STD Tuning Engine 5,5mm & 6,0 mm in same pump ( filmclip)
dieselmeken
01-11-2012, 07:47 AM #1
Yes, Im stupid, mixed the element, but it gave me the oppurtunity to maka a small clip, Here you see how much a 5,5 can perform maximum contra a 6,0 mm from a OM606 pump. The 5,5 does not give more than app 65 cc, but take a look at the 6 mm element.
The pump has now 5pc of 6 mm element inside
dieselmeken
vstef_is
01-11-2012, 08:19 AM #2
And the clip (you forgot) - looks like there's only so much a 5.5 can put out...
P.S. Is it a OM617?
This post was last modified: 01-11-2012, 08:22 AM by vstef_is.
vstef_is
P.S. Is it a OM617?
dieselmeken
01-11-2012, 09:21 AM #3
(01-11-2012, 08:19 AM)vstef_is And the clip (you forgot) - looks like there's only so much a 5.5 can put out...
P.S. Is it a OM617?
Yes, Thats the limit. OM617 yes.
dieselmeken
P.S. Is it a OM617?
w210tdt
01-11-2012, 03:14 PM #4
any news on the new 7,5mm elements gøran?
w210tdt
lpumb3
617 300sd
141
10-05-2012, 10:15 PM #5
Do you sell the 6,0mm elements and delivery valves ? i was watching your you tube pretty impresive . i have an mw pump i would like to upgrade . i think these will be the best balance for my goals . also what size injectors would you recommend/sell with the 6.0mm element/dv's ?
thanks and i like the rock and roll pump video keep it up !
lpumb3
awk
10-06-2012, 07:23 AM #6
wow impressive difference. you still have 6mm elements or you make only 7.5 now?
awk
dieselmeken
10-07-2012, 12:21 PM #7
(10-06-2012, 07:23 AM)awk wow impressive difference. you still have 6mm elements or you make only 7.5 now?
6mm is stock Bosch elements, 7,5 is own production. 6 mm can be bought in any Bosch dieselshop/ Göran
dieselmeken
Bangaway
606 Turbo > Porsche Turbo
129
10-07-2012, 04:59 PM #8
Goran: As of now, what are you offering as far as element sizes. You have 7.5mm--what else? What are the respective cc outputs for each size that you are offering?
Bangaway
lpumb3
617 300sd
141
10-07-2012, 07:04 PM #9
thanks Dieselmeken , do you have part numbers for the 6mm , elements and DVs ?
lpumb3
