STD Tuning Engine 7,5 mm Element design for high performance engine
  • 5 Vote(s) - 4.8 Average
Pages (9): Previous 1 3 4 5 6 7 9 Next
mercemann
08-15-2012, 12:40 AM #201
(08-14-2012, 05:28 AM)dieselmerc I guess it's like the 8mm mynä, it very very sensitive on the throttle, almost a bit anoying sensitive
You are right.
S123, OM606, HX40, 8mm Herelevi-pump
https://www.facebook.com/#!/groups/198848373469840/
mercemann
You are right.
dieselmeken
08-15-2012, 12:09 PM #202
http://www.facebook.com/photo.php?v=4523298681979
A small teaser, another clip will bee made soon. This 603 only have 1,5 bar of boost and 160cc of fuel, max rpm 5000 full load. Inlet mainfold was cracked, so we had some boost leak there.
If the clip dont work, check out my facebook in my signature.
dieselmeken
300SD_KY
super turbo diesel
121
08-17-2012, 09:18 AM #203
you guys are CRAZY!
300SD_KY
you guys are CRAZY!
RICHIS
08-17-2012, 05:23 PM #204
nice i need that sort of style out my om605!
RICHIS
08-18-2012, 11:52 AM #205
I'm putting money away for an m-pump, hopefully by spring time I will have enough for one, and for a set of elements!
08-18-2012, 08:38 PM #206
Any idea how much horsepower a 617 could get from one of these pumps, with big turbo and I/C of course?
EDH_Performance
08-20-2012, 08:58 AM #207
Here is 140cc series 1 elements in actionBig Grin
Race mode:
Stealth mode= 50-80 hp less (restrictive exhaust!)
This post was last modified: 08-20-2012, 09:00 AM by EDH_Performance.
EDH_Performance
Race mode:
mantahead
08-20-2012, 09:36 AM #208
shes going well. Keep the videos comingBig Grin
mantahead
EDH_Performance
08-22-2012, 06:09 AM #209
Serie 1 elements:
EDH_Performance
Serie 1 elements:
jeemu
457
09-09-2012, 01:46 PM #211
(09-09-2012, 03:24 AM)dieselmeken 356whp from 140cc of fuel
http://www.youtube.com/watch?v=GNjsiA0HHUk
What are specs?
I dyno Mynä 7mm 150cc 449whp on 605
jeemu
What are specs?
09-09-2012, 09:17 PM #212
Did I read that right? 1680 nm?
HoleshotHolset
09-09-2012, 10:33 PM #213
It's 1680nm at the hubs...not to the tire.
It's right around 550nm (405 ft-lbs) to the tire.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
dieselmeken
09-10-2012, 06:01 AM #214
(09-09-2012, 01:46 PM)jeemu
What are specs?
EDH_performance have the spec, 400bhp was the goal and that was reached with + tolerance. this was his first dynorun with this engine.
dieselmeken
What are specs?
EDH_Performance
09-10-2012, 06:21 AM #215
Hi,
Yes this is my first dyno with this engine and I am pleased because I have not any performance camshafts and running stock prechambers. I will post some dynocharts soon!
That beeing said, this is the specs of the todays engine regards performance not strength:
Positiv:
-Ported head
-God flowing and tuned exhaust manifold
-Good turbo match (Still china turbo, but I have machined antisurge), surged before at 2 bars at low rpm, now it does 2.6 bars without any problem!
- 3" straight pipe exhaust with no muffler
- Eaton M90 with small nosewheel, does around 0.9bar at 2500rpm.
- Strong valvesprings
Negativ:
- valve between compressor/turbo opens a bit to late, so a pressure drop is seen in dynochart (This is easy to fix, but don`t had the time before dyno day)
Dieselmeken aka "The boss" is willing to rebuild my pump with series 2 180cc elements, and then I will dyno again!
This time with just pump upgrade, then with rebored prechambers, then with camshaftBig Grin
Stay tuned guysBig Grin
EDH_Performance
Hi,
Positiv:
-Ported head
Negativ:
09-10-2012, 09:14 AM #216
(09-09-2012, 10:33 PM)HoleshotHolset It's 1680nm at the hubs...not to the tire.
Beers,
Matt
Can you explain for me?
Beers,
Matt
EDH_Performance
09-10-2012, 11:12 AM #217
You need to divide the nm on the hub on total gear ratio to the engine, in this case divide it by 3,07Wink we dynoed in fitft gear (1:1) and final gear (3,07)
EDH_Performance
dieselmeken
09-11-2012, 04:07 AM #218
My search for quality parts continue, On Thursday - Saturday I will wisit the
http://automechanika.messefrankfurt.com/...esuch.html
Hopfully I can find some nice people down there that can help me to keep on developing my elements & valves
7,5mm for MW would bee nice to have in the program.
Also, there is some people that I have booked time with to sit down and talk about testequippment for CRI pumps. ( Injectors is no problem, that I do already), they are quite impressed of what you guys can do with the Mercedes engines & some small help from me, Your videoclip is all over the world now SmileSmile
There is a lot on the wish list for this X-mas.......
dieselmeken
tomnik
09-12-2012, 02:40 AM #219
(09-11-2012, 04:07 AM)dieselmeken 7,5mm for MW would bee nice to have in the program.
why not cooperating with people on the forum that already work on MW elements with success???
Tom
tomnik
Tom
dieselmeken
09-12-2012, 03:55 AM #220
(09-12-2012, 02:40 AM)tomnik
Tom
I would be happy to do that. You?
dieselmeken
Tom
tomnik
09-12-2012, 04:27 AM #221
(09-12-2012, 03:55 AM)dieselmeken I would be happy to do that. You?
Not me. I am out of the element projects for the public.
Member OM616 (Dave)
Tom
tomnik
Member OM616 (Dave)
Tom
jeemu
457
09-12-2012, 04:29 PM #222
(09-10-2012, 06:21 AM)EDH_Performance Hi,
Positiv:
-Ported head
Negativ:
You burn all fuel and power is that small on six. Need better Injection pump. What sound strange because here is dyno 603 on mynä 7mm at 530hp. So 140cc should be good enough at 500?
jeemu
Positiv:
-Ported head
Negativ:
dieselmeken
10-18-2012, 09:10 AM #223
So, now I have done some 7,5mm 180cc pumps that works good. The big test will be next week when I go down to Cyprus to change a 140cc pump to this 180cc with outside ALDA as I showed in another topic.
The 180cc without ALDA chokes the engine at full throttle, if you rew it up careful and wait for boost, it goes like hell according to my customers.
I shall try to make a nice filmclip of it and share to you all on STD.
dieselmeken
EDH_Performance
10-19-2012, 10:17 AM #224
Now i know why i only dynoed 356whp, and that is quite easy to understandSmile
The problem is that i am running a small efi petrol pump and stock fuel lineSad
So i think i have found the weak link in the chain! Upgrade is coming soon, and then i will dyno againBig Grin
And now that i am aware of the starvation problem, i can really feel that it dont get all the fuel that it need above at high rpm...
EDH_Performance
jeemu
457
10-20-2012, 03:40 PM #225
That is really nice at you found the problem on your car Big Grin
I like persons who tink themselves
This post was last modified: 10-20-2012, 03:43 PM by jeemu.
jeemu
huseyin55amg
10-25-2012, 03:22 PM #226
hi goran. waiting to see the results on the 190 my friend....
huseyin55amg
dieselmeken
10-27-2012, 04:09 AM #227
(10-25-2012, 03:22 PM)huseyin55amg hi goran. waiting to see the results on the 190 my friend....
So, back from Cyprus, did put the 180cc pump in, fired it up and it runs almost like a stock pump on low idle.
Nice sound and really quick in the uprewing.
Didnt drive it, Today Saturday is raceday, I went home Friday, waiting for result.
dieselmeken
huseyin55amg
10-28-2012, 01:31 PM #228
(10-27-2012, 04:09 AM)dieselmeken
lets see what salahi says Wink
huseyin55amg
dieselmeken
11-02-2012, 11:16 AM #229
[attachment=5964]
First 180cc pump did go Dyno today in Portugal
597hp 902nm @4800rpm
2,8bar of boost
Not so bad or what do you think?
This post was last modified: 11-02-2012, 11:19 AM by dieselmeken.
dieselmeken
[attachment=5964]
2,8bar of boost
mantahead
11-02-2012, 11:18 AM #230
(11-02-2012, 11:16 AM)dieselmeken First 180cc pump did go Dyno today in Portugal
2,8bar of boost
nice one, what turbo and spec?
mantahead
2,8bar of boost
dieselmeken
11-02-2012, 11:54 AM #231
(11-02-2012, 11:18 AM)mantahead
2,8bar of boost
Turb is GT3582R, he vill change now to a GTX35 aand see if he can reach 700hp.
dieselmeken
2,8bar of boost
mantahead
11-02-2012, 11:58 AM #232
2,8bar of boost
[/quote]
[/quote]
[/quote]
good power, shows the Dieselmeken pump can do it.Cool
mantahead
2,8bar of boost
[/quote]
[/quote]
[/quote]
dieselmeken
11-02-2012, 01:04 PM #233
(11-02-2012, 11:58 AM)mantahead First 180cc pump did go Dyno today in Portugal
2,8bar of boost
[/quote]
[/quote]
[/quote]
Thanks alot. Yes, this is my first prove, I have known that my pumps have worked out well, but still, a dyno result is prove that it works in real life.
My customers tells me that it goes like hell etc, but this is the first dyno with 180cc pump.
Also, another dyno showed that original fuelline & filter goes to 400hp, after that no moore.
One 170cc pump from another company ( time for own thinking here..) did 430hp, after modifie with 10mm fuelhose from tank, Holley black fuel pump and a fuelfilter with high flow, it dynoed OVER 500hp, same setup, only thing changed, fuellines & filter.
Good information to you all on STD from me, if you dont know it already.
Happy Friday evening, now its time for a beer.
dieselmeken
2,8bar of boost
[/quote]
[/quote]
[/quote]
11-02-2012, 02:01 PM #234
Not bad for an old diesel burner.
dieselmeken
11-02-2012, 02:26 PM #235
(11-02-2012, 02:01 PM)winmutt Not bad for an old diesel burner.
No, Not bad for an old dieseltech alsoSmileSmile
Finally, a result that I am really proud over.
dieselmeken
yankneck696
395
11-02-2012, 06:45 PM #236
I have a 2nd gen Dodge with a Cummins, now, VP44s will burn out from not enough fuel to cool them because of the computer on them. There are great lift pumps that have pre & post filtering & water separating. Got to use 1/2" fuel lines to get the most flow (12.5MM?). There are also some good belt driven pumps that are good for daily driving & 900+HP woth stupid torque...
Ed
yankneck696
Ed
Turbo
11-02-2012, 08:12 PM #237
Dieselmeken
is there a specification available on the turbo exact witch one it is.
at pressure rate a 3,8 it is really on the limit and I do wonder how the GTX3582R is going to like it
what is the air flow?
Is there some where you can read of how this engine is done?
(11-02-2012, 06:45 PM)yankneck696 I have a 2nd gen Dodge with a Cummins, now, VP44s will burn out from not enough fuel to cool them because of the computer on them. There are great lift pumps that have pre & post filtering & water separating. Got to use 1/2" fuel lines to get the most flow (12.5MM?). There are also some good belt driven pumps that are good for daily driving & 900+HP woth stupid torque...
Ed
Turbo
Dieselmeken
Ed
dieselmerc
11-03-2012, 08:20 AM #238
what inducer and exducer did that turbo have? sounded like a lot of power for such a small turbo?
dieselmerc
dieselmeken
11-03-2012, 10:47 AM #239
(11-03-2012, 08:20 AM)dieselmerc what inducer and exducer did that turbo have? sounded like a lot of power for such a small turbo?
Dont have that information.
Can ask him if its important for you, Is there any doubt that this spec not can do 600hp?
dieselmeken
11-03-2012, 06:10 PM #240
That would be an 82 exducer on the compressor I believe.
Turbo
11-03-2012, 07:33 PM #241
Like diselmerc say a lot of power for that small turbo.
according to garret the inducer is properly 61,4 mm for GT3582R if it is not a special one?
Turbo
dieselmerc
11-06-2012, 05:58 AM #242
okey if it is 61,4mm inducer i can belive those figures! but that turbo is maxxed!
dieselmerc
dieselmeken
11-06-2012, 02:57 PM #243
Clip from Cyprus pump with 7,5mm performance element.
This post was last modified: 11-06-2012, 08:20 PM by winmutt.
dieselmeken
11-06-2012, 08:18 PM #244
Here he got lost in the parking lot....
11-06-2012, 11:05 PM #245
Moar
Moar
mantahead
11-07-2012, 05:10 AM #246
lethal machine. She goes well.
mantahead
jeemu
457
11-07-2012, 04:30 PM #247
2,8bar of boost
Must be hell on fire on intake temp Confused
was pump tune 180cc on taht 597hp duno pull?
jeemu
2,8bar of boost
dieselmeken
11-08-2012, 12:31 AM #248
(11-07-2012, 04:30 PM)jeemu
2,8bar of boost
Yes.
dieselmeken
2,8bar of boost
Yes.
Turbo
11-08-2012, 07:38 AM #249
You could say there is hell after the turbo
At that pressure rate you could say it spinning like... do wander how long it will last at that speed...
(11-08-2012, 12:31 AM)dieselmeken
2,8bar of boost
Yes.
Turbo
2,8bar of boost
Yes.
jeemu
457
11-09-2012, 04:19 PM #250
(11-08-2012, 07:38 AM)Turbo You could say there is hell after the turbo
Measured airtemp after turbo can see if turbo is on map or not.
That Garrett not, and add that fuel amount. Not good on that engine.
But everyone do what they want Smile
6 syl should get near 700hp at 170cc of fueling.
Cyprus dyno is good Big Grin
http://www.youtube.com/watch?feature=pla...Yaqskg3Wh0
This post was last modified: 11-09-2012, 05:23 PM by jeemu.
jeemu
 6 Guest(s)
 6 Guest(s)
