STD Other Alt fuels Water/methanol injection
  • 1 Vote(s) - 1 Average
Pages (2): Previous 1 2
03-21-2012, 07:15 PM #51
Awesome I'll have to check them out after my manufacturing processes class tonight
dust
03-29-2012, 06:56 PM #52
Sassparilla, check out home depot for hose. I am using their 3/8 hose for the pre-pump on my kit right now. They should have 1/4" hose as well. I broke my first push to connect after 5 years of use and probably 20+ removals.
dust
03-30-2012, 05:32 AM #53
(03-29-2012, 06:56 PM)dust Sassparilla, check out home depot for hose. I am using their 3/8 hose for the pre-pump on my kit right now. They should have 1/4" hose as well. I broke my first push to connect after 5 years of use and probably 20+ removals.
I was actually checking it out there earlier!! I had to go over there to look for some fitting for another project and saw some 1/4" tubing that was pretty high pressure, so I'll probably go back and get some next week, since I'm gonna be on spring vacation and I plan on getting a lot of work done on the car, and hopefully getting this stuff all set up. I'm getting pretty stoked, finally some real performance upgrades on the car!!
dust
03-30-2012, 05:54 AM #54
I found some parts and nozzles etc. I am just interested in the pump, but if you are interested in
Adjustable hobs switch
relay
hose
3 nozzles
y fittings
check valve
64oz tank
What do you need now?
dust
relay
hose
3 nozzles
y fittings
check valve
64oz tank
03-30-2012, 02:59 PM #55
All I need for my basic setup at the moment is tubing, which I plan on buying this weekend.
dust
03-30-2012, 09:31 PM #56
Good, so you are almost there. Interested in pics when you are done.
dust
03-31-2012, 02:32 AM #57
Can do, hopefully I get it done during the week along with all my other projects
04-27-2012, 05:18 PM #58
FINALLY!!! Got all of my parts for now, sort of. Tonight I plan on cleaning my non-egr manifolds, and possibly removing turbo + manifolds from engine, and then tomorrow will be install of new manifolds and w/m injection, along with egt probe/sensor/gauge. Hopefully all goes well.
Just curious where everybody mounts their pumps and routes their lines? I think I may mount the pump in the engine compartment since currently there is more room there than the trunk, and possibly just route the lines under the seats/carpet and stuff. We'll see, I'm sure I'll figure something out
04-27-2012, 08:44 PM #59
There's a nice free area on the passenger wheel well for the pump, close to the battery too. A few screws there and route the lines to the trunk. Or I guess where ever the tank is Wink
04-28-2012, 01:32 AM #60
That's about where I was planning on mounting it. Hopefully the tubing I got holds up to the pressure, I think its rated for about 40 psi less than the pump is set at, so hopefully it doesn't explode lol
05-18-2012, 04:47 PM #61
Okay I got the pump mounted, but wtf!?!? There seems to be no easy way to route the lines to the trunk Huh. I wanted to run them under the floor/carpeting along with the vacuum lines, on the passenger side of the car, but then discovered there's no place for it to come through the firewall, (which drilling a hole can easily solve). NEXT I couldn't figure out how in the hell to get the line from the trunk into the passenger compartment, so I decided maybe I'll try finding some place to route it under the car, and then I crawled under there and found there's no easy way to route it under there either!!!! Angry
Grrrrrrrr............ I think I'm gonna go to the hardware store and get a couple things I need and try again later Dodgy
05-18-2012, 05:14 PM #62
The vac lines for the trunk lock go along the passenger floor then go up over top of the fuel tank.
You can run your supply line next to them?. Also, the hole in the firewall by the passenger side
05-18-2012, 05:17 PM #63
I tried to route it along with the vac lines, but had trouble getting the tubing behind the seat and then up over the fuel tank. I tried both directions, going from trunk to passenger compartment and passenger compartment to trunk. Is there some sort of trick to it? I think I'll probably try again later when its not quite as warm out lol
05-18-2012, 06:35 PM #64
Well, I actually cut the trunk vac lines and spliced them into my water/meth supply. So can't say for sure.
You could maybe use a fishtape or possibly cut one of the trunk lines and use it as like a leader. Try to figure out how to get it back in though Wink
05-18-2012, 07:01 PM #65
I'm sure I will think of something, I usually do Tongue
05-21-2012, 11:35 PM #66
Gonna finish getting this all set up tomorrow, I have the pump installed, and the injector is now in the turbo outlet, so all I need to do is hook up the wiring for the pump and route the line from the trunk up to the pump and then it will all be good.
Can anybody tell me what kind of performance increase I can expect from running 3 gallons per hour? I'm just gonna end up using washer fluid for now so I need to go find some for cold weather.
lgreeley83
Mr. Rumbles
08-03-2013, 07:08 AM #67
Hey we want pics SAS! Lol thought I'd revive this thread.
I think greazzer did this too maybe? I'll have to hunt a minute.
lgreeley83
08-03-2013, 06:11 PM #68
Alright I'll post some shortly
08-06-2013, 07:25 PM #69
(05-21-2012, 11:35 PM)sassparilla_kid I'm just gonna end up using washer fluid for now so I need to go find some for cold weather.
I lol'd when I read this, where I am from its odd to find summer washer fluid, first time I saw it I was like what in the hell is that? haha
And as far as performance gains, I would expect you to pick up a couple ponies, nothing ground shaking though.
You aren't pushing enough fuel or air to make an enormous gain off W/M injection. But, used correctly it could help with mileage
08-06-2013, 09:51 PM #70
Sorry for the delay in getting you pictures guys, our home internet is being dumb so I can't use my computer, and my phone is being dumb every time I try to use it to upload images. I'll try to figure something out tonight though
08-09-2013, 10:27 PM #71
internet is finally working again!!! I'll post some pictures within an hour or so
So I'm pretty sure I posted these in project thread because I found them on my computer from last November, either that or I totally spaced on it and forgot to upload them when I took them lol
Here's a picture of the pump, mounted on the passenger side fender well
and the nozzle, going straight into the outlet side of the turbo. I believe its a 3gph nozzle, although I think it could probably be upped to 4-5gph
This post was last modified: 08-09-2013, 11:15 PM by sassparilla_kid.
bricktron
'77 240D
174
10-30-2013, 02:48 PM #72
i think if i were plumbing a water injection setup i would add another nozzle for misting the intercooler. it's the same cure for the same problem!
bricktron
10-30-2013, 10:05 PM #73
(10-30-2013, 02:48 PM)bricktron i think if i were plumbing a water injection setup i would add another nozzle for misting the intercooler. it's the same cure for the same problem!
True, but the methanol adds more fuel!
10-31-2013, 08:28 AM #74
(08-09-2013, 10:27 PM)sassparilla_kid internet is finally working again!!! I'll post some pictures within an hour or so
It's about damn time you posted up!
How does the power feel?
10-31-2013, 02:33 PM #75
I could probably use a higher flowing nozzle, but for now it's alright. I have it disconnected at the moment though until I find my pressure switch and plumb it in, as well as a spot for the switch in the cabin. I had been using one of my old vegetable oil switches mounted to the kick panel just under the ignition, but they are now being used for a starter kill switch and reverse light switch (had to do something with the wires after the manual swap)
It's probably gonna be a while until I get it hooked back up though, I'm pretty busy with school and work right now, and I'm trying to get started on my getting my 280Z running, and I also am probably gonna be getting a '71 International 1310 in the next couple weeks that's gonna need a little work
This post was last modified: 10-31-2013, 02:38 PM by sassparilla_kid.
10-31-2013, 07:23 PM #76
Make the time to set it up for straight water at least, Greazzer attributes his restored compression to just running water on his NA 617
10-31-2013, 09:48 PM #77
I'll get around to it eventually, I just need to get bored enough first lol
sooperkent
11-03-2015, 06:30 AM #78
Love to see more info/pics on this.
Intending to put in budget water injection on my om606 - wont use fancy devils own however as I find they are far too expensive.
sooperkent
dust
11-03-2015, 07:52 AM #79
Sooperkent, look for used. I don't know about the situation on your side of the pond, but I can find used on/off kits for $100-150, and progressive for $200-up. Bought two British top of the line kits for $250 and $300, but is more than most here would need.
dust
11-05-2015, 09:26 PM #80
Devils own is cheap compared to some of the tractor pulling water injection systems lol
