STD Other Projects my w124 606 962 Superturbodiesel
  • 3 Vote(s) - 4.67 Average
Pages (4): 1 2 3 4 Next
08-31-2011, 02:01 PM #1
hello again!
by my second infirmity, I have decided to build a 24v turbo diesel.
I bought a used 606 962 ...
I'm still not sure whether I should remove the cylinder head or not to rebuild.
someone has a good solution to the intake manifold and exhaust manifold for? hx40w with T3 flange should fit.
thank you
hansebanger77
hello again!
thank you
E300TSC
Turbo-Supercharged
321
09-01-2011, 08:24 PM #2
Sounds like a good project! Good luck!
E300TSC
09-02-2011, 04:41 AM #3
What throttle linkage for 606 in w124?
performance exhaust manifold? anyone can build me one.. ?
hansebanger77
aaa
09-02-2011, 01:10 PM #4
Here's the NA 606 linkage:
aaa
09-02-2011, 01:49 PM #5
ahh a 606 NA is stock mechanikal linkage? with a normal mech pump same as 603? an shuld fit plug and play?
and the 606 turbo is electric...
hansebanger77
09-07-2011, 12:16 PM #6
should I cut my intake manifold?
someone has pictures of one?
hansebanger77
09-19-2011, 09:51 AM #7
There are two pins are pulled down. now stuck in the head.
any tips to drill out ?
hansebanger77
09-23-2011, 09:58 AM #8
(09-19-2011, 09:51 AM)hansebanger77 There are two pins are pulled down. now stuck in the head.
You mean glow plugs? There is a thread here and a DIY on peachparts. Its not pretty.
09-23-2011, 02:33 PM #9
no it was the bolt for the exhaust manifold.
thanks i fixt the problem.
i only ned a pood picture of the original linkage of a 606. i think olso perhaps the inj pump have a other as the 603. but not sure.
the pump is installt and engine is runnig at18° ADC verry well
but I must remove the pump again, because the timing is on 18° maxed out to late.
hansebanger77
10-05-2011, 02:49 PM #10
hi
the engine is in.
can someone help me with the speedmeter ? or RPM-meter dont know the right word.. to see the rpm inside the car.. haha Big Grin
the sensor does not fit from 603 to 606t engine
and the 606 stock aso not because the sensor does not fit to the flywheel.
It was an automatic gearbox on the 606 engine. and i take my 5 speed gearbox from a 603 again with stock 603 flyweel.
what can i doo? is ther a way over the generator?
thx
hansebanger77
hi
the engine is in.
thx
10-11-2011, 06:25 AM #11
projekt update
hansebanger77
projekt update
10-11-2011, 12:27 PM #12
holy jebus! Thanks for the updates keep them coming great progress
10-14-2011, 05:17 AM #13
hi!
can I use the oil filter housing from the 603? on my 606?
I think the 606 is no pressure sensor?? wtf?
An advantage would be also the oil cooler line would fit again 1 to 1 to the 603 housing. apart from the pressure switch ..
thx
hansebanger77
hi!
thx
10-19-2011, 01:22 PM #14
hansebanger77
aaa
10-19-2011, 03:41 PM #15
Zeitgeist did it on his 124/606 dealio:
http://www.benzworld.org/forums/w124-e-c...24-10.html
aaa
10-27-2011, 03:37 PM #16
hi guys
Today I had time to work on my benz.
The oil filter 603 housing fits and now the oil cooler as well.
I built the new turbo housing with the rest of my hx 40 together. and turned the middle section and the compressor-side so that everything fits.
oil inlet and oil outlet I've already finished. Oil flow was a disaster. everywhere so little space. just past at the manifold flange, compressor outlet and manifold pipe itself Smile but I guess it could fit.
the glow wire I soldered. matches the stock relays now.
today the first start!
everything in the green rangeSmile
I'm happy I made a lot today
Next
intercooler pipes
Intake adapt
Connect the water cooler and heater
new downpipe
ETG
Drill hole for rpm meter sensor
testdrive Smile
hansebanger77
hi guys
Next
intercooler pipes
Intake adapt
new downpipe
ETG
testdrive Smile
ritvarsx
10-29-2011, 02:39 PM #17
Take a video!Big Grin
ritvarsx
10-31-2011, 09:00 AM #18
hi
I think I'm out of luck ......
I did everything together as far as I can made ​​a test drive ..
once full throttle and the power went off .. I was briefly with 2.3 par boost pressure
then the power was off, I thought my worst. motor is running shit .. no idle ..
i think for a moment o fuuuck my rods ore somsing is damaged.. how the finns can drive like hell and go on driftrace with a sock never open 606 turbo and drive 2.5bar and nothing happen with de engin..? damn
I just now tested the timing .. (with position sensorless original MB)
Both leds light at about 3 degrees after dead center ????? WTF ????????????
how can that be?
last week i tested the timing 2 times. I let the engine run 10min. and placed in degrees to 20. to go on safely because went to sharper adjustment is later no problem.
how can this happen?
thx
Hans
hansebanger77
hi
how can that be?
thx
Hans
11-02-2011, 08:39 AM #19
(10-29-2011, 02:39 PM)ritvarsx Take a video!Big Grin
here it is
http://www.youtube.com/watch?v=SdUeRgrKgxM
hansebanger77
here it is
11-02-2011, 08:10 PM #20
That thing sounds nasty!
11-03-2011, 12:37 AM #21
Nice steering wheel. Clacking not so good Sad
11-03-2011, 02:34 AM #22
The loud klack was the injection variable thing in front of the pump. Timing was at 2 deg. Now i used the from 603 unclude vaacum pump and all is ok again Smile
This post was last modified: 11-03-2011, 03:20 AM by hansebanger77.
hansebanger77
11-03-2011, 10:32 AM #23
Driving video! I want to see that car go!
11-03-2011, 11:47 AM #24
Beautiful.
If the 617 ever dies in my w123 i want to put a 606 in it as you did in your w124.
That or a 4bt cummins Big Grin
Beautiful.
majesty78
11-03-2011, 02:26 PM #25
Was machstn Du einmal im Jahr wennst zum Pickerl mußt? *g*
majesty78
11-03-2011, 03:37 PM #26
(11-03-2011, 10:32 AM)Captain America Driving video! I want to see that car go!
at weekend i hope i could make the downpipe and exhaust so i can drive without dieselsmoke inside the car Big Grin
(11-03-2011, 11:47 AM)MFSuper90 Beautiful.
617 never dies hehe Smile
(11-03-2011, 02:26 PM)majesty78 Was machstn Du einmal im Jahr wennst zum Pickerl mußt? *g*
guade Frog Smile in februar is vorbei mit da Hetzt Smile irged a linke muss ja no wo gebm *g*
This post was last modified: 11-03-2011, 03:39 PM by hansebanger77.
hansebanger77
iheartboost
11-03-2011, 04:26 PM #27
man i really need to get my hands on an om606 lol
00 Mustang gt drift car
iheartboost
11-06-2011, 05:11 PM #28
hi!
what about EGT's ?? where is the limit for om 606 ? i testet the max today is 720C celsius at 2.2 bar boost
thanks
hansebanger77
hi!
thanks
iheartboost
11-06-2011, 10:43 PM #29
i think thats great! i believe they said something like shouldn't go over 800c? dont quote me on that though. just trying to help lol.
iheartboost
11-07-2011, 07:59 AM #30
ok thanks!
hansebanger77
ok thanks!
11-21-2011, 05:32 AM #31
3.5" downpipe and straitpipe Smile
its variable for a muffler and pipe.
what universal muffler i can use to make it silent and performance for daly drive? i have a flowmaster but i think it make to much backpressure.
hansebanger77
iheartboost
11-21-2011, 08:32 AM #32
i hear good things about dynomax superturbo mufflers. small back pressure and good sound!
iheartboost
11-21-2011, 01:00 PM #33
thanks i will check this..
currently drive still a pipe without anything Smile
hansebanger77
majesty78
11-21-2011, 02:25 PM #34
Magst vielleicht auch für meinen CDI ne Auspuffanlage schweißen*g*
majesty78
11-22-2011, 06:38 AM #35
würde ich sofort! leider ist der WIG schweisser nicht von mir gewesen Smile aber der macht dir das sicher auch..
hansebanger77
Jtn190D
MERCEDES DIESEL POWER!
192
11-22-2011, 08:55 PM #36
Ist das nicht ein bisschen übertrieben für den Auspuff?
Jtn190D
11-23-2011, 01:13 AM #37
Auf keinen Fall hätte ich mehr platz würde er noch größer sein gg
hansebanger77
11-23-2011, 07:05 AM #38
i think not many people look in drivetrain topics so im sorry i ask here again.
it was a 717 433 bevore and i bougth the same again. now its broken again. every time the 3. gear is damaged... 1. and 2. gear always spinning tires sometimes 3. too. because long diff. if i get grip the 3rd it break.. Sad
any better boxes on mercedes secor?
if it is not absolutely necessary, then I would shift myself. So no automatic.
thx
hansebanger77
thx
bad3gakk
om605 - kkk27 - w124
52
11-25-2011, 04:11 PM #39
I had 3 exhaust studs broke of 3-4mm in the holes, inside the head of my 605.. i put a mig welder inside of the holes, and "buildt" out a nodge, and welded a nut to that... wrenched the nut out Smile
I wount hurt the head, because its aluminium Smile
And wrench while its hot as hell, then its easyest to loosen Smile
bad3gakk
olefejer
11-25-2011, 06:09 PM #40
(11-23-2011, 07:05 AM)hansebanger77 if it is not absolutely necessary, then I would shift myself. So no automatic.
thx
Why no automatic ?
You can shift youself. if using 722.6
I know this is a lousy video i will upload a better one soom :-)
http://www.youtube.com/watch?v=hw2tKdLJvl0
http://www.superturbodiesel.com/std/show...p?tid=3114
This post was last modified: 11-25-2011, 06:11 PM by olefejer.
olefejer
thx
Why no automatic ?
11-26-2011, 12:01 PM #41
Thats verry nice but a lot of work to Do this Projekt.
What about the 6 speed from 230 kompressor ? Or some cdi tranny to shift ? Thanks
hansebanger77
12-06-2011, 03:34 PM #42
Today was on the DynojetSmile
I've found that I only take 7mm and not 7.5mm elements .. Sad
so I was hoping for 350ps and not the 400 +
data and video coming tomorrowSmile
i only make 2 runs. at 2. i adjust the pump only for 1,5 deg later. Smile then i let is so how it is.. done..
im verry happy with the resault because only 7mm. for dailydriving enoughSmile
dont want know what happend at good adjustments on 7.5 Big Grin
ohh and the rpm are little different the engine make 6000 or little more. so you must about 250-300 rpm add on to the the curve. sorry
This post was last modified: 12-07-2011, 06:11 AM by hansebanger77.
.pdf
Scannen0001.pdf
hansebanger77
.pdf
Scannen0001.pdf
ritvarsx
12-07-2011, 07:28 AM #43
Very niceCoolTake acceleration video!
ritvarsx
12-07-2011, 09:19 AM #44
(12-07-2011, 07:28 AM)ritvarsx Very niceCoolTake acceleration video!
http://www.youtube.com/watch?v=6zQyTW-OmTQ
this is the dynorun
it is horrible to drive at full trottle.. the roads are already slippery and it is cold outside...
I'm a bit scared when coming the ass in the 4th gear
if it stops raining I will try a video.
hansebanger77
this is the dynorun
George3soccer
12-07-2011, 11:48 PM #45
Absolutely love the stock look. Congratulations on the numbers
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
95e300dez
95E300td
89
12-11-2011, 12:33 PM #46
Nice job I have heard that the rods would not last long at that power we will see how long yours last. I have a 95 with the hx 35 and know need to invest in upgraded pump. Would really like this kind of power out of mine.
95e300dez
12-11-2011, 02:52 PM #47
(12-07-2011, 11:48 PM)George3soccer Absolutely love the stock look. Congratulations on the numbers
wintertires Smile
Quote:Nice job I have heard that the rods would not last long at that power we will see how long yours last. I have a 95 with the hx 35 and know need to invest in upgraded pump. Would really like this kind of power out of mine.
if i had 7.5mm elements it would be much more. so i hope also the 606 hold longer then the 603´s i had Smile
hansebanger77
wintertires Smile
George3soccer
12-11-2011, 10:57 PM #48
What one of power did you make with your 603 when they went out of commission. Care to share some details about your 603 projects.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
12-12-2011, 01:54 AM #49
Dont know about the Power never was on dyno. Same ip and turbo as now. But too high egt. There is a tread where i post the rebuild of NA and turbo engine and all the damages .
hansebanger77
George3soccer
12-12-2011, 10:55 AM #50
Oh yes, I do remember now totally forgot that was you in those previous posts.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
