STD Other Pics and Videos BMW diesel - hunting for idle
HoleshotHolset
09-14-2011, 11:03 PM #1
This thing sounds exactly like a pro-stock pulling tractor. Cool
The starter sounds like it's out of a 2-stroke outboard boat motor... HA!
Beers,
Matt
This post was last modified: 09-14-2011, 11:04 PM by HoleshotHolset.
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
mike-81-240d
more like mike-84-300d now
427
09-15-2011, 12:07 AM #2
My gawd. E30 touring + diesel= win
mike-81-240d
09-19-2011, 02:24 AM #3
Wow, thats Badass!
Wow, thats Badass!
09-19-2011, 07:52 PM #4
Hahahahha. It does sound exactly like a pro stock. I wish they would have moved, i bet its fasttt Big Grin
09-23-2011, 09:46 AM #5
Wow an e30 TD. There was an E28 that floated around on CL for a while here, like between 3 different sellers....
09-23-2011, 02:36 PM #6
hansebanger77
09-24-2011, 09:45 AM #7
favorites/youtube
favorites/youtube
Palmer
10-26-2011, 07:05 AM #8
[youtube]http://www.youtube.com/user/kavelz1[/youtube]
Palmer
George3soccer
10-28-2011, 07:49 PM #9
Absolutely love it. Wish to see it in a manual.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
10-28-2011, 10:13 PM #10
EDH_Performance
11-03-2011, 06:59 AM #11
This is a Danish car, and the owner has wrote something about it here:
http://www.bilgalleri.dk/gal_visbil.aspx...4#comments
From google translate:
330D M57 from E46 year 2002 std 184 bhp.
Upgraded with:
Turbonetics ball bearing turbo 1000Hk (data I keep to myself)
Bosch A series of pump, with high speed cam, 10mm elements and a damn fast gouvenor.
6-3 pipelines.
Nozzle Holders of Volvo truck, which was extended, overflow is moved and fitted large nozzels, REALLY big!
The top is the ported and it is drilled up to the truck nozzle holders otherwise it is std.
Custom made exhaust manifold, made as short as possible.
Custom made intake manifold with large plenunium chamber and connectors for water injection.
2 serious intercoolers.
There is made a Girdle plate under the engine of 25mm, otherwise crankshaft would break.
The oil pump is moved up to the side of the engine, used an ordinary hyd pump, driven by the cam chain.
Holly micro filter oil filter (can be taken apart and checked for shavings)
Most of the bolts in the engine is custom made in the ordinary 12.9 bolts, not stretch bolts!
pistons are machined, both on top and sides.
Dry sump pump, there is a tank of 12 liters below the gearbox.
El-pump for prelube with oil pressure the engine before it is started.
4 "Pressure after intercooler.
3 "Pressure before the intercooler.
And much much more, but allows me to keep a little secret, but I can make a good setup for your car if necessarySmile
Charge pressure is somewhat modest, small 6 bar can I squeeze in!
Transmission:
E46 330 Petrol 6 speed gearbox
Crowe 3 plate clutch
Steel flywheel with replaceable wear plate.
Fixed gear with a very short walk.
Eta Finaldrive (must change to another)
More text coming
Horsepower: Not known yet, since it is not quite doneSmile
Wheels: 17 "OZ Superleggera
Tires: Michelin slicks, but they must be upgraded when there is too little bite into them here.
Suspension: Std so far.
Car: It has the sweetest soundSmile
Styling: exhaust out through the front fender!
Interior: Sparco Pro ADV seat
M-Tach rat
Helbur chrome molly tube
Drag race 20L tank in plastic
4 point harness H
4 pcs trykure
All side windows are pexiglas and is bolted
Otherwise, the total stripped.
Extras: An extra engine should always have in stockSmile
Notes: The car is completely rebuilt to race and running, although it did not finish, we are currently working with that clutch, it is not running optimally. Please write if there are questions, however, gives no engine data or something like thatSmile
This post was last modified: 11-03-2011, 07:06 AM by EDH_Performance.
EDH_Performance
Upgraded with:
6-3 pipelines.
Transmission:
More text coming
M-Tach rat
4 point harness H
4 pcs trykure
11-06-2011, 03:33 PM #12
Thanks for that EHD!
HoleshotHolset
11-10-2011, 12:47 AM #13
Wow - that thing is tweaked and peaked. I hope he takes it down the 1320.
Thanks for doing some digging/translating EDH_Performance!
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
EDH_Performance
12-01-2011, 07:43 PM #14
EDH_Performance
