STD Maintenance General OM605 Timing Marks
OM605 Timing Marks
OM605 Timing Marks
dcm
09-17-2011, 02:20 PM #1
Just looking for some info on the timing marks for a OM605 engine.
I have the crank at 0, the two marks on the cams across from each other so the pin fits it. However the engine locks up when trying the turn it by hand? Car is a 99 C250, everything standard.
Any help appreciated.
Thanks
dcm
Thanks
E300TSC
Turbo-Supercharged
321
09-17-2011, 08:51 PM #2
What did you do to cause you to need to check the timing? Did you remove the cams, injection pump, cam gears?
E300TSC
dcm
09-18-2011, 10:53 AM #3
Injector pump, Can anyone tell me what cylinders should be up along with the 1st at TDC?
dcm
dcm
09-19-2011, 01:48 PM #4
Here’s a picture of the autodata instructions, everything is aligned as the diagram shows.
1st cylinder up when the crank is at 0, the two punch marks together and the pin through the carrier. I can’t turn the engine over by hand, the 5th piston seems to hit the valves.
[Image: CamInstructions.jpg]
dcm
