STD Tuning Drivetrain how to change a rearend
10-02-2011, 09:27 PM #1
so the chart says this is a 2.47 diff
http://www.superturbodiesel.com/std/Thre...=diff+info
1984-1985, 500 SEL, M117.963 5.0L V8, 2.47, 1.3 Liter
http://bloomington.craigslist.org/pts/2608374540.html
What all do I need to do to change the gearing of my rear end?
Just swapping gears or do I need a diff case and axles?
oh, I guess the 2.47 is too short?
http://www.superturbodiesel.com/std/Thre...al+options
This post was last modified: 10-02-2011, 09:40 PM by larsalan.
10-03-2011, 06:44 PM #2
It will be way easier to just swap the whole unit case and all vs changing the gears in the case. Then you wont have to muck about with things like setting and shimming the gears and adjusting lash to make it quiet. Its only 4 bolts into the rear subframe, and then two bolts holding the mount that attaches to the cover.
Fairly easy with the exception of possible rust problems, the studs point up and are held in place by nuts on the top of the subframe, so its a pain in the ass if you have rusted seized nuts on top of the subframe which is not super easy to access.
The axles if they are one piece come out by removing the diff case cover, and pulling the circlips our of the end of the axles, then you can completely remove them.
heres a thread with some pics of the studs-
http://www.superturbodiesel.com/std/Thre...ck-to-life
This post was last modified: 10-03-2011, 06:48 PM by JB3.
10-03-2011, 07:18 PM #3
You'll also have to swap out the input flange from the 3.07 to the 2.47. The 2.47 has a larger flange and to swap it out, there is a special procedure.
mike-81-240d
more like mike-84-300d now
427
10-04-2011, 01:03 AM #4
Plus your speedometer, odometer will be off like none other...
mike-81-240d
10-05-2011, 04:10 PM #5
(10-04-2011, 01:03 AM)mike-81-240d Plus your speedometer, odometer will be off like none other...
Yep. For that rear, you'll need a ratio adapter spliced in your speedo cable to correct the speedo.
10-05-2011, 05:19 PM #6
I don't use a speedo. I just make sure to be a little faster than everyone else Wink
Let johnny law tell me how fast I'm going
dieselboy
Rotatin 5500 times a minute
680
10-05-2011, 11:20 PM #7
or you get the speedo out of the same car.. thats all i did.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
mike-81-240d
427
10-06-2011, 02:02 AM #8
(10-05-2011, 11:20 PM)dieselboy or you get the speedo out of the same car.. thats all i did.
Wont fit correctly in a W123 cluster. It'll look like ass.
mike-81-240d
dieselboy
680
10-06-2011, 02:16 AM #9
Oh. Well. There's an app for that. I had to use it for a few months while my speedo didn't work.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
