-2011, 11:18 PM)totaldisaster Congrats... wheres the photos?
Check out this blacked out grill.
http://www.superturbodiesel.com/std/show...p?tid=2699
More photos later, we just drove to get it today and I was kinda whipped from that and all the brews I drank last night.
This post was last modified: 06-11-2011, 11:26 PM by larsalan.
totaldisaster
211
06-11-2011, 11:29 PM #14
Oh man... that paint IS nice. I don't think I have ever seen that color without flaking clearcoat. A steal!
Lets hope the vacuum is solvable.
totaldisaster
06-11-2011, 11:33 PM #15
There is a twin of this car that showed up down the street like 2 months ago. I want to park right next to it and get a photo but, I'm too shy and don't wanna bother whoever owns it.
totaldisaster
211
06-11-2011, 11:46 PM #16
no... you just don't want to embarrass them with your amazing paint.
Idea: go home and detail it for a few days... swirl remover, black trim plasticizer.. the whole nine.
....then take a trip over to friendly neighborman and as for an autograph ; )
or I guess you could just creep over there one night and take a bunch of shots while everyone snoozes (creepy!)
totaldisaster
