STD Maintenance General Need thinner than stock prechamber rings
Biohazard
Smokin like a champ!
376
06-21-2011, 05:55 PM #1
So I put the thicker headgasket in my 617 engine, but I can't find any prechamber sealing rings that are thinner than the stock 2.0mm. I would like to put in a thinner sealing ring to get the prechamber back to its stock hight in relation to the piston. I asked a company for a quote to make a thinner sealing ring, and they wanted $20/each!! That seems a bit on the steep side for a sealing ring. Does anyone know where to get a thinner ring, or have the ability to machine a set to about 1.15mm thick? They seem to be really soft aluminum.
Thanks in advance!
This post was last modified: 06-21-2011, 05:56 PM by Biohazard.
Biohazard
Thanks in advance!
98taco3
06-23-2011, 03:14 AM #2
possibly get ahold of a set of mics and hand sand/lapp them to the correct thickness? alot of work but cheap...
98taco3
300D50
Graphite Moderator, ala RBMK
06-23-2011, 08:21 AM #3
Mail me one, I'll see what I can do. No promises it'll be done this year though...
300D50
Biohazard
376
06-23-2011, 08:48 AM #4
(06-23-2011, 03:14 AM)98taco3 possibly get ahold of a set of mics and hand sand/lapp them to the correct thickness? alot of work but cheap...
Thought about doing that, but I am pretty sure they would get distorted and or uneven during the process. I have an old one laying around, it is really easy to bend it by hand. Plus, like you said, a lot of work. LOL
Thanks for the offer 300D50, but I think I'm just going to bite the bullet and send off for the custom ones. I cant think of any better ideas for making stock ones the needed thickness without messing them up. Should have them in about a month or so.
Biohazard
300D50
06-23-2011, 08:58 AM #5
Oh, I was going to do a short run of them, using one to get measurements.
300D50
Biohazard
376
06-23-2011, 10:24 AM #6
(06-23-2011, 08:58 AM)300D50 Oh, I was going to do a short run of them, using one to get measurements.
Ok, PM me your address, I'll send you one. Smile
Biohazard
Biohazard
376
06-23-2011, 01:28 PM #7
I'll be shipping you out a sealing ring tomorrow at the latest. Thanks again!
Biohazard
300D50
06-23-2011, 11:16 PM #8
No problem, how's 1/5th their price sound? Wink
I'm flexible though, I might be wooed into doing it for random parts, a kudos, or just because, haha.Tongue
300D50
Biohazard
376
06-24-2011, 08:54 AM #9
Holy crap that sounds awesome!! Let me know what random parts you might be looking for too! I'll probably need a total of 10 of these; 5 for my car, 5 more for what ever car I put my other copper headgasket on. Big Grin
Biohazard
06-24-2011, 08:44 PM #10
Look at this guy! I mean between 300D50 and Delivery Valve .... Awesome!
300D50
07-13-2011, 10:12 AM #11
Doing the production run. Smile
300D50
Biohazard
376
07-13-2011, 11:08 AM #12
If anyone else is doing a thicker head gasket, please post in here asap so we can figure out how many of these to make. Thanks again 300D50!!
Biohazard
300D50
07-14-2011, 07:09 AM #13
These were from yesterday, but the network was being flaky so I couldn't access my gallery...
[Image: IMG_20110713_153553.jpg]
Two sets of 1.15's, and the original out towards the right
[Image: IMG_20110713_153818.jpg]
The blue is a windows 7 login screen (no, it's not my personal machine... I run Debian...)
The 1.25's will be getting finished today if all goes well.
This car-porn break brought to you by, machines! They do the work so you don't have to![Image: icon_lol.gif]
300D50
Biohazard
376
07-14-2011, 10:00 AM #14
Those are sexy! You know, in a car-porn sort of way. Big Grin
Biohazard
300D50
07-14-2011, 04:21 PM #15
I've got 30 1.15mm and 30 1.25mm in stock as of now.
300D50
Biohazard
376
07-14-2011, 10:37 PM #16
(07-14-2011, 04:21 PM)300D50 I've got 30 1.15mm and 30 1.25mm in stock as of now.
Sweet! In case anybody wants to go with the thicker headgasket through Cometic, the numbers on the package they sent it in are: H311309c with description 208087. It is a .094 thickness gasket. Cool
Biohazard
07-18-2011, 09:23 AM #17
Erf. Those are crush rings. Your solid rings will not seal as well I do not think.
300D50
07-18-2011, 09:32 AM #18
I'll be honest, I'm a little worried about that as well.
Biohazard and I decided to try it anyways, and hope the surfaces involved are parallel enough to work.
The idea is to torque them in stages, up to the FSM's specified value.
This post was last modified: 07-18-2011, 09:33 AM by 300D50.
300D50
Biohazard
376
07-18-2011, 10:01 AM #19
Yeah, much like the thicker headgasket, I'm ok with being the guinea pig. I've got the special tool for the prechamber collar being shipped; this will help with getting the torque correct.
Biohazard
Hercules
07-19-2011, 05:55 PM #20
Never had a problem re-using old rings,just apply small amount of sealer.So don"t see problem using solid ring! No leaks!
Hercules
Biohazard
376
07-19-2011, 08:24 PM #21
Again, you've come through with a great tip. Thanks!! Waiting for multiple packages now...
Biohazard
Biohazard
376
07-22-2011, 09:15 AM #22
Got two packages here now! One box of sealing ring goodies and one box with the lock collar tool!! Woot! I know what I'm doing Sat after work!!
Hercules, what type of sealer did you use? I have some of the spray copper sealer I used with my copper headgasket, think that would do the trick?
Biohazard
300D50
07-22-2011, 09:20 AM #23
The ones with 2 sharpie marks are thicker IIIRC.
Sorry about the burrs on the ID...
300D50
Biohazard
376
07-22-2011, 09:36 AM #24
I can get the burrs off. No problems there. Smile I've got a caliper, I can check the thickness to make sure too.
Biohazard
07-22-2011, 10:43 AM #25
I do rent the lock ring tool.
Biohazard
376
07-22-2011, 02:45 PM #26
^^^ I had forgotten about that. But, I also have 3 and a halfish MB diesels in the family, so having my own is good. Plus, I'm a tool whore. Big Grin
Biohazard
Hercules
07-22-2011, 03:49 PM #27
(07-22-2011, 09:15 AM)Biohazard Got two packages here now! One box of sealing ring goodies and one box with the lock collar tool!! Woot! I know what I'm doing Sat after work!!
If that copper sealer works good for the head gasket should be ok .I used high temp. silicone . Is the prechambers going be be drilled at exit holes,at least to 85 specs.Sure worked well for me. Prechambers, not hard to drill ,did by hand.
Hercules
Biohazard
376
07-22-2011, 04:12 PM #28
Doing the tapered entrance to the PC holes. I have a spare from a parts engine I practiced on the other day. Really easy to cut with a carbide bit and some cutting oil.
Biohazard
Biohazard
376
07-25-2011, 12:49 AM #29
Didn't have a chance to work on this on Saturday. Just about finished the adapter to pull the prechambers tonight though. Need to make one more groove for clearance and then it should be ready.
Biohazard
