STD Maintenance General Part Number
Part Number
Part Number
smoke026
When the Cat's away the mice will play!
94
09-02-2011, 07:45 PM #1
looking for help on getting official part numbers on my OM617.952 for:
1.Oil Separator Return Line (O Rings) top and bottom
(one fits into the actual check valve and the other actual bottom of oil separator itself)
2.Oil Separator Return line (check Valve) at the bottom sump.
Im not really interested in messing with the turbo oil return line as i hear its a real PITA to replace.8)
The turbo O rings are part No.004-997-53-48-M16 and i think they might be the same for both drain tubes?
Thanks,
cheers
This post was last modified: 09-02-2011, 07:48 PM by smoke026.
smoke026
Thanks,
cheers
Kozuka
I'm_Badass
334
09-02-2011, 10:09 PM #2
May I recommend epc?
http://epc.startekinfo.com/epc/
Kozuka
