STD Tuning Engine manifolds?
manifolds?
manifolds?
randomdude
06-22-2011, 07:23 PM #1
so i guess if i'm shootn for power/efficency i should address the mani's. so what are the best "bang for buck" mani's? both IN and EX? unless you all have other ideas, like stockers that will flow just as well?
ANY input is appreciated Big Grin
P.S. how can i have my avatar title changed??? I HAVE TWO TURBO CARS IN MY SIG LOL. im clearly no N/A guy lol.
This post was last modified: 06-22-2011, 07:24 PM by randomdude.
cars? what cars? WHERE???
randomdude
06-22-2011, 07:37 PM #2
You have to keep posting Wink
I think there are some good intakes but for exhaust you'll need to weld one up.
I could be wrong, wait for some of these old mbz experts to chime in.
led-panzer
06-22-2011, 08:15 PM #3
As far as intake manifolds, the best you could get would be the w115 manifold, exaust would be from the turbo models before they started adding the EGR, the 78 and 79 SD.
1985 300D 280,000 miles RIP
led-panzer
MTUPower
287
06-22-2011, 08:45 PM #4
(06-22-2011, 08:15 PM)led-panzer As far as intake manifolds, the best you could get would be the w115 manifold, exaust would be from the turbo models before they started adding the EGR, the 78 and 79 SD.
X2- and if you can coat (like jet hot)the exhaust to keep the heat in (and gases flowing faster) it's about the best you'll get until you go custom.
This post was last modified: 06-22-2011, 08:45 PM by MTUPower.
MTUPower
dieselboy
Rotatin 5500 times a minute
680
06-22-2011, 09:49 PM #5
I have a non egr exhaust manifold and a modified w115 intake manifold on my car.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
MTUPower
287
06-23-2011, 08:14 AM #6
(06-22-2011, 09:49 PM)dieselboy I have a non egr exhaust manifold and a modified w115 intake manifold on my car.
While I have the stronger/better non egr exhaust that is coated- I gotta ask- how much does the long runner intake seem to help?
MTUPower
06-23-2011, 09:57 AM #7
You can put in a custom title in you user cp
randomdude
06-23-2011, 03:57 PM #8
im going to delete the egr with a kit someone sells. are there other benefits to getting the actual non egr manifold?
would i be better off to do a log mani? is there kits for them?
how much to get a modded IN mani like yours?
are there any benefits to be had by P&P these stockers?
This post was last modified: 06-23-2011, 03:58 PM by randomdude.
randomdude
06-23-2011, 04:11 PM #9
Yes, the non EGR exhaust manifold is said to flow better than the EGR version.
The W115 is basically a log manifold and should provide better low end torque
You can get them at the junkyard if your lucky and spot one
randomdude
06-24-2011, 04:48 PM #10
so does anyone do log/tube manis for these? i bet your lookin at BIG $$$ since like 12 people in the world mod these lol.
randomdude
randomdude
06-24-2011, 08:15 PM #11
anybody got a non egr to sell?
randomdude
dieselboy
680
06-24-2011, 11:12 PM #12
(06-23-2011, 04:11 PM)Captain America Yes, the non EGR exhaust manifold is said to flow better than the EGR version.
Think I lost bottom end with the w115 manifold.
And the non egr exhaust manifold keeps 4-5 separated to the collector and the egr one doesn't.
Im going to the jy tomorrow if there is a non egr exhaust mani I'll snag it. I've had good luck finding those. Got 4 so far but the w115 manifold I've only ever found and seen one.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
randomdude
06-25-2011, 02:30 PM #13
so if you find a nonegr how much would you want for it shipped? so do you think it was not worth getting the 115 mani?
randomdude
mantahead
06-25-2011, 02:50 PM #14
(06-25-2011, 02:30 PM)randomdude so if you find a nonegr how much would you want for it shipped? so do you think it was not worth getting the 115 mani?
hi guys, i am running a standard om605 egr ex manifold with the turbo side bored out bigger and i used black iron bends to extend the manifold and welded a flange and mounted the hx35 up front beside the rocker cover. This is a cheap ass manifold and has run 368 hp with 426 ft lb torque.
mantahead
dieselboy
680
06-25-2011, 04:07 PM #15
There was only 1 non egr car there and it was the one I took the manifolds off of last time.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
randomdude
06-25-2011, 07:46 PM #16
dieselboy- what about my second Q?
mantahead- VERY nice to hear/know. what were your other modifications? (interals, trans, what size IP element, etc)
randomdude
mantahead
06-26-2011, 05:38 AM #17
[/quote]hi, i have used Toms 7.5mm elements, standard internals, modified 6 cyclinder inlet manifold, 5 puk paddle clutch and welded diff.
mantahead
randomdude
06-26-2011, 02:36 PM #18
could you supply pics of the mani please?
randomdude
06-26-2011, 11:19 PM #19
FYI for pictures.
http://www.superturbodiesel.com/std/show...p?tid=1694
I wish the picture links were fixed.... Moderators?
This post was last modified: 06-26-2011, 11:19 PM by DeliveryValve.
FYI for pictures.
randomdude
06-28-2011, 01:49 AM #20
DV- ive read that thread SEVERAL times. i was hoping that mantahead could show us pics of his modified mani.
randomdude
mantahead
07-25-2011, 07:05 PM #21
(06-28-2011, 01:49 AM)randomdude DV- ive read that thread SEVERAL times. i was hoping that mantahead could show us pics of his modified mani.
http://s1213.photobucket.com/albums/cc46...20Uploads/
This is a link to my manifold extension pipe.
mantahead
randomdude
07-26-2011, 12:57 PM #22
(06-25-2011, 02:50 PM)mantahead
any pics of they mani you mentioned above?
randomdude
mantahead
07-26-2011, 05:35 PM #23
(07-26-2011, 12:57 PM)randomdude
Did that last link work ok? I'm not that great at this kind of thing. That was the pipe between manifold and hx35. I have a 20mm spacer between this pipe and turbo which is to allow for quick spool valve.
http://s1213.photobucket.com/albums/cc461/mantahead1/
This shows the hx35 on the engine, extension pipe and original manifold
and 20mm spacer.
mantahead
and 20mm spacer.
randomdude
07-28-2011, 09:09 AM #24
ok cool, now i gotcha. ya, that worked. ya, i'm not that great at that kind of thing either lol. i'm pretty suprised a stock EX mani supported 426 ftlb's, you think you would gain much from a custom/log manifold?
lots of guys run log mani's on the volvos, i dont see many in the mbz world.
randomdude
mantahead
07-28-2011, 07:05 PM #25
(07-28-2011, 09:09 AM)randomdude ok cool, now i gotcha. ya, that worked. ya, i'm not that great at that kind of thing either lol. i'm pretty suprised a stock EX mani supported 426 ftlb's, you think you would gain much from a custom/log manifold?
hi,
i think my manifold is not holding me back much yet but it won't be long.
My ecu is cutting fuel at 4900rpm but revs to 5500. Now i will try same manifold with mechanical pump.
I would like to make a new manifold soon. Do you know where i can get a 12cm housing for my holset hx35?
I would like to get 400hp on this manifold.
mantahead
hi,
07-29-2011, 07:22 AM #26
I have a NON-EGR intake manifold from a 1979 300SD, W116. I am willing to sell it for $40 plus shipping. It's light, so shipping should be around $10 or so. I am still lookiing for a W115 intake, however, so that is why I am selling. PM me if you're interested. Thanks.
