STD Tuning Engine 87 190DT Lift Pump Pressure
TurboWalt
12-08-2011, 03:37 PM #1
Does anyone know what the output pressure range is for a 87 190DT?
TIA, Walt
TurboWalt
TIA, Walt
12-09-2011, 01:36 AM #2
Normal is 0.8 - 0.9 bar. There are rep kits and longer springs and valves. I drive 3 bar for superturbo with w123 300d liftpump. If u have bigger Elements i make Sense to tune the liftpump.
hansebanger77
tinchariot
12-11-2011, 12:31 AM #3
(12-09-2011, 01:36 AM)hansebanger77 Normal is 0.8 - 0.9 bar. There are rep kits and longer springs and valves. I drive 3 bar for superturbo with w123 300d liftpump. If u have bigger Elements i make Sense to tune the liftpump.
Where might one find a rep kits and longer springs and valves?
I'm definitely interested!
Anyone using a prepump below the tank?
Just picked up an Airtex E8845 pump 17-30 Lbs rotary-vain type it might be noisy, been using a diaphragm pump rated @ 9-14 Lbs with good results.
tinchariot
12-11-2011, 03:03 PM #4
dont know about the electric pumps in dieselcars.. hav one in my petrol for mor power.
i use w123 with handpump. and others spring and pressure valve. its nice difference to stock.
found it in german shop tey build up benz for vegetable oil.
https://www.dieselcoupe.de/index.php?pro...8046468012&
https://www.dieselcoupe.de/index.php?produkt=05801072&
best regards
hansebanger77
best regards
 3 Guest(s)
 3 Guest(s)
