EDH_Performance
Norwegian OM606 build
Hi guys,
I have posted a few photos of my project here in different treads.
But here I will post all my photos of my high hp OM606 build.
The engine started out as an .910 engine with a stock 5.5mm M pump, and some tweaking was done too it along the way.
The car I started with was an MB w201 2.0D 4-speed 1993 mod.
I drove it a while with the stock Om606.910 engine, it worked very well, but 136hp wasn`t enough
I fitted an Eaton m90 compressor and tuned the stock 5.5mm pump to max, and got out around 170ish hp (dyno papers will come)
This worked very well, and drove with this mod for almost 6monts!
But 170+hp wasn`t enough
So I bought an shorblock OM606.962 from Erling66 on this forum. This engine had 2 badly bent rods, and 1 minor bent rod. So i bought 6 H-profile rods from Sten Parner Motor form sweden. All gaskets, pistonrings+++ was bought. So lets get on with the pictures
Pictures from the first build:
The setup now is turbo+compressor, and a 7.5mm M-Pump built by Dieselmeken.
Pictures from current build
Who said turbocharging was easy????
N/A vs Custom turbo manifold
All pistons, rods where weight balanced to +-0.05grams
Piston rings was also gapped to right measurment.
![[Image: IMG_3358.jpg]](http://i3.photobucket.com/albums/y66/volvoturbopower/W201/IMG_3358.jpg)
Custom flywheel made from a stock om604 motor, with an 6 puck sinterdisk and Sachs racing Bmw e34 preassure plate.
![[Image: IMG_3319.jpg]](http://i3.photobucket.com/albums/y66/volvoturbopower/W201/IMG_3319.jpg)
[/align]
Main-bearing girdle was made...
In these days the head is ported! A lot can be done to the channels, speacily the exhaust side
Pictures will come
Stay tuned
12-25-2011, 09:43 PM |
bad3gakk
om605 - kkk27 - w124
RE: Norwegian OM606 build
A buddy of mine ran his 606 with hx40 (19ccm turbine) and a 3" downpipe.. that created too much backpressure.. he only got 2,2bars manifoil pressure.. another buddie of mine ran his 603 with 0,5mm smaller pump elements, a little smaller turbine, and 4" downpipe and exhaust, and got 3,5+ bars...
You might concider building a bigger DP... i got myself 2m of straight 4", and 2 mandrel bendt 90's for christmas  it turned out to be a beatiful peice of metal in the end, and will help my 605 sing beautiful serenades
12-27-2011, 11:47 PM |
EDH_Performance
(12-27-2011, 11:47 PM)bad3gakk Wrote: A buddy of mine ran his 606 with hx40 (19ccm turbine) and a 3" downpipe.. that created too much backpressure.. he only got 2,2bars manifoil pressure.. another buddie of mine ran his 603 with 0,5mm smaller pump elements, a little smaller turbine, and 4" downpipe and exhaust, and got 3,5+ bars...
You might concider building a bigger DP... i got myself 2m of straight 4", and 2 mandrel bendt 90's for christmas it turned out to be a beatiful peice of metal in the end, and will help my 605 sing beautiful serenades  Sounds nice, how many hp did you buddy`s OM606 make?
It is plenty room for a bigger DP  But i will meausure backpreassure first...
(12-28-2011, 05:30 AM)jeemu Wrote: Hope those rods hold up. Piston+pin is wery heavy
On my 605 i had 2.7-3.2bar boost and back pressure with 3.5" DP was 1.8-2.2bar
I was a bit afraid for that to happen...The piston are way more heavier than the N/A piston  But the rod are strong the other way, so we have to see if it holds together... If it breaks, then I will buy some new stock rods!
12-28-2011, 06:38 AM |
EDH_Performance
12-28-2011, 06:03 PM |
EDH_Performance
12-28-2011, 08:23 PM |
EDH_Performance
01-18-2012, 01:06 PM |
EDH_Performance
01-18-2012, 05:06 PM |
EDH_Performance
01-19-2012, 01:54 PM |
erling66
SuperDieselVan
(This post was last modified: 01-19-2012, 04:02 PM by erling66.)
01-19-2012, 03:36 PM |
EDH_Performance
01-26-2012, 07:29 PM |
EDH_Performance
01-29-2012, 10:13 AM |
majesty78
I like :-)
But you should maybe use some beefier boost hose clamps....
Mercedes Benz W210 E-Class 320CDI, lowered 2.5", 18" AMG wheels, Decat, EGR removed, Tumble flaps removed, C30 AMG injectors, 400kpa MAP, Custom GT2566XTV turbo, SW tweaked to 300+hp/750Nm
(This post was last modified: 01-29-2012, 02:26 PM by majesty78.)
01-29-2012, 02:22 PM |
Rub87
Should have come like that from Stuttgart, looking very nice.. do you use the gate after the intercooler to bypass mr Eaton once the turbo is spooled?
01-30-2012, 10:45 AM |
EDH_Performance
(01-30-2012, 08:51 AM)Booster Wrote: Nice build! Do you have any more details on your exhaust manifold? Images of how you made the collector on the turbo flange etc? also the flange on the head side? whats your end power goal? cheers!
Hi,
I have some more photos of it, if you want to see?
But I made the collector along the way, just started with two runners and mended the others into them. And after that I welded some inside and ported the collector to a smooth finish
The turbo flange made I myself, the Head flange comes from klracing.se.
The power goal is high, I have seen 614hp on stock engines(upgraded valvesprings). And as I also will fit special high duration cams and stiff springs, who knows? I WANT BIG POWER
I will also get my hands on a BMW 330D/530D transmission, these can handle almost 1000nm (does the BMW guys say)
(01-30-2012, 10:45 AM)Rub87 Wrote: Should have come like that from Stuttgart, looking very nice.. do you use the gate after the intercooler to bypass mr Eaton once the turbo is spooled? Haha, agree! I looks better with the headcover on
No, I haven`t made the inlet in the intake for it yet! But I will do that as soon as i get the 7.5mm pump  I dont want to take the intake off two times
01-30-2012, 11:13 AM |
Rub87
Maybe one small remark about the plenum. the big planar top surface welded at the corner under 90° will be prone to crakcing because the big surface will vibrate, and then at the 90° edge the weld will start crack from the inside.. I found out the hard way.. its better to bend the 90° on the plate and then weld in a planar section, this way the weld is only loaded on tension.. or you can also weld some studs in the big flat plate to prevent it from flexing
offcourse I see you used some thick aluminum, which also helps.. I used 3mm, but was only running around 1.7 bar, static tested with 6 bar was no problem, but the pulsation inside the plenum made it fail over time
01-30-2012, 11:26 AM |
EDH_Performance
(01-30-2012, 11:26 AM)Rub87 Wrote: Maybe one small remark about the plenum. the big planar top surface welded at the corner under 90° will be prone to crakcing because the big surface will vibrate, and then at the 90° edge the weld will start crack from the inside.. I found out the hard way.. its better to bend the 90° on the plate and then weld in a planar section, this way the weld is only loaded on tension.. or you can also weld some studs in the big flat plate to prevent it from flexing
I see, let`s hope it won`t crack! But it is 10mm alu, so it is pretty strong!
01-30-2012, 11:40 AM |
Booster
(01-30-2012, 11:13 AM)EDH_Performance Wrote: (01-30-2012, 08:51 AM)Booster Wrote: Nice build! Do you have any more details on your exhaust manifold? Images of how you made the collector on the turbo flange etc? also the flange on the head side? whats your end power goal? cheers!
Hi,
Yes please I would love to see as many as possible...
cheers
01-30-2012, 11:59 AM |
EDH_Performance
01-30-2012, 12:13 PM |
EDH_Performance
(01-30-2012, 01:36 PM)erling66 Wrote: I am very impressed with your fast progress, maybe there is nothing else to do in Arendal in the winter than working?
So tell us, how does the engine feel? old engine with Eaton vs new engine with Eaton vs new engine with Eaton and turbo?
Old engine vs Mr. Eaton: Very good, powerful engine with N/A characteristics. No "turbo" lag....Had 0.2 bar on idle and 0.9 at around 3000 and up. It was a bit smokey (blue) on cold starts and idle. A bit ruff at idle when cold. And the engine was a bit "choky" at the top of the rpm. It is a good "cheap" way to do it...Stick a Eaton m90 or turbo, and tune the stock 5.5mm pump, and you get around 170-180hp. The car uses around 0.7ltr/10km on higway driving
New engine vs Mr. Eaton: Same as above, but no smoke at coldstarts, smooth idle. A bit more powerful on the top end (the porting helped!)
New engine vs Turbo+Mr. Eaton: Way more power on higher rpm! The intake preassure comes much faster! The exhaust sound is completly different, much better  So i can`t wait to get my 7.5mm elements!!!!
01-31-2012, 09:27 AM |
huseyin55amg
awesome stuff , well done ...!!
02-08-2012, 12:04 AM |
