STD Tuning Drivetrain 240D 4 speed transmission fluid
TheDon
606 Power!!
247
08-14-2011, 09:27 PM #1
I picked up two quarts of pennzoil synchromesh since it was recommended on the peach forum. Is that a good oil to put in the transmission?
TheDon
300D50
Graphite Moderator, ala RBMK
08-15-2011, 06:51 AM #2
Factory states to use ATF in the manual boxes, so I'd use that.
300D50
TheDon
606 Power!!
247
08-15-2011, 09:25 AM #3
I wasn't sure if that was a good idea or not since ATF is very very light. I read a lot on the forums and it's a mixed response jet like oil types. Sad.
TheDon
08-15-2011, 09:45 AM #4
I think it depends on the year of the transmission the older ones I have seen early 1960-70's used 30 weight & later one's used ATF and but I have no idea when it comes to the later all aluminum boxes like yours?
300D50
08-15-2011, 09:59 AM #5
I know someone on here tried with ATF and regular oil, can't remember who though.
This post was last modified: 08-15-2011, 10:17 AM by 300D50.
300D50
TheDon
606 Power!!
247
08-15-2011, 06:05 PM #6
The transmissions were swapped today.
[Image: 223731_10150251640061534_589171533_78580...4788_n.jpg]
the old transmissions had ATF in it. The new(still old) transmission had gear oil in it. I drained the oil and put in the synchromesh. It shifts soooo nice.
This post was last modified: 08-15-2011, 06:47 PM by TheDon.
TheDon
08-18-2011, 07:13 AM #7
ATF and 10W30 maybe used. Did you have an experience with the new trans prior to the penzoil? I have Royal Purple in my 4 spd. MTL in my 5spd but I am not over impressed with it.
