STD Other Projects Norwegian OM606 build
  • 7 Vote(s) - 4.43 Average
Pages (7): Previous 1 2 3 4 5 7 Next
EDH_Performance
06-19-2012, 01:34 AM #101
(06-18-2012, 01:19 PM)Ducos Greetings from ålesund!
What diff are you using?! does it hold up?? haha
Creds on your build !! Smile love it!!
Hi,
Ålesund is a nice place, have been thereTongue
The diff is a w124 ASD diff with 3.24 gearing, custom 125mm flanges and shortened w129 35mm axelsSmile Works fine, but i am positive that the diff will break soonConfused Too much torqueTongue
If that one breaks, i have a w129 210mm diff with a 2.2 gearingBig Grin But this needs welding, or some diferentiallockSmile
(06-18-2012, 08:41 PM)sassparilla_kid Do you have enough outboard motors? haha
Yes, I work at a local Mercury dealer...So i fix alot of out/inboard enginesWink
This post was last modified: 06-19-2012, 01:38 AM by EDH_Performance.
EDH_Performance
Hi,
bmartins
06-20-2012, 04:31 AM #102
Brutal...great job.....
bmartins
Nielsychop
06-21-2012, 05:16 PM #103
Amazing perseverance!
Where did you get your 8000rpm valve springs from may I ask? Also I'm currently looking for a wastegate, what wastegates are you using? and why two? Better control, or is it your manifold?
Nielsychop
gaiex
06-21-2012, 07:39 PM #104
This is the type of work everyone have to dedicate to their engines, if everyone at least have 1/3 of your knowledge, specially me! LOL
Keep up with the good project. Soon I will also put a 606/603 on my w115 and that will be a huge task, but first I have to remove all the rust in it!! Smile
PS: I noticed that you don't have any engine/AC fan, you don't have too much sunny hot days there to need it!? :-D
The space for the fan is minimal right?
Regards
gaiex
Regards
EDH_Performance
06-23-2012, 09:33 AM #105
(06-21-2012, 05:16 PM)Nielsychop Amazing perseverance!
Here did i got the springs: http://kmcams.com/product_info.php?cPath...cts_id=885
They are really cheap, and the fit the stock retainer. Custom botom shims is needed.
I have a twinsroll turbo, so therefore i have two wg...Then i can split the pressure in the two exhaust chambersWink
(06-21-2012, 07:39 PM)gaiex This is the type of work everyone have to dedicate to their engines, if everyone at least have 1/3 of your knowledge, specially me! LOL
Regards
Thanks mateBig Grin
You are absolutly right, I dont have any fan...There is so little room for it, but I will make room, and install one very soon as we go towards pretty warm days here in NorwayWink
This post was last modified: 06-23-2012, 09:35 AM by EDH_Performance.
EDH_Performance
Regards
Thanks mateBig Grin
jeemu
457
06-23-2012, 04:44 PM #106
Hi. Spal make wery thing fans. 350mm version is 51mm thing.
jeemu
1540
09-12-2012, 02:24 PM #107
what kind of valve do you use to bypass the compressor and how do you control it?
1540
EDH_Performance
09-12-2012, 06:51 PM #108
(09-12-2012, 02:24 PM)1540 what kind of valve do you use to bypass the compressor and how do you control it?
BMW trottelbody+wastegate actuator that opens when turbo charge more than the compressor! Easy fix if you can weldWink
EDH_Performance
1540
09-13-2012, 06:04 AM #109
Can you take a picture how you have linked together wastgeten and trottelboddyn because I have a 606 with turbo and ombygd pump but it needs more boost at lower RPM. just have to find kompessor that works well first
1540
Rub87
09-20-2012, 05:05 AM #110
How's the oil burning these days in the OM606??
Rub87
EDH_Performance
09-24-2012, 06:20 AM #111
(09-13-2012, 06:04 AM)1540 Can you take a picture how you have linked together wastgeten and trottelboddyn because I have a 606 with turbo and ombygd pump but it needs more boost at lower RPM. just have to find kompessor that works well first
I can take some photos if i rememberSmile But it was very easy to fix!Wink
(09-20-2012, 05:05 AM)Rub87 How's the oil burning these days in the OM606??
The oil burner works perfect! Still to little hp, but we are gonna dyno it one more timeSmile I need to fis the feedpump and then meybe we can se 500whpBig Grin
This post was last modified: 09-24-2012, 06:22 AM by EDH_Performance.
EDH_Performance
mao76
09-24-2012, 07:26 PM #112
would very good friend, want to do a job as yours on my bmw330d, would I want to put an eaton m90, but as turbocharger I have found a gt3582r Garrett and a t70super, is you/he/she able' to go? what ar should I use warm side?difference feels a lot him with supercharger for the low regimes?
This post was last modified: 09-27-2012, 07:23 AM by mao76.
mao76
Ksteen2
09-27-2012, 02:39 AM #113
(12-27-2011, 03:09 PM)EDH_Performance
(12-27-2011, 01:33 PM)erling66 Hmmm, looks like it is going to be tough for me to get the strongest 606 in Southern NorwayDodgy But that is coolSmile
Why did you weld the back side of your flywheel?
and what turbo is that?
Haha, who knows Erling...Time will show!
I had to weld the startertooths to the flywheel bacuase I had to take away so much material, that the startertooths would fall off if haden`t Smile
The turbo is a T70 super, similar to Garrett T-61.. I have a bigger turbo as well, but hope this will do for nowWink
Hello, Nice work on your car, I am just woundering, can i use a flywheel from a Gasoline engine and mashine like that?
Ksteen2
EDH_Performance
09-27-2012, 07:45 AM #114
(09-27-2012, 02:39 AM)Ksteen2
Yes, i think the E300 or the 300D om603 flywheel is easier to machineWink
EDH_Performance
HaavardPYA
10-08-2012, 11:20 AM #115
Nice project! The rear axel is the weak link in the 201. Is the 2,3 16v rear axle any stronger than the W124? I know that the BMW e28 rear axle bolts right on the w124 bolt holes, just need a custom diff mount. And then you can use the big "210" Bmw 7-serie diff. But i dont think there is any option like that to the 201. Maybe you can use a e28 rear end and shorten it to be narrower?
Im from Norway and doing a 606 swap in a 201 myself, so its really nice to see what needs to be done with the driveline!
A friend of mine is running the 530D tranny and BMW "210" diff in his E21 with a S54 engine. The only thing that been broken this season is a joint on the propshaft and plenty of tiresSmile Im pretty sure that BMW parts is a cheap and strong solution when it comes to driveline.
http://www.youtube.com/watch?v=18Q-1569WZc
-Håvard
HaavardPYA
-Håvard
EDH_Performance
10-09-2012, 07:56 AM #116
(10-08-2012, 11:20 AM)HaavardPYA Nice project! The rear axel is the weak link in the 201. Is the 2,3 16v rear axle any stronger than the W124? I know that the BMW e28 rear axle bolts right on the w124 bolt holes, just need a custom diff mount. And then you can use the big "210" Bmw 7-serie diff. But i dont think there is any option like that to the 201. Maybe you can use a e28 rear end and shorten it to be narrower?
-Håvard
The weak link in the w124 diffs without the asd is the planet wheels. I have welded my diff, and it holds still! standstill and starting in 3rd gear with no problemSmile
EDH_Performance
-Håvard
HaavardPYA
10-09-2012, 09:19 AM #117
Great! Smile What gear ratio is your diff?
HaavardPYA
EDH_Performance
10-11-2012, 04:30 AM #118
(10-09-2012, 09:19 AM)HaavardPYA Great! Smile What gear ratio is your diff?
3.07Smile Have a 210mm diff from a w140 with 2.2 ratio, theoretical top speed of 360kmhSmile
This post was last modified: 10-11-2012, 04:31 AM by EDH_Performance.
EDH_Performance
HaavardPYA
10-11-2012, 09:29 AM #119
Ok. That 140diff would be nice for cruising, or some very long burnouts if there is enough grunt!Big Grin
HaavardPYA
jeemu
457
10-12-2012, 12:29 PM #120
That e21 is really nice. but Mercedes typ 188 diff can handle prety much power if it is good gondition if used normal street tires on the street.
type 210 diff can handle the rest Big Grin
Nice build EDH
jeemu
Nice build EDH
EDH_Performance
10-17-2012, 04:19 AM #121
(10-11-2012, 09:29 AM)HaavardPYA Ok. That 140diff would be nice for cruising, or some very long burnouts if there is enough grunt!Big Grin
More grunt is coming when the fuelsystem is upgraded! Now that i am aware of the starvation in fuelsupply, i really feel that the engine does not get enough food on high revs!
(10-12-2012, 12:29 PM)jeemu That e21 is really nice. but Mercedes typ 188 diff can handle prety much power if it is good gondition if used normal street tires on the street.
Nice build EDH
The 188diff has survived massive burnouts with 225 tyres;D If i go as extreme as you Petri and all the other finnish guys, i will ned the 210mm diffBig Grin
This post was last modified: 10-17-2012, 04:22 AM by EDH_Performance.
EDH_Performance
Nice build EDH
EDH_Performance
10-19-2012, 10:07 AM #122
Here is dyno video and a little test drive. Made only 356whp and 540nm on the wheel becuase of to little feedpump...
Dyno day with the vw/audi club
A little test drive:
EDH_Performance
2996
10-19-2012, 10:34 AM #123
Very awesome videos, thanks for posting Smile You can almost feel the power/torque from the g-force movement of the camera
guy.
Are you getting a bit of compressor surge around 18 to 22 seconds in the second video? The engine sounds very nice!
Cool dyno room also Smile
2996
guy.
EDH_Performance
10-19-2012, 10:52 AM #124
(10-19-2012, 10:34 AM)2996 Very awesome videos, thanks for posting Smile You can almost feel the power/torque from the g-force movement of the camera
guy.
ThanksWink The sound you hear between 18-22 sec is the back tyres touching the wheelarch...Have some friends in the backseat;D
EDH_Performance
guy.
EDH_Performance
11-22-2012, 04:24 PM #125
The engine will be taken to new hights now with: better intake manifold, compound turbo, remove compressor, new 210cc @6100 rpm diesel pump, new big home made feed pump, bigger exhaust.
December will be a exiting monthBig Grin Stay tuned!
EDH_Performance
EDH_Performance
11-29-2012, 11:18 AM #126
210cc pump was to much for this china turbo...
Listen to the strange sound everytime the turbo hits boost!
Minute after the compressor wheel came apartSmile
[Image: 20121129_152614.jpg]
[Image: 20121129_153043.jpg]
EDH_Performance
Sotnisse
11-29-2012, 01:02 PM #127
(11-22-2012, 04:24 PM)EDH_Performance The engine will be taken to new hights now with: better intake manifold, compound turbo, remove compressor, new 210cc @6100 rpm diesel pump, new big home made feed pump, bigger exhaust.
Finally i found your project thread, its awesome. And i have to say its also informative in many ways. Ive got w123 om606 turbo. It has been running very nice, but im always planning for upgrades. Since you are removing the compressor, are you not happy with it? Ive been dreaming of a compressor but im not really sure. Maybe i should keep on searching for a better turbo, at the moment its a hx50
W123 om606 hx50 ppd-pumpHeart
Sotnisse
EDH_Performance
11-29-2012, 01:07 PM #128
Hello thereSmile
The compressor is going away becuase it takes to much space and the intake is not good regarding the flow! The compressor and turbo works really good in a daily driver, because you get boost instantlyWink
Now i am building a compound setup with a hx60 and maybe a hx40Wink
Can you tell me what the size of your turbine housing is, and when do you have full boost?
EDH_Performance
Hello thereSmile
Sotnisse
11-29-2012, 01:28 PM #129
(11-29-2012, 01:07 PM)EDH_Performance Hello thereSmile
Well i have to check, its from a scania 9liter v8. It kicks in at 3500. Max boost is now 1,6 bar. And max revs is approx 5300. Full boost only between 4000-5200Huh It keeps the boost through gearchanges(3,4&5) but the thing is i cant get it spinning on first and second gear. If i figure out how to post pictures i got the dynochart with previous settings.
Sotnisse
majesty78
11-29-2012, 01:30 PM #130
@EDH:
http://www.superturbodiesel.com/std/thread-3402.html
Nothing for you?
Pricing would be reasonable cheaper ;-)
This post was last modified: 11-29-2012, 01:31 PM by majesty78.
majesty78
@EDH:
Nothing for you?
EDH_Performance
11-29-2012, 01:34 PM #131
(11-29-2012, 01:30 PM)majesty78 @EDH:
Nothing for you?
Hoho, looks like a good and healthy turboBig Grin But to big for me...I have an holset hx 60 and i need one in the size of a hx40 with 14cm2 housing for early spoo upSmile But thanks for the infoBig Grin
EDH_Performance
Nothing for you?
Ksteen2
11-30-2012, 04:08 AM #132
how do i mesure the outlet housing??
I've still got a BW KKK29 laying for my 300TDT prodject..
if its not too big, maybe it would be the turbo you'r looking for??
Ksteen2
w210tdt
11-30-2012, 01:17 PM #133
May i ask What your plans Are for the feed pump?i have a meken 140cc pump in my 606 with a 1 bar high flow feed pump,but wondering if two 044 pumps would be better.to Get 3bar feed pressure.
w210tdt
EDH_Performance
11-30-2012, 06:07 PM #134
(11-30-2012, 04:08 AM)Ksteen2 how do i mesure the outlet housing??
You need to meassure the little and big diameter on the compressor wheelWink
(11-30-2012, 01:17 PM)w210tdt May i ask What your plans Are for the feed pump?i have a meken 140cc pump in my 606 with a 1 bar high flow feed pump,but wondering if two 044 pumps would be better.to Get 3bar feed pressure.
I am building my own pump, capable to over 800 litres/hour, so you need some 044 pumps to beat me! But holley makes ggod feed pumps, and offcourse you can use the 044 pumps, but they are very expensiveSmile
This post was last modified: 11-30-2012, 06:11 PM by EDH_Performance.
EDH_Performance
Ksteen2
12-02-2012, 06:23 PM #135
I'll do that Wink
Ksteen2
I'll do that Wink
Ksteen2
12-03-2012, 05:22 AM #136
somethings telling me that this old Merch diesel just fly's away from all the other cars that's tunned here, Volvo's and bimmers :p
and I like it Big Grin
Ksteen2
EDH_Performance
12-06-2012, 09:20 AM #137
Resturation of my newly bought Holset hx60:
[Image: 20121201_141432.jpg]
[Image: 20121201_142630.jpg]
[Image: 20121201_142637.jpg]
[Image: 20121201_142657.jpg]
[Image: 20121203_185007.jpg]
New paint and cleaned the v-bandsBig Grin
[Image: 20121205_204252.jpg]
[Image: 20121205_204313.jpg]
[Image: 20121205_204320.jpg]
[Image: 20121205_204351.jpg]
[Image: 20121205_204402.jpg]
[Image: 20121205_204444.jpg]
[Image: 20121205_204525.jpg]
EDH_Performance
12-06-2012, 10:30 AM #138
That is a BIG turbo Smile
Ksteen2
12-07-2012, 07:32 AM #139
it became a little better then what it was Wink
this is just too cool :p
Ksteen2
mantahead
12-07-2012, 12:15 PM #140
hi,
looking good. What size is the exhaust housing.
mantahead
hi,
EDH_Performance
12-09-2012, 07:21 AM #141
(12-07-2012, 12:15 PM)mantahead hi,
It is big, 27...but it is almost the smallest you gan get to the hx 60Smile
EDH_Performance
pena837
12-09-2012, 04:27 PM #142
KKD sells HX60 with 22cm2 housing
This post was last modified: 12-09-2012, 04:29 PM by pena837.
pena837
EDH_Performance
12-09-2012, 05:30 PM #143
(12-09-2012, 04:27 PM)pena837 KKD sells HX60 with 22cm2 housing
I will make it smaller if it is to big;D No problem in that, cut and weldBig Grin
EDH_Performance
Ksteen2
12-10-2012, 03:15 AM #144
If you use a HX35 with smal housing azz a starter, there is no chanse in hell that the HX60 wont spool Wink
Ksteen2
EDH_Performance
01-20-2013, 08:05 PM #145
The new setup on this engine will be a 3 staged turbo system, with boost from idle and up to top rpm... No more info on this now, i will post picture when the setup is builtWink
I have worked on the HX60 that will be delivering the air in my setup...The exhaust housing was a 27cm, and will be downsized to about 18-20cm!
[Image: 20130116_222120.jpg]
[Image: 20130116_222112.jpg]
[Image: 20130116_222102.jpg]
[Image: 20130116_222137.jpg]
[Image: 20130116_231020.jpg]
[Image: 20130116_231037.jpg]
[Image: 20130116_231102.jpg]
[Image: 20130116_231132.jpg]
EDH_Performance
erling66
SuperDieselVan
294
01-21-2013, 04:40 AM #146
If you can make that turbo work on a 606, I will be very impressed Smile I like people that try to solve problems themselves and not just buy new parts
HuhCoolTongue
erling66
HuhCoolTongue
01-21-2013, 08:30 AM #147
Turbo surgery!!? What what!?!?!?
jellydonut
1987 W124 250D
21
01-21-2013, 08:44 AM #148
That sounds real interesting. I have yet to actually see a 3-stage turbo setup - most people, and companies, end up using at most 3 turbos in a two-stage setup. BMW with their two high-pressure turbos that gate in and out for better response.. and drag racers/sled pullers with two low-pressure turbos for massive amounts of air.
Depending on how small the high-pressure turbo has to be, you might have to use a wastegate+bypass air valve to bypass it at higher RPMs.
jellydonut
Ksteen2
01-21-2013, 09:01 AM #149
it looks neat Wink
hope that big old lump of steel can get some pressure soon Wink
Ksteen2
it looks neat Wink
majesty78
01-21-2013, 03:39 PM #150
That's a funny one :-)
Long time ago i've seen somebody in UK doing this on a VR6 VW build with to big turbine housing....
majesty78
 9 Guest(s)
 9 Guest(s)
