STD Tuning Engine The build starts, 320 cdi with stand alone ecu, twin turbo
diesel2fast4u
12-20-2011, 03:13 PM #1
teaser pics, all details of the build will be posted...
[Image: 3.JPG]
[Image: 1.JPG]
[Image: OM613.jpg]
[Image: 2.JPG]
Grand cherokee WK (OM642)
diesel2fast4u
[Image: 3.JPG]
[Image: 1.JPG]
[Image: OM613.jpg]
[Image: 2.JPG]
Palmer
12-20-2011, 03:50 PM #2
Is that turbo of a FH12 Globetrotter by any chance? lol
Im looking forward to this Big Grin
Palmer
majesty78
12-21-2011, 08:54 AM #3
I guess its a gtb2056vk from volvo application...
majesty78
angryspartan
12-21-2011, 02:10 PM #4
this is what its all about! cant wait to see this build!
Obsidian black 2001 E320 cdi, 18inch AMG wheels, waiting to be modified!Smile
angryspartan
diesel2fast4u
12-21-2011, 03:08 PM #5
Yes, it's the gtb 2056 vk from volvo.
Powergoal is 400 HP, so 2 should do with acceptable spoolup
We start with standard compression ratio
diesel2fast4u
diesel2fast4u
12-23-2011, 01:51 PM #6
first header design
[Image: Schermafbeelding%2525202011-12-22%252520....29.37.png]
[Image: Schermafbeelding%2525202011-12-22%252520....29.12.png]
This post was last modified: 12-23-2011, 01:52 PM by diesel2fast4u.
diesel2fast4u
first header design
olefejer
12-23-2011, 02:30 PM #7
That's a Cool build you have going on there, witch controller are you going to use BOSCH ?
olefejer
diesel2fast4u
12-25-2011, 02:04 PM #8
no, we are using our own controller, I'll post pics tomorrow.
final manifold design :
[Image: Schermafbeelding%2525202011-12-25%252520....06.09.png]
[Image: Schermafbeelding%2525202011-12-25%252520....08.21.png]
This post was last modified: 12-25-2011, 02:11 PM by diesel2fast4u.
diesel2fast4u
diesel2fast4u
12-27-2011, 08:08 AM #9
our controller
[Image: 2.JPG]
[Image: 3.JPG]
diesel2fast4u
our controller
[Image: 2.JPG]
[Image: 3.JPG]
INC
12-27-2011, 12:19 PM #10
Please post details and price for this controler.
It`s NIRA?
INC
It`s NIRA?
diesel2fast4u
12-27-2011, 12:52 PM #11
(12-27-2011, 12:19 PM)INC Please post details and price for this controler.
It`s NIRA?
No, develloped & produced in Belgium : It manages as well common rail piezo engines, common rail inductive engines, and pump injectors or UIS injectors engines up to 6 cilinders.
People who want details pm me your email
Stainless steel came in for the manifolds, welding starts thursday
[Image: Schermafbeelding%2525202011-12-26%252520....32.52.png]
This post was last modified: 12-27-2011, 12:54 PM by diesel2fast4u.
diesel2fast4u
It`s NIRA?
majesty78
12-27-2011, 02:52 PM #12
Shall this engine go into an W210 engine bay again?
majesty78
diesel2fast4u
12-27-2011, 05:41 PM #13
(12-27-2011, 02:52 PM)majesty78 Shall this engine go into an W210 engine bay again?
No, I am building 2 that are going in a boat Smile
Why?
diesel2fast4u
Why?
majesty78
12-27-2011, 06:05 PM #14
Ok that's what confused me because with those exhaust manifolds it would cause clearence issues in engine bay I guess....
majesty78
diesel2fast4u
12-28-2011, 05:31 PM #15
(12-27-2011, 06:05 PM)majesty78 Ok that's what confused me because with those exhaust manifolds it would cause clearence issues in engine bay I guess....
Should be interesting to try, if you want I send you measurements
diesel2fast4u
diesel2fast4u
01-09-2012, 01:18 PM #16
flanges
[Image: IMAGE_A261C084-F66B-4614-8894-CED62C61D7CC.JPG]
Almost done Smile
[Image: IMAGE_CAC1E7B9-D090-44F8-85E6-5CC7213CDFD6.JPG]
Intercooler
[Image: IMAGE_29567357-A900-40AB-87F4-B23A50905B1A.JPG]
Anyone has used these china intercoolers? I want to use 2 of them on each engine...
They any good?
diesel2fast4u
flanges
Almost done Smile
Intercooler
They any good?
01-10-2012, 01:01 AM #17
(01-09-2012, 01:18 PM)diesel2fast4u Intercooler
They any good?
I have one
[Image: attachment.php?aid=4896]
[Image: attachment.php?aid=4897]
They any good?
I have one
HughF_UK
01-10-2012, 07:42 AM #18
We use those coolers on a pair of marinised isuzu 1.7 turbo diesels - worked very well so far for 2 seasons...
HughF_UK
Alcaid
01-10-2012, 09:17 AM #19
Small mistake earlier in this thread, this is not a GTB2056VK turbo, it's the GTB2056VL with a lower trim compressor wheel compared to the VKs.
Alcaid
diesel2fast4u
01-10-2012, 11:16 AM #20
@ Hugh , I wonder if they are big enough for +400 HP, otherwise I would use 2 on each engine...
@ Alcaid , you are right & they are water cooled
diesel2fast4u
diesel2fast4u
01-11-2012, 02:52 AM #21
injector driver & ECU
[Image: IMAGE_8517063F-B1DF-4271-A864-22E7626EE054.JPG]
diesel2fast4u
antonmies
Go MPR
59
01-11-2012, 07:44 AM #22
one ic manufacturer in china told me that those w/a intercoolers couldn't take seawater...I guess it's the brazing material they use in manufacturing or he was being cautious.
antonmies
yankneck696
395
01-11-2012, 05:08 PM #23
(01-11-2012, 07:44 AM)antonmies one ic manufacturer in china told me that those w/a intercoolers couldn't take seawater...I guess it's the brazing material they use in manufacturing or he was being cautious.
The saltwater MUST be run through a brass/bronze heat exchanger to cool antifreeze/water mixture. There MUST also be zinc sacrificial anodes in the saltwater portion. Then, you can use the coolant to cool the charge air. If used in fresh water, you can "get by" with this setup, but MUST fully examine the intercoler EACH time after it is run !!! That would necessitate an inspection plate & pressure checking/vacuum checking each outing. There are many marine intercoolers that are designed for marine/saltwater use that remove the loss of 2 transfer mediums.
When you use salt water (or anything but distilled water to a point) you WILL have electrolysis between dissimilar metals. That will corrode & eventually lead to porosity of the intercooler & eventual engine damage.
I work on marine engines for a living & see all too commonly that when the Zinc annodes are not replaced on a yearly basis that failure is a certainty.
If I were to use a W/A intercooler, I would surely use a couple zinc sacrificial anodes along with antifreeze/distilled water to help ensure longevity. Also, replacing the sacrificial anodes (even at West Marine prices of under $10.00) on a 6 month schedule (unless proven to be over 75% remaining after said time, then up to a year) MANDATORY for longevity.
Any questions, feel free to ask or PM me...
Ed
yankneck696
Ed
diesel2fast4u
01-12-2012, 06:17 PM #24
only messed up 2 90° before getting it right
I don't like the metal work Sad
2morrow more cutting & welding ...
[Image: IMAGE_589D1184-A615-4B00-BFD6-F6D220D99239.JPG]
[Image: IMAGE_B9B5FBFD-3BFC-4EAB-8D0F-537B386D452E.JPG]
diesel2fast4u
diesel2fast4u
01-14-2012, 06:33 AM #25
it always looks easy ...
[Image: IMAGE_4ECD5E45-447B-4652-8823-7C56B2FD5587.JPG]
diesel2fast4u
diesel2fast4u
01-16-2012, 04:32 PM #26
manifold welding after alot of cutting Sad
[Image: IMAGE_DB051D0A-8566-42D6-9CE1-177CBB57E0F6.JPG]
[Image: IMAGE_608E1CD9-370C-4E42-A311-3BA3AAC1892C.JPG]
[Image: IMAGE_8CBAD8CB-01E6-4BCF-B053-F5EF0659C538.JPG]
[Image: IMAGE_4C158912-9EB9-44A4-852C-B0BFDA28DCE1.JPG]
This post was last modified: 01-16-2012, 04:33 PM by diesel2fast4u.
diesel2fast4u
diesel2fast4u
01-16-2012, 07:01 PM #27
Senders
Map
2 x EGT
2 x EMP
Lambda
[Image: IMAGE_34347185-2C78-4A32-9A8E-47545CAB6D25.JPG]
Back turbo manifold
[Image: IMAGE_E7F11F02-2B15-4118-9A9D-387A5D279CE9.JPG]
diesel2fast4u
Senders
Map
2 x EGT
2 x EMP
Lambda
Back turbo manifold
diesel2fast4u
01-17-2012, 01:23 PM #28
Started the intake manifold, EGR Confused
Cut the original manifold & took out the swirl valves
[Image: IMAGE_AFA611FF-EF92-4292-9BDE-E5EABA20EF97.JPG]
[Image: IMAGE_33852972-ED5D-464C-9639-E1EBA5506A67.JPG]
This post was last modified: 01-17-2012, 01:24 PM by diesel2fast4u.
diesel2fast4u
diesel2fast4u
01-18-2012, 09:58 AM #29
I am not quitting my day job, but getting the hang of it Smile
[Image: IMAGE_90BD8B4C-A3E7-4D58-A476-BC574A35BC5F.JPG]
diesel2fast4u
01-19-2012, 02:47 AM #30
Looking much better! Smile
diesel2fast4u
01-19-2012, 12:53 PM #31
intercooler design
[Image: Schermafbeelding%2525202012-01-16%252520....16.34.png]
have some nice info on cdi injectors
1350bar Standard OM 613 injectors tested at 1600bar:
2000 injections 1100 ms = 117gr
With AMG nozzle at 1600 bar:
2000 injections 1100 ms = 204gr Smile Smile
This post was last modified: 01-19-2012, 12:56 PM by diesel2fast4u.
diesel2fast4u
intercooler design
majesty78
01-20-2012, 12:53 AM #32
With 90mg/stroke you get about 100Nm per cylinder ;-)
majesty78
diesel2fast4u
01-20-2012, 11:42 AM #33
[quote='majesty78' pid='37727' dateline='1327038790']
Well... we decided to put the nozzles in & see what is going to happin on the dyno....
diesel2fast4u
diesel2fast4u
01-21-2012, 12:49 PM #34
intake
[Image: IMAGE_8E13D870-240C-4EE6-A8F9-834C0EDCC52D.JPG]
[Image: IMAGE_2452BFC4-7F70-4574-B38B-2B5CDEA2ABF5.JPG]
diesel2fast4u
intake
Rub87
01-21-2012, 01:48 PM #35
Looking good.. friend of me who works regulary on jetskis also said that if the anode if missing its a matter of days in seawater.. also for non salt water he said it would be mandatory with these alu cores..
Rub87
diesel2fast4u
01-24-2012, 05:54 PM #36
new vs old high pressure pump
[Image: 12%25252019%25253A53%25253A56.jpg]
diesel2fast4u
Rub87
01-25-2012, 04:57 AM #37
I've did some reading about the mods done to these pump, and it seems the US companies are asking up to 1000$ for some really basic mods, which usually are ported feedpump and metering valve.. I didnt found a proof they use bigger bore plunjers or difference E-shaft for more lift
I think this is the L110 pump, meaning leftturning 1100mm³ theoretical displacement per pump revolution
Rub87
majesty78
01-25-2012, 05:44 AM #38
Hy Ruben, nice to meet you over here :-)
majesty78
Rub87
01-25-2012, 07:31 AM #39
Hi Alex, also nice to meet you over here, how's your new compressorwheel doing?
Rub87
zeeman
01-29-2012, 12:57 AM #40
I am using the same engine a 2006 in a Street Rod project and need a stand alone computer to make it work, were did you gets yours? I also have a flywheel and bellhousing if you still need them. Is there anyway to use the stock computer?
zeeman
diesel2fast4u
01-29-2012, 03:50 AM #41
(01-29-2012, 12:57 AM)zeeman I am using the same engine a 2006 in a Street Rod project and need a stand alone computer to make it work, were did you gets yours? I also have a flywheel and bellhousing if you still need them. Is there anyway to use the stock computer?
Stock computer is in my opinion impossible because you would need a bosch wizard to turn off all things in the ECU you don't use in your car that will put the engine in Limp mode.
With EDC15 it was doable but not with EDC16, on top of that you can't run electronic VNT or VGT turbo's with the EDC15.
Pm me your email address
diesel2fast4u
diesel2fast4u
01-30-2012, 02:52 PM #42
did some work today
[Image: IMAGE_E7741FC7-FA44-492D-B9D2-7D837E21ADC3.JPG]
Cut the intercoolers (thanks Joe)
[Image: IMAGE_FAADB5B8-CAF2-4ADB-B94E-59C7D521F04C.JPG]
Core
[Image: IMAGE_9165E456-F26F-441F-9666-F1E59ACD332E.JPG]
Welded :
[Image: IMAGE_1BEEEFD5-A94E-4C79-BBB3-26A7A2A69678.JPG]
Intake ready for welding :
[Image: IMAGE_BCB97801-994E-42C6-B4F8-15AF93B82692.JPG]
Turbo mock up
[Image: IMAGE_0E02194C-A7C7-40C9-B01A-616B0D5DEF27.JPG]
[Image: IMAGE_8270B2D3-C5D8-4A2A-9729-8DFED17E604E.JPG]
[Image: IMAGE_9771320C-63D9-4B2D-97BC-A1504E67C5FA.JPG]
diesel2fast4u
did some work today
Core
Welded :
Turbo mock up
toomanydiesels
02-11-2012, 11:00 AM #43
I really hope someone corrects me on this, but I absolutely have to mention something.
What a great project. What wonderful results.
I did, however, notice something that set me wondering.
When building headers, the weld really matters and more welding is generally worse than less welding because of fatigue cracking.
I have always, ALWAYS seen, and been told, a header is welded on the gasket side of the flange. It is never welded on both sides of the flange. The single weld on the gasket side (against the engine block) is then dressed down smooth and the outboard side of the flange is left unwelded.
Those that do weld the outboard side of the flange invariably have a very good looking and stout header -- except it soon cracks miserably from fatigue and vibration.
Now, does that apply here? I can't say. But it does apply in gassers of just about every size.
And I'm certainly not trying to stall your wonderful project. And I'm not saying you will experience abysmal failures. And I'm not saying to yank all that apart and rebuild it, Heavens No! Everything might be just fine.
But if you end up faced with a mysterious cracking problem, you might look into that because it seems to always happen.
toomanydiesels
Boatbuilder
MSc
40
04-23-2012, 09:36 AM #44
Hi, nice project. I have two similar engines in my boat. next friday in the sea for final testing. Runs with Bravo III and watercooled exhaust
manifold, watercooled intercooler, oil cooler, and power steering oil cooler . Run with a modified Bosch original ECU. Lot of work avoiding limp mode , but ok now.
I am also running with a heavy flywheel.
Your project are with exhaust direct into the two turboes and dry exhaust after turboes. In my opinion that should create a lot of heat
in the engine room and where are you routing the seawater outlet ?
These 6 cyl engine runs very smooth and well balanced.
Boatbuilder
Theturbodave
05-17-2012, 08:47 AM #45
Good work man. I had one question on the twin turbo manifolds i have done you have to run a balance tube between manifold or a surge will happen between the turbo due to firing order of the cylinder (2 cylinders fire in one manifold while other one only one fires and the it switchs). Is there something different on the diesel engine. This happens at light loads part throttle. Just asking, keep up the good work u have some good skills.
This post was last modified: 05-17-2012, 08:49 AM by Theturbodave.
Theturbodave
Lucian189
09-05-2014, 01:54 PM #46
Awsome! any updates??
Lucian189
