STD Tuning Engine turbo with no whistle
chach007
07-20-2011, 09:10 AM #1
Hey there. My 1980 300 sd turbo has been swapped to a 1983 300 sd turbo. I dont seem to have that turbo whistle on my newer motor. I do have some power. I dont have a boost gauge or pyromometer. Is it possible that the turbo could be full of Carbon. The intake elbow removed i can see the turbo spinning and a slight whine. Its just quiet. But driving it there is no noise under load or idle.My car gets up and goes. all componants are adjusted correctly. Thanks Quinn
1980 300 SD,recent 1983 motor install. 2005 Triumph Bonneville.
chach007
07-20-2011, 09:26 AM #2
That's weird, I should think you would hear it. Can you rig up a boost gauge? It's a fun thing to have and only costs $20 or <
dieselboy
Rotatin 5500 times a minute
680
07-20-2011, 11:48 AM #3
When i took my tubo off my car you could hear the thing loud and clear. We put it on my friends car you could hardly hear it. I think it's a timing deal on his car.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
07-20-2011, 12:05 PM #4
Is it the same type of turbo the garret T3's are quieter than the k26's
07-20-2011, 03:04 PM #5
With the stock air box and intake elbow (u tube) you wont hear a thing
chach007
07-21-2011, 09:07 AM #6
(07-20-2011, 11:48 AM)dieselboy When i took my tubo off my car you could hear the thing loud and clear. We put it on my friends car you could hardly hear it. I think it's a timing deal on his car.
Well i think it sucks that I cant hear it. I will get a boost gauge connected soon. Thats the best part of a diesel, The whistle. My timing is dead nuts on. Ok i'll get a boost connected. My old turbo had two fins bent . That sucker screamed out . With the elbo off it it still super quiet. But if thats the way they are then it is what is. But i want whistle in my turbo.I could just stick a few of the birthday party favors in my mouth w/ the windows down and blow real hard.
(07-20-2011, 12:05 PM)willbhere4u Is it the same type of turbo the garret T3's are quieter than the k26's
What model year sported the K26. Or is it just another turbo that would fit.I have a 722.1 ? 1980 trans, and 1983 motor in my w116 1980 300 sd. stock turbo. So i have an extra 5 H.P. w/ the motor With more boost from a k26 be alright or is it the same
This post was last modified: 07-21-2011, 09:12 AM by chach007.
chach007
07-21-2011, 11:05 AM #7
Best bet is a party favor haha
You should hear it if its spooling no doubt. I guess best thing to do is check for boost
07-21-2011, 03:38 PM #8
Myb you need a exhaust delete Wink
led-panzer
07-21-2011, 09:37 PM #9
Stock turbo, stock exhaust, and alda on, I barely heard mine. Removed exhaust and alda and it would sing all the time. I miss it, my vnt only has a whistle for about a second Dodgy
This post was last modified: 07-21-2011, 09:39 PM by led-panzer.
1985 300D 280,000 miles RIP
led-panzer
chach007
07-21-2011, 11:25 PM #10
(07-21-2011, 03:38 PM)larsalan Myb you need a exhaust delete Wink
I bet my exhaust system weighs twice as much as it should. Looking through the tail pipe i can see a crap load of soot build up.Removing the exhaust muffler is one mod that is effective. What about the exhaust system that was designed for proper back pressure.
chach007
Biohazard
Smokin like a champ!
376
07-21-2011, 11:33 PM #11
I pulled the twin little kidney mufflers and welded a piece of straight pipe in their place. It was a touch louder but not obnoxious. I really don't remember if I could feel a difference, bit it at least sounded faster! Saves a bit of weight too! I couldn't really hear my turbo until I got rid of the stock intake, now it screams.
Biohazard
07-21-2011, 11:46 PM #12
+ 1,000,000!
The exhaust weight at least 50-60lbs on an SD
This post was last modified: 07-21-2011, 11:46 PM by Captain America.
+ 1,000,000!
07-22-2011, 09:37 AM #13
Here is the engine in my dads car It an 83 engine it has pre 1980 non EGR manifolds a k26 turbo available on 84-85 models I think It makes the same amount of boost but it has a smaller exhaust housing witch helps it spool up almost 700 rpm sooner so it makes my dads car a torque monster out of the lights! It has a cheap filter on it so you can hear the turbo! also the ALDA is not removed but it is maxed out!
This post was last modified: 07-22-2011, 09:38 AM by willbhere4u.
07-22-2011, 10:10 AM #14
Boost gauge will tell all. The stock exhaust on the 617 is more than adequate as it is straight flowing. If you are going to remove anything remove the resonator.
chach007
07-24-2011, 12:04 AM #15
(07-22-2011, 10:10 AM)winmutt Boost gauge will tell all. The stock exhaust on the 617 is more than adequate as it is straight flowing. If you are going to remove anything remove the resonator.
Boost gauge installed today. 3000 rpm i was @ 8 lbs of boost. Ran up a steep hill for some load w/ the air intake elbo off and the turbo is singing.
This post was last modified: 07-24-2011, 12:05 AM by chach007.
chach007
07-24-2011, 12:20 AM #16
I recommend the fram intake mod. It's been shown on here before. I did it the other day and think it's an easy and awesome upgrade.
A fram 8037 or 8038 I think. Then a few dollars of abs bends and whatnot.
Clears up a lot of space, drops a pound or two and has got to flow better.
Is 8psi your max? Or can you get up to 10?
Oh, and seriously delete or straighten out that exhaust, magna flow or straight or 8in hood stack Wink
This post was last modified: 07-24-2011, 12:24 AM by larsalan.
chach007
07-24-2011, 12:00 PM #17
(07-24-2011, 12:20 AM)larsalan I recommend the fram intake mod. It's been shown on here before. I did it the other day and think it's an easy and awesome upgrade.
My boost is 8 @ full load. Thats my max. The stock air cleaner still installed. I'm looking for a intercooler, and air element to mount. Not having good luck with the exact diam. air filter installation for inlet turbo. I've only had this car since December, my first Benz. Also recently put trans in gear floor it , motor just goes bleagh around 2000 rpm . It will not do a burnout. damb maybe i should have got a 240 w/ a w116 turbo . or a V8 chevy crate. oh well this is my daily car and cant afford to break it .
chach007
07-24-2011, 12:58 PM #18
You can see what I'm talking about here...
http://www.superturbodiesel.com/std/show...=fram+8038
though maybe those pictures are on the way out?
07-25-2011, 08:57 PM #19
You wont do a burnout with the ALDA still on the injection Pump. It wont give you enough fuel to make any boost.
Remove the ALDA and you have a completely different animal. Tongue
with ALDA I couldn't build any boost power braking, and without ALDA I can make like 7 psi.
You boost is also low. should be 9 psi stock and 12ish is best
capflya
Dreaming of a VNT
309
08-08-2011, 04:21 PM #20
Not sure what my boost is... but I still have alda in and my benz will spin em' Tongue
Engine only has ~145k miles on it. 3.07 diff but with the 85 tranny that has the higher stall torque converter. Not sure if that makes a difference but possibly.
capflya
dieselboy
680
08-08-2011, 04:48 PM #21
My car would kill a stock tire. I can powerbrake with the huge 245s on it and a 2.65 LSD. Granted it may take a few for it to make boost but when it does it will spin inti 2nd.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
08-09-2011, 01:35 AM #22
(08-08-2011, 04:21 PM)capflya Not sure what my boost is... but I still have alda in and my benz will spin em' Tongue
Yeah That 2500 stall converter would make a big diference
08-10-2011, 07:59 AM #23
(07-24-2011, 12:00 PM)chach007 My boost is 8 @ full load. Thats my max.
Adjust WG or rebuild unless you are at high alt.
dieselboy
680
08-10-2011, 06:23 PM #24
Hes like 200ft above sea level in "Oceanside" lol.
We will have to meet up sometime.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
smoke026
When the Cat's away the mice will play!
94
08-10-2011, 07:44 PM #25
Don't want to sound like a DICK or take a Dump on your thread but,
Regarding Air Filter Setups.
The FRAM 8038 exposed air filter WILL NOT generate more power or create more air flow than the stock OEM box.
I dropped the idea of installing the Fram after going insane "literally" for days reading up on multiple sanctioned bodies of racing regarding engine air filtration. Unless the whole thing is at least 90% correctly shielded and scooped for air induction, ur wasting ur time. It wont clunk ur motor over either but I think its still not a smart move.
Bottom line is that an exposed air filter will suck roughly 40% hotter air, has 16 Degrees avg higher E.G.T's than OEM, has longer EGT cool downs, it generates 20% hotter under hood temps. etc etc
Every 5.5°F increase in air intake temperature reduces engine
power by 1%.
Every 1°F of cooler intake air will reduce EGT by approximately
1.5°F.
Cooler intake air reduces under hood temperature.
OEM sealed air box allows the engine to cool down faster than
semi-open heat shield type air boxes.
Cooler intake air improves mileage. Every 10°F drop in intake
air increases mileage by 1%.
Think about it logically, even lawn mowers have sealed air filters! Refer to attached pics of some random sanctioned bodies of PRO RACING air filter setups. Not 1 has an exposed air filter. I wonder why?
NASCAR:
[Image: wqwint.jpg]
FORMULA1:
[Image: r2rf9c.jpg]
[Image: 2817hat.jpg]
MIDGETS:
[Image: dnhmqr.jpg]
SHIFTER PRO KARTS:
[Image: dvpmj9.jpg]
FERRARI:
[Image: 2irkk1d.jpg]
GRAND PRIX CR6 CORVETTE:
[Image: 2rdx9v7.jpg]
This post was last modified: 08-10-2011, 07:55 PM by smoke026.
smoke026
power by 1%.
1.5°F.
NASCAR:
[Image: wqwint.jpg]
FORMULA1:
[Image: r2rf9c.jpg]
MIDGETS:
[Image: dnhmqr.jpg]
SHIFTER PRO KARTS:
[Image: dvpmj9.jpg]
FERRARI:
08-11-2011, 12:37 AM #26
Your right, It doesn't create more airflow. It allows for more airflow. In any case weather stock or you have a larger turbo or are even twin charging, your going to want the Least amount of restriction. I think that's the only thing you forgot to measure or just didn't post about....
1 reason to add the Fram is SURFACE AREA and plumbing. Now I'm not going to get into the number of pleats and junk like that but I can be sure the fram has more surface area than the stock round filter. As far as plumbing goes... The stock setup just LOOKS restrictive... haha
*Every 10° change in Air temp either increases or decreases power by 1% (as taught at UTI)
Cooler intake air temp decreases under hood temps? Because of EGT's?
The American Le Mans GT ZR1's are just badass cars that Win!
You CANNOT compare the shitty stock air filter assembly to RACE cars! haha All of them (execpt for maybe the Kart) use sealed intakes that either have NO restriction or are pressurized by the speed of the vehicle. My Buell also uses the same "forced" air intake and actually develops boost when traveling above 80mph. The Benz intake could only dream of that....
smoke026
94
08-11-2011, 09:11 AM #27
Weather it Allows more airflow the fact remains that the additional air flow allowed will be of hotter air and of more turbulent air.
If a semi-open air box delivers up to 39° hotter intake air to the turbo than the OEM air box why would it matter that ur increasing the flow of such hotter air?
Its true that its not fair to compare race cars to stock cars, but its the theory that matters. They are trying to suck colder air into motor.
Lower under-hood air temperature: The engine, radiator and especially the exhaust manifold and turbocharger are the 4 biggest contributors of under-hood heat. When using cooler intake air in the engine, the exhaust manifold and turbocharger produces lower EGT, thereby radiating less heat into the engine compartment. Plus lower engine compartment temperature extends the life of many components under the hood.
Reduce air turbulence: Flat panel air filters are known for straightening air flow as air passes through the filter, resulting in uniform air flow and a shorter air path to the turbocharger. Conical air filters, due to their round shape, swirl the air as it travels through the air filter and down the intake tube (just like water vortexes when a toilet is flushed) increasing air flow turbulence. Turbulence in the intake tube causing the turbocharger to work harder to draw in air.
Air filter remains cleaner: Semi-heat shield air box allows under-hood heated air, circulating around the engine to enter the conical filter, depositing an oily and greasy film on the filter from OM617 8), resulting in more frequent filter cleaning to maintain performance. The OEM sealed air box prevents engine compartment air from entering the air filter, keeping the filter cleaner and extending the replacement or cleaning intervals.
MTU power: has the best TRUE after market cold air intake set up I have seen on OM617:
[Image: sltcfl.jpg]
Rudolf_Diesel's Conical Air filter shield is prob 2nd best.
[Image: esp11w.jpg]
Quote:The American Le Mans GT ZR1's are just badass cars that Win!
An acquaintance has a zr1 racing school, He wants around 10k to get me into a ZR1 "Semi" [meaning not official] Le Mans car for a couple laps. CRAZY!!!
This post was last modified: 08-11-2011, 02:23 PM by smoke026.
smoke026
[Image: sltcfl.jpg]
[Image: esp11w.jpg]
08-11-2011, 03:32 PM #28
The Fram filter is not "conical", and is used in the OEM
The OEM filter still has WAY less surface area than the Fram.
I guess we can agree to disagree but I still think the OEM setup = shit Tongue
P.S. I plan to use the passenger side cowl duct as an air intake. Not only will it be some of the coolest but it will be forced air by the high pressure at the bottom of the windshield....
This post was last modified: 08-11-2011, 03:35 PM by Captain America.
smoke026
94
08-11-2011, 08:13 PM #29
Sweet!! I did see an old pic somewhere I think Benzworld or something where someone managed to plumb the intake to where the battery sits. It had a simple U bend from the turbo to the battery. Practical and simple. Perfect for shielding and could suck air from the cowl.
No beef just opinions! Beefing is not good...im here to learn.
I was half way committed on my FRAM setup anyways, i did not really have an interest in it so I dropped the ball on making it functional. I agree that under the right circumstances it could be acceptable.
Lets now enjoy some good old F1 Renault Turbo cars from the 70's. 2012-13 I think they will reintroduce turbos. These mofos sure know what they are doing.
http://youtu.be/-Da_tGousd8
This post was last modified: 08-11-2011, 08:14 PM by smoke026.
smoke026
08-12-2011, 07:03 AM #30
The OEM setup is excellent. Except that they made the bracket out of aluminum and they snap all the time. I went away from stock because I was tired of replacing mounts and brackets. If I had the time I would make an air dam around it. Smoke all of those numbers you quoted probably do not apply to the MB as the engine bay is 10x larger than any ricer. At idle/slow speed you will have increased intake temps but at speed its just as cold as stock.
smoke026
94
08-12-2011, 06:02 PM #31
Those numbers were grabbed as an accumulated study from multiple diesel turbo motors V6 and V8. Real life mapping of OEM vs CAI kits performed by non CAI suppliers of course.
Mostly RENAULT,CUMMINS, & POWERSTROKE. I am no mechanical engineer but do think that the logic should transfer mostly to all motors.
Exposed CAI's are cool and all but has always been that "upgrade" that I honestly never really understood. Kind of like someone removing their A/C system, removing all their windows and calling it a
[Cold A/C Window kit]. Then they will say "AHHH but listen to how that wind spools"..
No insult to Swamp Coolers of course which actually do cool!
[Image: s617x3.jpg]
smoke026
[Image: s617x3.jpg]
808morgan
10-09-2011, 12:43 AM #32
Where can I get this?? I looked up MTU and I don't see anything. I really want to get rid of my broken air cleaner bracket and this looks like an awesome option! Please share!
[Image: sltcfl.jpg]
Cheers
808morgan
[Image: sltcfl.jpg]
Cheers
E300TSC
Turbo-Supercharged
321
10-11-2011, 05:40 AM #33
MTU Power is a member on this and other forums...
E300TSC
