5,5mm & 6,0 mm in same pump ( filmclip)
Yes, Im stupid, mixed the element, but it gave me the oppurtunity to maka a small clip, Here you see how much a 5,5 can perform maximum contra a 6,0 mm from a OM606 pump. The 5,5 does not give more than app 65 cc, but take a look at the 6 mm element.
The pump has now 5pc of 6 mm element inside
(01-11-2012, 08:19 AM)vstef_is And the clip (you forgot) - looks like there's only so much a 5.5 can put out...
P.S. Is it a OM617?
P.S. Is it a OM617?
Do you sell the 6,0mm elements and delivery valves ? i was watching your you tube pretty impresive . i have an mw pump i would like to upgrade . i think these will be the best balance for my goals . also what size injectors would you recommend/sell with the 6.0mm element/dv's ?
thanks and i like the rock and roll pump video keep it up !
(10-06-2012, 07:23 AM)awk wow impressive difference. you still have 6mm elements or you make only 7.5 now?
