STD Tuning Engine 7mm pumpelement to my mercedes 300D -87
countach
04-08-2009, 03:53 PM #1
i have a 300D -87 6cyl.(not turbo pump) and wonder if anyone now where i can buy 7mm pumpelement to this pump? like Mynä-Diesel 7mm elements? and price?
//Thanks...
countach
//Thanks...
tomnik
04-08-2009, 11:47 PM #2
(04-08-2009, 03:53 PM)countach i have a 300D -87 6cyl.(not turbo pump) and wonder if anyone now where i can buy 7mm pumpelement to this pump? like Mynä-Diesel 7mm elements? and price?
//Thanks...
the "Myna" 7mm are too large (or better supply too much fuel) for the n/a engine.
Tom
tomnik
//Thanks...
Tom
countach
04-14-2009, 04:14 AM #3
(04-08-2009, 11:47 PM)tomnik
//Thanks...
i mean at the injector pump is not a turbo pump, but its a big turbo on the engine. so i must have more fuel from the orginal pump. anyone som now where i can buy 7mm element to this pump?
Tom
countach
//Thanks...
Tom
04-14-2009, 09:34 AM #4
You might be able to find the turbo pump for about the same price...
tomnik
04-14-2009, 09:56 AM #5
(04-14-2009, 09:34 AM)winmutt You might be able to find the turbo pump for about the same price...
Turbo IP and 7mm elements makes sense.
Just the 7 mm elements in the non turbo IP on an engine with big turbo will cause smoke at low range or will not give you max power in high range when the IP is adjusted for no smoke in low range.
The elements are 45 EURO/each.
Is the engine originally n/a?
The reason I ask is I have turbo IPs but with pneumatic idle control. This is a unique version and does not fit to turbo passenger cars because of the pneumatic idle control (where this is electromagnetic).
NEW! 300 EUR.
Tom
tomnik
NEW! 300 EUR.
Tom
