STD Other Projects sassparilla_kid's 300D Turbodiesel
  • 3 Vote(s) - 3.33 Average
MTUPower
287
11-09-2011, 05:55 PM #51
(10-30-2011, 08:24 PM)Captain America 1 cup of oil over 20 months is insignificant in my eyes and the stock filter setup is lame. Tongue
That's my setup on my engine... some engine may produce a cup a day....
Why is the stock set up lame? It certainly allows enough air and filters it very well. What else do you want from your air filter???
MTUPower
11-09-2011, 06:11 PM #52
Efff the waste gate.
Save your lunch money and get the manual controller.
- Set it.
- Test run down the street, if it needs adjustment
- Pop the hood
- Adjust
- Leave hood on the safety
- Repeat.
- Close hood when properly adjusted.
That will take 10 min max Big Grin
(11-09-2011, 05:55 PM)MTUPower
More space and the great sound
(11-09-2011, 10:16 AM)iheartboost just disconnect the waste gate FULL BOOST! lol jk
Have you tried that? lol The over boost safety switch will cut fuel HARD! Like slamming on the brakes!
This post was last modified: 11-09-2011, 06:14 PM by Captain America.
- Set it.
- Pop the hood
- Adjust
- Repeat.
11-09-2011, 10:55 PM #53
Overboost? On a 617? I have had no such problem
11-10-2011, 12:59 AM #54
Is the overboost safety switch that sensor lookin thingy sticking out of the manifold towards the back??
11-10-2011, 04:08 AM #55
(11-09-2011, 10:55 PM)MFSuper90 Overboost? On a 617? I have had no such problem
I did, easily when I first installed my controller, which was basically an air compressor pressure reg. Adjusted it backward by accident. Safety switch cut at just about 14-15 psi IIRC
The system works well, therefore I removed it Tongue
(11-10-2011, 12:59 AM)sassparilla_kid Is the overboost safety switch that sensor lookin thingy sticking out of the manifold towards the back??
Yes that is the sensor and it sends a signal to close off the boost going to the ALDA via that switchover valve at the firewall
This post was last modified: 11-10-2011, 04:12 AM by Captain America.
11-10-2011, 06:40 AM #56
Oh well the switchover valve was bypassed by a previous owner sooo I guess thats one less thing I have to remove lol. Has anybody come up with any good uses for the hole the sensor screws into, or is it just best left alone
11-10-2011, 01:17 PM #57
Ahh, i pulled that thing off when i yanked the ALDA off.
I figured if it was hooked into the ALDA i didnt need it anymore Wink
11-11-2011, 05:40 PM #58
You can leave the sensor there if you bypass the switchover valve. Or unplug the sensor and leave the switch over in place
iheartboost
11-11-2011, 08:57 PM #59
lol yea captain thats true. i was figuring he was going to remove it or by pass it like everyone else lol
00 Mustang gt drift car
iheartboost
11-13-2011, 12:23 AM #60
I by passed that hoe!
11-13-2011, 02:07 AM #61
A previous owner by-passed the switchover valve so its already done! Now I just have to stop screwing around and actually get some more work done on the car, maybe after this week since Im gonna have some other stuff goin on that takes precedent Undecided
mike-81-240d
more like mike-84-300d now
427
11-14-2011, 01:51 AM #62
I ran without the wastegate hooked up for at least two months... It maxed out my harbor frieght boost gauge and then some. At least 25 psi. Sounded sooooo amazing on the freeway at 17-23psi in third passing someone. I had so many people looking like WTF is this haha.
Now I have my wastegate actuator line replaced, and I went back to the stock air cleaner, versus the shitty fram 8038.
mike-81-240d
11-14-2011, 01:54 AM #63
How did it perform at that boost?
mike-81-240d
427
11-14-2011, 02:09 AM #64
(11-14-2011, 01:54 AM)Captain America How did it perform at that boost?
Very swell up to 17, anything higher and it was bad news bears... You could hear the little T3 over spinning. Idea
This post was last modified: 11-14-2011, 02:09 AM by mike-81-240d.
mike-81-240d
11-14-2011, 02:10 AM #65
Haha yeah probly like a heat gun too lol
11-14-2011, 04:00 AM #66
So what I take from this is, increase boost until it sounds like the turbo is gonna explode, then back off a little bit lol
iheartboost
11-14-2011, 08:59 AM #67
Lol dont do that. But dam I dident think these baby turbos could get to more than 25 psi
iheartboost
11-14-2011, 04:58 PM #68
It will make that boost. But at that pressure you are both over running it and making an intense amount of heat. Take a look at what 15lbs looks like....
Poor Little 45 trim looks like this @4500 rpm with 15lbs of boost:
[Image: attachment.php?aid=4363]
11-14-2011, 06:54 PM #69
I don't really understand what Im looking at Undecided
aaa
11-14-2011, 07:15 PM #70
The efficiency is around 60%. 60% instead of 74% is 10c hotter.
aaa
iheartboost
11-14-2011, 08:08 PM #71
wow. yea its already falling off the map at 15lbs. its been a while since ive read a compressor map. looks like ill have to do a little refresher once i try to find the turbo for the 603
iheartboost
11-15-2011, 01:41 AM #72
They need to teach useful information like how to read these things in schools, so I understand what the the y-axis and x-axis represent but am still trying to figure out what they have to do with each other and where rpm comes into the equation
aaa
11-15-2011, 05:23 AM #73
RPM and boost and combined into the x-axis. Higher rpm = more airflow, higher boost = more airflow. The y is boost.
aaa
11-15-2011, 03:51 PM #74
Alright that makes a little more sense
11-15-2011, 05:10 PM #75
Basically the more boost and RPM you have the red dot moves up and to the right....
The curved lines that start high on the left and go down to the right are turbo RPM
The left side is SURGE (when more air volume is being made than can be taken in by the engine IIRC)
The right side is CHOKE:
"When a turbocharger is run deep into choke, turbo speeds increase dramatically while compressor efficiency plunges (very high compressor outlet temps). Additionally, the turbo's durability is compromised by the resulting high thrust loads."
You can plug boost and RPM into the calc to see where your turbo is operating...
http://www.not2fast.com/turbo/glossary/t...utyCycle=0
This post was last modified: 11-15-2011, 05:15 PM by Captain America.
iheartboost
11-15-2011, 06:34 PM #76
(11-15-2011, 01:41 AM)sassparilla_kid They need to teach useful information like how to read these things in schools, so I understand what the the y-axis and x-axis represent but am still trying to figure out what they have to do with each other and where rpm comes into the equation
here ya go friend http://www.superturbodiesel.com/std/show...p?tid=3131
iheartboost
12-01-2011, 12:40 AM #77
Does anybody know the diameter of the line going to the wastegate? The manual boost controller people make you choose between 1/4" and 3/16" on their website
iheartboost
12-01-2011, 08:46 AM #78
hmm... good question. lol.
iheartboost
12-01-2011, 03:39 PM #79
Line size is 3/8" going to the wastegate.
12-01-2011, 05:33 PM #80
I guess I should get the 1/4" one then
12-01-2011, 11:36 PM #81
Which part are they referring to for the size choice? Link?
12-02-2011, 05:21 PM #82
(12-01-2011, 11:36 PM)Captain America Which part are they referring to for the size choice? Link?
The hose barb size is available in two different sizes. I guess it doesn't really matter which one I get if they dont work I can just go buy different sized barbs
http://nxsmotorsports.com/content/manual...er-classic
12-05-2011, 01:37 AM #83
Ahhh, Guess it wont matter because you need 3/8" barbs anyway...
01-10-2012, 03:30 AM #84
FINALLY!!! Ordered turbo and exhaust gaskets along with a new thermostat, from autohausaz, hopefully they arrive in the next week so I can finish this project lol, so I guess I need to get an egt guage and install on the non-egr manifold before installing in the car, and then I can hopefully move on to other projects.... hmmmm Im having trouble deciding, A/W IC, or water/meth/war emergency power/ whatever you want to call it, or maybe something else?? Suggestions folks?
Also if its possible I guess this should probably be in the "Projects" section of the forum but Im unsure about how to do that
This post was last modified: 01-10-2012, 03:32 AM by sassparilla_kid.
01-11-2012, 01:16 AM #85
Nuclear Reactor FOR THE WIN! Cool
01-11-2012, 02:12 AM #86
That would be bitchin!!! Imagine the torque lol
aaa
01-11-2012, 05:09 PM #87
(01-10-2012, 03:30 AM)sassparilla_kid Also if its possible I guess this should probably be in the "Projects" section of the forum but Im unsure about how to do that
Do you want me to rename it too?
aaa
01-12-2012, 03:14 AM #88
(01-11-2012, 05:09 PM)aaa
Sure could you just name it "sassparilla_kid's 300D Turbodiesel" or something along those lines? I think that would work
Thanks!
Thanks!
01-12-2012, 10:44 PM #89
TURBO -Biiiiiiiiiiiiiiiiiiiiiiitch!
[Image: tumblr_lx2ad2c0ty1qkmmtwo1_500.jpg]
This post was last modified: 01-12-2012, 10:44 PM by Captain America.
01-12-2012, 11:10 PM #90
^^^^^^ like X 1000 lol
Also I gots another question, what is the best bang for the buck turbo wise? Would it be a new fancy turbo or getting the garrett rebuilt or something along those lines?
This post was last modified: 01-12-2012, 11:12 PM by sassparilla_kid.
01-13-2012, 01:22 AM #91
I just got mine rebuilt. I guess it depends on your goals...
01-13-2012, 01:32 AM #92
My goal is to be able to be able to merge with traffic, possibly going uphill while doing so
01-14-2012, 01:17 AM #93
Cost me $400 to go from a blown out Garret T3, 45 trim to a 60 trim with a brand new CHRA and new turbine wheel. Only old parts used were the turbine and compressor housings. Now I can safely run up to 24psi @ 5000 RPM and still be 70% efficient, whereas my 45 trim would have exploded 3 times over
http://www.superturbodiesel.com/std/show...5#pid28225
01-14-2012, 01:36 AM #94
Hmm do you actually run it at 24psi? And I thought 13 or so was the max that could be run efficiently without extensive pump work/tuning, without just producing more heat
Oh and I got my manifold and turbo gaskets today from autohausaz along with a new thermostat so in the next week or two I hope to swap in the non-egr manifolds and flush coolant and replace thermostat and upper radiator hose. Just need to clean the new manifolds off and obtain an egt gauge/sensor and install before hand and then I can move on to the next project
This post was last modified: 01-14-2012, 01:40 AM by sassparilla_kid.
01-14-2012, 02:58 AM #95
No I dont but have that option available. at 14psi with stock turbo, youre under 65% efficiency so yes a lot of heat is being made... IP tuning will not change the compressor map. The 45 trim works harder with higher pressure no matter what you do to the IP.
01-14-2012, 03:03 PM #96
So approximately what is the ideal pressure for stock turbo with stock IP (ALDA maxxed) for best power/efficiency combination?
01-18-2012, 02:01 AM #97
I would say 13, 14 max
01-18-2012, 02:59 AM #98
Yeah that's about where I was planning on putting it
01-19-2012, 02:28 AM #99
after that turbo charger go boom! ....Not literally, but you will be over running it if you go past 14lbs.
Ryan after he cranks the boost up...
Seconds Later
lol. I have too much fun
This post was last modified: 01-19-2012, 02:45 AM by Captain America.
Seconds Later
01-19-2012, 04:33 AM #100
HAAAHAHAHAHAAHAAHAHAHAA!!!!!!!!!!! That would be awesome!!!!
Except maybe not the dieing in the explosion part Tongue
Also finally got around to ordering the boost controller, tomorrow I'll probably pick up egt gauge/sensor
This post was last modified: 01-19-2012, 04:53 AM by sassparilla_kid.
 9 Guest(s)
 9 Guest(s)
