STD Tuning Drivetrain early w126 subframe on w123?
BRABUS
07-15-2011, 04:49 PM #1
Hi
As topic says.
Would a complete rear subframe bolt on my w123 300d?
i know the control arms and wheel hub are the same. But maybe the subframe is wider on the w126?
BRABUS
Hi
As topic says.
07-17-2011, 11:26 AM #2
(07-15-2011, 04:49 PM)BRABUS Hi
As topic says.
The rear track on the w126 is something like 3 inches or 76 mm wider than the w123, and since the control arms and hubs are the same, the wider length is made from the sub frame. So no it will not bolt up without modification.
As topic says.
