STD Other Pics and Videos Angry OM606
Angry OM606
Angry OM606
HoleshotHolset
08-23-2011, 12:07 AM #1
1) Angry because it is only running on 5 cylinders
2) Angry because it is very free flowing Big Grin
After the entire intake was removed, I looked down into the intake ports this evening - couldn't see anything obviously wrong with either of the ports on #2. So it's still anyone's guess as to what is up with that engine at this point. Granted, with all that yummy slime/crud in the intake from EGR+CCV vapors...it's hard to see in there.
Few more hours to go and the old OM606.910 will be removed from the W124...then the OM606.962 will be put in its place.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
iheartboost
08-23-2011, 03:09 PM #2
why on 5 cylinders?
00 Mustang gt drift car
iheartboost
why on 5 cylinders?
HoleshotHolset
08-24-2011, 09:07 PM #3
(08-23-2011, 03:09 PM)iheartboost why on 5 cylinders?
Until I know for sure what is wrong with it - your guess is as good as mine. Smile
If you rev it up just a little bit, it will backfire slightly through the intake and it is also pumping exhaust through the intake. Methinks the valves and/or seats for the #2 cylinder have been damaged. The intake runners for #2 got warm after only a short time of idling - so the exhaust flowing the wrong way is heating things up a bit.
The previous owner had the glow plugs swapped out and I think they said that the engine started acting up AFTER the shop changed the glow plugs....so perhaps a chunk of miscellaneous crud or a chunk of old glow plug did some damage in there...
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
vilsaa
12-19-2011, 11:25 AM #4
You can try to change the hydraulic valve lifters. they Jam some times and valves lets the pressure out
(08-24-2011, 09:07 PM)HoleshotHolset
Beers,
Matt
vilsaa
Beers,
Matt
HoleshotHolset
01-22-2012, 12:08 PM #5
(12-19-2011, 11:25 AM)vilsaa You can try to change the hydraulic valve lifters. they Jam some times and valves lets the pressure out
That is VERY good advice - thank you!
I should have checked the lifters before I started disassembly of the W124...I could have been driving it months ago. Oh well.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
E300TSC
Turbo-Supercharged
321
02-03-2012, 11:37 PM #6
Yeah, stuck lifters. You can pull them out and exercise them in a vise, squirt cleaner into the ports and get them working properly again.
E300TSC
HoleshotHolset
06-18-2012, 12:03 AM #7
Methinks the OM606 in this rat rod suffered from a stuck lifter or two during this burnout run...do you concur?
Beers,
Matt
This post was last modified: 06-18-2012, 12:04 AM by HoleshotHolset.
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
bonden_85
07-08-2012, 06:55 AM #8
(06-18-2012, 12:03 AM)HoleshotHolset Methinks the OM606 in this rat rod suffered from a stuck lifter or two during this burnout run...do you concur?
Beers,
Matt
Nope, he was running without wastegate and due to ridicoulus boost he blew a 10cm piece off the headgasket at the 6th cylinder...
btw it's a OM603 Wink
// Johan
This post was last modified: 07-08-2012, 06:58 AM by bonden_85.
bonden_85
Beers,
Matt
// Johan
HoleshotHolset
09-04-2012, 10:40 PM #9
(07-08-2012, 06:55 AM)bonden_85 Nope, he was running without wastegate and due to ridicoulus boost he blew a 10cm piece off the headgasket at the 6th cylinder...
// Johan
Ha! Those 603's do love to eat head gaskets. Smile
Beers,
Matt
'07 W211 OM642
HoleshotHolset
// Johan
Beers,
Matt
'07 W211 OM642
Siekkinen
09-05-2012, 07:29 AM #10
Many om606 engines have problems with valves. Usually valve sinks in head and lifter runs out of adjustment (is that right word for it?) and valve wont hold pressure anymore. If that happens faulty cylinder usually begins to run when you press gas pedal. On idle it doesnt run. Let the engine go cold and pour some oil on that valve and look does oil surface decrease.
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
HoleshotHolset
09-09-2012, 10:36 PM #11
Very good information there - thank you!
I recently gave this engine to a diesel mechanic student in Indiana - he is going to rebuild the entire engine and has plans to turn it into a STD.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
