STD Other Projects Norwegian OM606 build
  • 7 Vote(s) - 4.43 Average
Pages (7): Previous 1 2 3 4 5 7 Next
George3soccer
04-09-2012, 10:01 AM #51
I love it.
So you are running 1.9 bar for turbo, what is the supercharger running on.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
I love it.
Mb 2004 w203 C230k
EDH_Performance
04-09-2012, 10:12 AM #52
(04-09-2012, 10:01 AM)George3soccer I love it.
Supercharger gives 0.5 bar, and then the turbo takes overSmile
EDH_Performance
dieselmeken
04-09-2012, 11:21 AM #53
This is really nice, Thanks alot for the videocliip, i`ll take it to my dieselmeken facebooksite if its OK with you.
It seems to have a litttle bit of overfuelling, but as you wrote, its easy to fix now that you have a gearbox that is OK.
Also, the fact that you dont have any ALDA on the pump, It can bee seen in the cloud of smoke before boost is rised. Nice job with engine / gearbox.
Come back when you got max out of the pump and it not is enough and you need moore, then I fix it.
dieselmeken
EDH_Performance
04-09-2012, 11:29 AM #54
(04-09-2012, 11:21 AM)dieselmeken This is really nice, Thanks alot for the videocliip, i`ll take it to my dieselmeken facebooksite if its OK with you.
Put it on your facebook siteWink
Yes, the swedish gearbox and universal sinterplate works very goodSmile
I will come back with more videos after i`ve turned up the boost, and adjusted the injectiontime on the pump...Can hardly hear any dieselknockingSmile
I will also dyno test it with this series 1 elementsWink
Must say the service from you gøran is extraordinary! VERY PLEASEDBig Grin
EDH_Performance
w210tdt
04-10-2012, 09:38 AM #55
edh,what timing do you use on the pump now?
w210tdt
EDH_Performance
04-10-2012, 11:51 AM #56
(04-10-2012, 09:38 AM)w210tdt edh,what timing do you use on the pump now?
12 degrees static
EDH_Performance
12 degrees static
dieselmeken
04-10-2012, 12:22 PM #57
I linked the youtubeclip to a community in Sweden, At Youtube the clip has 590 views now, on the Swedish community it has 1500 in less than 24 hours. Your Mercedes is hot in Sweden.
Here is a link.
http://www.garaget.org/video/120108
dieselmeken
Here is a link.
EDH_Performance
04-10-2012, 03:57 PM #58
(04-10-2012, 12:22 PM)dieselmeken I linked the youtubeclip to a community in Sweden, At Youtube the clip has 590 views now, on the Swedish community it has 1500 in less than 24 hours. Your Mercedes is hot in Sweden.
Here is a link.
Nice gøran! I really like itBig Grin
EDH_Performance
Here is a link.
mantahead
04-11-2012, 03:35 PM #59
(04-10-2012, 03:57 PM)EDH_Performance
Here is a link.
hi,
she goes well, Nice one.
How many rpms and how much power do you think you have?
mantahead
Here is a link.
hi,
EDH_Performance
04-16-2012, 01:37 AM #60
(04-11-2012, 03:35 PM)mantahead
Here is a link.
hi,
I stop reving at 6000, bacause i`m afraid the stock valve springs wont hold the valves past that pointTongue I don`t know how much power, but after i adjusted the Injectiontime yesterday the engine runs even better! Infact so good, that the driveshaft snapd after one pull in 3rd...So now i am searching for some better and beefier axelsBig Grin
EDH_Performance
Here is a link.
hi,
dieselmeken
04-16-2012, 03:05 AM #61
Blame me for it!SmileSmile
(04-16-2012, 01:37 AM)EDH_Performance
(04-10-2012, 03:57 PM)EDH_Performance Nice gøran! I really like itBig Grin
hi,
dieselmeken
hi,
EDH_Performance
04-16-2012, 04:38 AM #62
You`re such a badassTongue
This post was last modified: 04-16-2012, 04:38 AM by EDH_Performance.
EDH_Performance
Obi Kenobi
04-17-2012, 02:28 PM #63
Compliments .
Great job.
You are turned this W201 into a small evil fighter.
Obi Kenobi
Compliments .
Great job.
EDH_Performance
04-18-2012, 10:02 AM #64
Here is the tranny build picturesBig Grin
The bellhousing is from a old 5 speed mb tranny, and the gearbox is a GS5-39DZ from a BMW E39 530d. This can handle up to 1000nmBig Grin
We started like this:
[Image: IMG_4056.jpg]
The bmw inputshaft fits inside the stock mb bearing (35mm*15mm*10mm)
[Image: IMG_4060.jpg]
[Image: IMG_4062.jpg]
Spotwelded one side and adjusted the tranny so it aligned up with the engine
[Image: IMG_4063.jpg]
We was almost empty of gas that night, so the welding wasn`t perferct...But it holdsSmile
[Image: IMG_4070.jpg]
[Image: IMG_4072.jpg]
[Image: IMG_4073.jpg]
[Image: IMG_4074.jpg]
The universal sinter plate with the big BMW center welded to it
[Image: IMG_4075.jpg]
[Image: IMG_4076.jpg]
Made a hardyplate adapter, so that i can use the stock mb hardyplate until i`ve got myself an BMW 110mm beefy hardyplateBig Grin
[Image: IMG_4084.jpg]
[Image: IMG_4085.jpg]
[Image: IMG_4086.jpg]
[Image: IMG_4087.jpg]
The gearstick holder was shortened...
[Image: IMG_4088.jpg]
Here is my custom 5kg flywheel and my home made aligment tool
[Image: IMG_4077-1.jpg]
[Image: IMG_4078-1.jpg]
This post was last modified: 04-18-2012, 10:06 AM by EDH_Performance.
EDH_Performance
dieselmeken
04-18-2012, 11:14 AM #65
Thats the way, if you want it to hold, BMW is da shit! Nice work, next, come up whit the drivshafts that broke.Smile
dieselmeken
EDH_Performance
04-25-2012, 04:47 AM #66
Now is the rear end modified and strongerBig Grin
Let the pictures tell the story!
w124 (185mm diff) vs w129(210mm diff) flanges
[Image: DSC01284.jpg]
[Image: DSC01285.jpg]
125mm flange vs 102mm flange
[Image: DSC01286.jpg]
[Image: DSC01287.jpg]
[Image: DSC01288.jpg]
Custom driveshaft-flange with a 125mm flange
[Image: DSC01290.jpg]
[Image: DSC01291.jpg]
[Image: DSC01292.jpg]
A custom w124 differentialHeart
[Image: DSC01294.jpg]
[Image: DSC01295.jpg]
[Image: DSC01296.jpg]
Now over to the driveshafts....
To pieces welded togheter, then i make shure that they are strait before i weld them all the way
[Image: DSC01297.jpg]
[Image: DSC01298.jpg]
[Image: DSC01299.jpg]
Welded axels
[Image: DSC01300.jpg]
Then i macined the weld down to the same diameter as the axel. Then i press a pipe/bushing over the joint and weld that one as well. Now the joint it self are stronger than the axel.
[Image: DSC01301.jpg]
[Image: DSC01302.jpg]
Here is to finished axels, and you see the pipe i welded over the joint.
[Image: DSC01303.jpg]
Finished axels
[Image: DSC01304.jpg]
25mm with 102mm cv-joint vs 32mm axels with 125 cv-joint
[Image: DSC01305.jpg]
[Image: DSC01306.jpg]
[Image: DSC01307.jpg]
[Image: DSC01308.jpg]
This post was last modified: 04-25-2012, 04:51 AM by EDH_Performance.
EDH_Performance
Welded axels
Finished axels
04-25-2012, 09:35 AM #67
very nice! I'm impressed I may need to do that to a BMW project in the near future
EDH_Performance
04-30-2012, 06:31 PM #68
The sound says it all...
We start in 2nd gear Big Grin
This post was last modified: 05-01-2012, 04:50 AM by EDH_Performance.
EDH_Performance
dieselmeken
05-01-2012, 01:41 AM #69
(04-30-2012, 06:31 PM)EDH_Performance The sound says it all...
[Image: watch?desktop_uri=%2Fwatch%3Fv%3Du3uO5DK...m_Pc&gl=US]
Link don work for me.
dieselmeken
EDH_Performance
05-02-2012, 06:07 PM #70
Houston, we have a problem...
[Image: 20120502_202246.jpg]
[Image: 20120502_202414.jpg]
[Image: 20120502_202432.jpg]
[Image: 20120502_203441.jpg]
[Image: 20120502_203457.jpg]
[Image: 20120502_231115.jpg]
Double hardy plate work very good, but not for longRolleyesRolleyes
EDH_Performance
aaa
05-02-2012, 08:56 PM #71
That poor innocent sixspeed shift linkage was nailed...
The 190rev guys are fabbing a 90mm aluminum/delrin flexdisc, should be out in a month or two:
Wait, they exist already:
This post was last modified: 05-02-2012, 09:10 PM by aaa.
aaa
jeemu
457
05-03-2012, 12:05 PM #72
Are you sure at all fittings are straight? If u are then use original Flexdisc that used rear and tight that so your know at you are tighten it Smile
jeemu
denkoleso
05-03-2012, 02:37 PM #73
See on foto bolts is 8.8 class of strenght,original is 10.9.Double "elastic" togetheris impermissible design,bolts is too long.This is you problem.And sorry,but you coupling is incorect.Why you not weld part of bmw propeller shaft to mb shaft?You must be very serrious with this things-this is you life.But you is our brother in mercedes!
denkoleso
05-03-2012, 07:50 PM #74
http://190rev.net/forums/showthread.php?t=40991
$218 + shipping from thailand..
OR
$120ish in the states http://www.google.com/webhp?sourceid=chr...80&bih=925
One of those has to fit...
This post was last modified: 05-03-2012, 09:20 PM by winmutt.
OR
EDH_Performance
05-04-2012, 02:47 AM #75
(05-03-2012, 02:37 PM)denkoleso See on foto bolts is 8.8 class of strenght,original is 10.9.Double "elastic" togetheris impermissible design,bolts is too long.This is you problem.And sorry,but you coupling is incorect.Why you not weld part of bmw propeller shaft to mb shaft?You must be very serrious with this things-this is you life.But you is our brother in mercedes!
I agree with you, and this was just for the fun of itSmile Had to old flexdisc, and wanted to try...But now we know what not to do...I have a plan for the propshaft that I am trying this weekendWink
EDH_Performance
05-04-2012, 09:48 AM #76
Take pics! please
Take pics! please
mercemann
05-05-2012, 08:46 AM #77
I use automatic gearbox. The original parts seem to hold. Now i just waiting for my 8mm Herelevi-pump to arive....
mercemann
erling66
SuperDieselVan
294
05-05-2012, 08:55 AM #78
Hi
I used a flexdisc form a W210 E300 automatic. Larger dia and looks very strong.(Haven't tried it yet)
If you would like to have some idea about your HP and torque; I have a Gtech Pro FanaticSmile I can come to you and we can test it togetherBig Grin
HuhCoolTongue
erling66
Hi
HuhCoolTongue
EDH_Performance
05-05-2012, 10:20 AM #79
(05-05-2012, 08:55 AM)erling66 Hi
I found a w211 diesel propshaft at my friends place today, this has an 110mm Flexdisc...So i will build that todayWink We are planning a trip to skien or to notodden very soon, so can call you thenWink But for now lets say 177hp+ Big Grin
(05-05-2012, 08:46 AM)mercemann I use automatic gearbox. The original parts seem to hold. Now i just waiting for my 8mm Herelevi-pump to arive....
It is more linear power out of an automatic than an manualSmile
It broke when i tried to clutch it out on 4thTongue It worked a couple of times, but it had to clipp the bolts...
This post was last modified: 05-05-2012, 10:36 AM by EDH_Performance.
EDH_Performance
jeemu
457
05-05-2012, 12:20 PM #80
Say again. Use Original rear flex disk and tighten bolt so hard you can.
I t is much sronger than front disk and will hold up power.
Of cource all can be proken, if stupid Big Grin
jeemu
EDH_Performance
05-06-2012, 06:19 AM #81
(05-05-2012, 12:20 PM)jeemu Say again. Use Original rear flex disk and tighten bolt so hard you can.
I will uppgrade the rear flexdisc from 90mm to 110mm today, and also the axle from the diesel w211 has a bigger splines and bigger joint on the middle, so i hope it will hold now...And i found some 12.9 bolts, so i can tighten them even moreBig Grin
EDH_Performance
dieselmerc
05-07-2012, 09:14 AM #82
it was wet in this clip right? have you tried to increase the boost?
i think it should spin its tires more easily,
dieselmerc
EDH_Performance
05-07-2012, 09:31 AM #83
(05-07-2012, 09:14 AM)dieselmerc
In this clip the butterflyvalve didn`t open, so it goes better nowWink
It slips with 225 tyres, with 2 people in the backseat in 3rd gear on dry tarmac! Only 2 bars pressure.... As soon as the 90mm flexdisc is uppgraded i will turn up boostSmile
EDH_Performance
mantahead
05-07-2012, 11:44 AM #84
this should be good with more boost. can't wait to see this:Big Grin
mantahead
EDH_Performance
05-08-2012, 10:02 AM #85
Here is a few of all the broken parts...The first thing was the stock clutch, then the gearbox and then the driveshafts...
[Image: _MG_3701-1.jpg]
[Image: DSC01224.jpg]
[Image: DSC01223.jpg]
[Image: DSC01260.jpg]
[Image: DSC01261.jpg]
EDH_Performance
EDH_Performance
05-14-2012, 05:19 AM #86
Have now modified the diff tripodflange from 90mm to 110mm w211 style.
I now have an w211 propshaft that has bigger joint+bigger splines on the middle.
Now I have strong 110mm flexidiscsBig Grin
Bought a new gearshift holder and modified that...Have also moved the gearbox closer to the floor for better propshaft angle...
[Image: 20120510_214119.jpg]
[Image: 20120510_214124.jpg]
[Image: 20120510_215401.jpg]
[Image: 20120510_215409.jpg]
[Image: 20120510_221028.jpg]
[Image: 20120510_221035.jpg]
[Image: 20120510_221042.jpg]
[Image: 20120510_221047.jpg]
[Image: 20120510_222324.jpg]
[Image: 20120510_222334.jpg]
[Image: 20120510_222340.jpg]
[Image: 20120510_222344.jpg]
[Image: 20120511_214157.jpg]
[Image: 20120511_215104.jpg]
[Image: 20120511_215130.jpg]
[Image: 20120513_211507.jpg]
[Image: 20120513_211527.jpg]
[Image: 20120513_213355.jpg]
[Image: 20120513_215657.jpg]
Made a exhaust pipe for the rear wastegate, the other one will be done soon...
[Image: 20120514_002213.jpg]
[Image: 20120514_003637.jpg]
Here is what my enginebay looks like these daysSmile
[Image: 20120514_003723.jpg]
[Image: 20120514_003739.jpg]
[Image: 20120514_003748.jpg]
[Image: 20120514_003824.jpg]
[Image: 20120514_003851.jpg]
[Image: 20120514_003900.jpg]
The engine mounts don`t like when I start burning in 2nd and 3r gear with sinter clutchTongueTongueTongueTongue
[Image: 20120513_230521.jpg]
[Image: 20120513_230442.jpg]
This post was last modified: 05-14-2012, 05:24 AM by EDH_Performance.
EDH_Performance
dieselmeken
05-16-2012, 09:46 AM #87
Love it. So a common month for you is 29 days in the garage and 2 days on the road?SmileSmile
dieselmeken
05-16-2012, 08:59 PM #88
Honestly your problems have me rethinking 7.5mm upgrades Big Grin
EDH_Performance
05-17-2012, 01:03 PM #89
(05-16-2012, 08:59 PM)winmutt Honestly your problems have me rethinking 7.5mm upgrades Big Grin
Its the best thing that I have done to the car! If you drive carefully and dont race your car, it will holdSmile
Yes Gøran, the last months has been like that! But I like itSmile
EDH_Performance
mantahead
05-17-2012, 03:30 PM #90
(05-17-2012, 01:03 PM)EDH_Performance
hi
i don't think anything will stop you, keep up the good work Tongue
when do you sleep? Big GrinBig Grin
mantahead
hi
05-18-2012, 01:33 AM #91
Hi, I have been following this thread with interest for quite some time now. After seeing all of those broken parts, I am just curious if you have put the car on a dyno to see how much hp and torque this car has?
EDH_Performance
05-18-2012, 08:37 AM #92
(05-17-2012, 03:30 PM)mantahead
hi
I never sleepSmile
(05-18-2012, 01:33 AM)sassparilla_kid Hi, I have been following this thread with interest for quite some time now. After seeing all of those broken parts, I am just curious if you have put the car on a dyno to see how much hp and torque this car has?
No I haven`t...But i will in a couple of monthsWink
This post was last modified: 05-18-2012, 08:44 AM by EDH_Performance.
EDH_Performance
hi
I never sleepSmile
05-19-2012, 01:10 AM #93
Fuckin Awesome!
Fuckin Awesome!
EDH_Performance
06-10-2012, 07:21 AM #94
After a little breakdown, with the chain snapped and ruined my valves and camshafts I have now started on the rebuild! The motor is on my stand in the garage and I am uppgrading some vital parts this time to ensure a good and longlasting engineSmile
The wedge on the chainsprocket on the crankshaft has got an "Jeemu style" uppgradeSmile
Here is the stock 606 sprocket with the original wedge.
[Image: 20120609_185855.jpg]
[Image: 20120609_185915.jpg]
[Image: 20120609_185928.jpg]
I have drilled a 5mm hole trough the spcrocket and hammerd a 5mm rodwedge in there (dont know the exact english word for it)
[Image: 20120609_191349.jpg]
[Image: 20120609_191415.jpg]
[Image: 20120609_191949.jpg]
[Image: 20120609_192535.jpg]
[Image: 20120609_192549.jpg]
This upgrade is because the pump and camshafts are now heavier to drive, plus as jeemu says...We now have som trottle respons and th rpm drops and raises a BIT faster than a stock engineTongueTongueTongue
And the old supercharger has got an uppgrade with some new bearings and some portingBig Grin
Cleaned the screws
[Image: 20120609_223157.jpg]
the couppling was still in good condition
[Image: 20120609_223231.jpg]
stock outlet
[Image: 20120609_223511.jpg]
[Image: 20120609_223515.jpg]
desired outlet
[Image: 20120609_224555.jpg]
Ported outletBig Grin
[Image: 20120609_233606.jpg]
[Image: 20120609_233618.jpg]
[Image: 20120609_233642.jpg]
[Image: 20120609_233649.jpg]
[Image: 20120609_233716.jpg]
I am also thinking of mounting a smaller pulley on it...The ratio now is 1:2 and the old was 1:3!
1:3 is a bit to much, as the pulley is so small that the belt is just slipping. So 1:2,5 is much betterBig Grin
This post was last modified: 06-10-2012, 07:26 AM by EDH_Performance.
EDH_Performance
Cleaned the screws
stock outlet
desired outlet
dieselmeken
06-10-2012, 08:06 AM #95
What caused the breakdown? Valvesprings? High rew? Do you have ant harder springs now? How did the pistons look, Have the 606 burned the fuel as expected or do you need moore?
Anyway, thanks for sharing, now it seems to bee bulletproof. (again!)Smile
dieselmeken
EDH_Performance
06-10-2012, 08:32 AM #96
(06-10-2012, 08:06 AM)dieselmeken What caused the breakdown? Valvesprings? High rew? Do you have ant harder springs now? How did the pistons look, Have the 606 burned the fuel as expected or do you need moore?
I have talked and discussed with many buddies, and it looks like the chain split in half at 6000rpm, and then the camshaft was still spinning and thats why all 24 valves are bent and both camshafts are destroyd.
The piston said "careface" to the incident, so they are as good as they always have beenTongue
I am uppgrading springs now! My contact in Norway is on the caseWink
My engine swallows the diesel and burns it perfectSmile I will test some other things to get more power out of the same amount of fuel, but I think I need moreSmile
We all hope that you dont give up about better elements Big Grin
EDH_Performance
EDH_Performance
06-18-2012, 07:16 AM #97
Original (rh) vs race spring (lh)
[Image: 20120616_001030.jpg]
[Image: 20120616_001053.jpg]
[Image: 20120616_001106.jpg]
All 24 springs and custom bottom shims
[Image: 20120616_004829.jpg]
[Image: 20120616_004845.jpg]
Mounted springs
[Image: 20120616_010408.jpg][Image: 20120616_010440.jpg]
[Image: 20120616_012124.jpg]
8000rpm valvesprings
[Image: 20120616_024607.jpg]
Crimp paint on vital partsSmile
[Image: 20120616_035027.jpg]
[Image: 20120616_035034.jpg]
[Image: 20120616_035042.jpg]
[Image: 20120616_035050.jpg]
[Image: 20120616_042255.jpg]
[Image: 20120616_042301.jpg]
Since the stock valvesprings is just 15kg springrate, and the new one is 36kg! The camgear must be secured better...
Drilled and installed a M6 bolt "Jeemu style"
[Image: 20120617_153501.jpg]
[Image: 20120617_153638.jpg][Image: 20120617_153650.jpg]
Final assemblyBig Grin
[Image: 20120617_183737.jpg][Image: 20120618_010818.jpg]
[Image: 20120618_010826.jpg]
[Image: 20120618_010835.jpg]
[Image: 20120618_010846.jpg]
[Image: 20120618_011712.jpg]
[Image: 20120618_011727.jpg]
This is why my engine failed....Sad
[Image: 20120618_013036.jpg]
This post was last modified: 06-18-2012, 07:26 AM by EDH_Performance.
EDH_Performance
Mounted springs
06-18-2012, 12:58 PM #98
Literally the weakest link of your motor.
Ducos
HX35
81
06-18-2012, 01:19 PM #99
Greetings from ålesund!
What diff are you using?! does it hold up?? haha
Creds on your build !! Smile love it!!
Ducos
06-18-2012, 08:41 PM #100
Do you have enough outboard motors? haha
 4 Guest(s)
 4 Guest(s)
