STD Tuning Engine 7,5 mm Element design for high performance engine
  • 5 Vote(s) - 4.8 Average
Pages (9): Previous 1 5 6 7 8 9 Next
dieselmeken
11-18-2012, 08:45 AM #301
(11-16-2012, 04:42 PM)jeemu Pump bench you can result you want.
Only that matters is how much and how fast, Dieselmerken just dont want to understand my guestion, asked many times Smile case closed. myy opinioin is at ewerybody can do what they want.
What is it that I dont understand Jeemu? I have showed how long time it takes to inject fuel with 6,0 & 7,5mm element, 2 different setups of the 7,5
140cc element short duration
180cc long duration.
I was just wondering if you knew the duration on the 8mm that you have, just for compare?
That 8 mm is faster is no rocketscience to understand, I am intrested in how much faster it is.
dieselmeken
erling66
SuperDieselVan
294
11-18-2012, 12:15 PM #302
(11-17-2012, 05:12 PM)jeemu 605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
My woman go daily store shoping Smile
Impressive woman especially with those tires this time of the yearTongue
HuhCoolTongue
erling66
HuhCoolTongue
EDH_Performance
11-18-2012, 12:22 PM #303
(11-18-2012, 12:15 PM)erling66
Thats what I thought tooBig Grin
EDH_Performance
m2rkz
11-22-2012, 01:18 PM #304
now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.
Maybe 140cc 7,5mm pump is not good.
This post was last modified: 11-22-2012, 01:24 PM by m2rkz.
m2rkz
EDH_Performance
11-22-2012, 01:26 PM #305
(11-22-2012, 01:18 PM)m2rkz now after the filter there is 3bar for diesel and it comes 215 litres per hour only with battery. It is good enouh for petrol engine at least 600hp. But I still have same result and max 2,5 bar boost. It seams that still need some more diesel. egt is max only 550.
what kind of exhaust do you have?
EDH_Performance
mantahead
11-22-2012, 03:14 PM #306
hi,
how many degrees spill timing have you got?
mantahead
hi,
m2rkz
11-22-2012, 03:20 PM #307
(11-22-2012, 01:26 PM)EDH_Performance
3"
(11-22-2012, 03:14 PM)mantahead
hi,
14
This post was last modified: 11-22-2012, 03:21 PM by m2rkz.
m2rkz
3"
hi,
14
EDH_Performance
11-22-2012, 03:36 PM #308
This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
What kind of pump did you install? does the fuelflow go trough the stock feedpump or directly to the injection pump?
You should burn 3rd gear easily with this pumpWink
EDH_Performance
m2rkz
11-22-2012, 07:10 PM #309
(11-22-2012, 03:36 PM)EDH_Performance This sounds very strange to me! Offcourse you have mounted the fuel lines in the correct places on the pump? Not mixed the in and return?
yes I can burn 3rd gear but that's not the point. And ofcourse fuelflow go directly to the injection pump. We installed Bosch 044 and pressure regulator to 3 bar. And like I said we tested the fuelflow after the filter and directly before the diesel pump and it was very good. To 3500 or 4000 everything is ok but later the boost pressure will be the same or drop down little bit. Only problem can be the 140cc pump. Something is very bad there.
m2rkz
Mark_M
11-22-2012, 07:34 PM #310
Are you getting smoke but no more boost or is it clean?
Mark_M
m2rkz
11-22-2012, 07:39 PM #311
(11-22-2012, 07:34 PM)Mark_M Are you getting smoke but no more boost or is it clean?
at the beginning smoke and in the end clean....
m2rkz
dieselmeken
11-23-2012, 03:31 PM #312
(11-22-2012, 07:39 PM)m2rkz
As I told you in mail, I do the pump again to check it up, or upgrade it to you to thge 180cc edition
dieselmeken
m2rkz
11-23-2012, 05:06 PM #313
(11-23-2012, 03:31 PM)dieselmeken
yes I know. I just wanted to try it little bit more. The guys who are doing my mb are usually building petrol cars. That is why I ask so many questions here. Not for bad.
m2rkz
11-23-2012, 08:37 PM #314
Silliest of questions, checked all the charged air joints for leaks?
m2rkz
11-24-2012, 12:14 AM #315
(11-23-2012, 08:37 PM)winmutt Silliest of questions, checked all the charged air joints for leaks?
no leaks at all. checked many times.
But is this 215 litres diesel after filter and before pump enough?
It is enough for petrol engine. But for diesel?
EDH_Performance - please do a test for me. Calculate how much diesel per hour you will get after the filter and before injection pump with battery. And before filter. For example: put your feed pump to work for 20 seconds and lead diesel to resrvior and then calculate the amont for one hour. I got 215 litres per hour before injecton pump and 240 litres per hour before filter.
I have 8mm hoses and just new big banjos for filter. 8mm is good enough for 600hp with petrol engine. Tested.
This post was last modified: 11-24-2012, 03:54 AM by m2rkz.
m2rkz
EDH_Performance
11-24-2012, 07:05 AM #316
(11-24-2012, 12:14 AM)m2rkz
I will do a test today for youWink
This post was last modified: 11-24-2012, 07:10 AM by EDH_Performance.
EDH_Performance
jeemu
457
11-24-2012, 01:09 PM #317
I think at that -044 not flow enough. Why use that anyway?
No need 3bar trancfer pressure, 1bar is enough. Tested.
Try OEM lift pump.
jeemu
Try OEM lift pump.
dieselmeken
11-24-2012, 01:19 PM #318
(11-24-2012, 01:09 PM)jeemu I think at that -044 not flow enough. Why use that anyway?
Try OEM lift pump.
In testbench 1 bar is not enough with My elements. Pump starts to reduce fuel at 2600 rpm and up. When i put 3 bar in it supply fuel. Tested. But probably My elements is not so good as mynäs and herlevi
dieselmeken
Try OEM lift pump.
erling66
SuperDieselVan
294
11-24-2012, 01:24 PM #319
(11-22-2012, 07:10 PM)m2rkz
Do you have any videos from when you are driving?
HuhCoolTongue
erling66
HuhCoolTongue
jeemu
457
11-24-2012, 03:50 PM #320
(11-24-2012, 01:19 PM)dieselmeken
Try OEM lift pump.
Maybe there is some difference in pumps.
jeemu
Try OEM lift pump.
m2rkz
11-24-2012, 05:42 PM #321
Try OEM lift pump.
in petrol engines 044 is good for at least 600hp. tested. Diesel need more flow then?
(11-24-2012, 01:24 PM)erling66
sorry but no.
This post was last modified: 11-24-2012, 05:43 PM by m2rkz.
m2rkz
Try OEM lift pump.
sorry but no.
m2rkz
11-24-2012, 06:49 PM #322
Try OEM lift pump.
And whats your flowing afrer the filter and before injection pump on your om605 project? How many litres per hour? Please test it. I wanna know.
m2rkz
Try OEM lift pump.
m2rkz
11-25-2012, 09:17 AM #323
[/quote]
And what was the result?
m2rkz
[/quote]
300SD81
11-25-2012, 11:37 AM #324
Has anyone ever tried to add a fuel accumulator after the lift pump? Its a piston pump so the pressure pulses and is less for some cylinders than others..
[Image: Fuel_accumulator.jpg]
This post was last modified: 11-25-2012, 11:37 AM by 300SD81.
Ich liebe meine Autos!
300SD81
EDH_Performance
11-25-2012, 03:54 PM #325
Small test of the new 210cc Dieselmeken prototype!!
Works really good, but 4th gear didn`t love me in this video...
The motor runs very good, and work perfect on the road, daily drivingBig Grin
EDH_Performance
dieselmeken
11-26-2012, 02:55 AM #326
(11-25-2012, 03:54 PM)EDH_Performance Small test of the new 210cc Dieselmeken prototype!!
This is nice to hear, It sounds great, hopfully its moore powerful than the first edition. The fact that you self build the pump up & calibrated it in bench gives you at least 25 hp extra Wink
Now some daylight video before the snow cover the roads i Scandinavia.
dieselmeken
EDH_Performance
11-26-2012, 12:16 PM #327
Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easilyBig Grin I see now that i need new camshafts and bigger turbo and maybe some new slicks tyresBig Grin
I have evil plans, so stay tunedBig Grin
This post was last modified: 11-26-2012, 12:18 PM by EDH_Performance.
EDH_Performance
dieselmeken
11-26-2012, 12:41 PM #328
(11-26-2012, 12:16 PM)EDH_Performance Have been testing my merc today, since its dry at the motorway! Full pull on 4th gear, and at 4500rpm it starts to spinn tyres easilyBig Grin I see now that i need new camshafts and bigger turbo and maybe some new slicks tyresBig Grin
Big GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig Grin Bad pump, something is wrong, You should spin on 5:ft gear while your girfriend drive to the shopping mall, my misstake..sorryBig Grin På Svenska kallar vi detta Ironi.
dieselmeken
EDH_Performance
11-26-2012, 12:56 PM #329
(11-26-2012, 12:41 PM)dieselmeken
Hoho, with bigger turbo, 5th gear will also burn tyresWink Just you wait my friendBig Grin
The whole engine setup is to be modified, exhaust, intake and engine partsBig Grin
This post was last modified: 11-26-2012, 12:58 PM by EDH_Performance.
EDH_Performance
Ksteen2
11-27-2012, 03:11 AM #330
(11-26-2012, 12:56 PM)EDH_Performance
If you'r coming to Hamar soon, you can buy one of mine turbos, i have an BW KKK 31 and a BW KKK 30 and a Holsett HX60 Wink
i think the HX60 will fit you perfekt Wink
Ksteen2
EDH_Performance
11-27-2012, 03:45 PM #331
(11-27-2012, 03:11 AM)Ksteen2
(11-26-2012, 12:41 PM)dieselmeken Big GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig GrinBig Grin Bad pump, something is wrong, You should spin on 5:ft gear while your girfriend drive to the shopping mall, my misstake..sorryBig Grin På Svenska kallar vi detta Ironi.
Hahah, I just bought his HX60! Maybe now i can burn all 210cc Big Grin
EDH_Performance
Siekkinen
11-27-2012, 05:39 PM #332
(11-27-2012, 03:45 PM)EDH_Performance Hahah, I just bought his HX60! Maybe now i can burn all 210cc Big Grin
Or then you get problems with a cylinderhead Big Grin the air just can't get through fast enough. hx52 pro or hx55 are enough at least for 800 horsepower with that engine. Proofed Big Grin
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
EDH_Performance
11-27-2012, 05:45 PM #333
(11-27-2012, 05:39 PM)Siekkinen
True mate, and you know the person who has reached the"limit"Big Grin
But hey, go big or go home Big Grin
I will mate the hx60 with a hx35 or 40 for early spool up!
This post was last modified: 11-27-2012, 05:45 PM by EDH_Performance.
EDH_Performance
hooblah
11-27-2012, 06:07 PM #334
You crazy mofo! I can't wait to see this when it's done!
I've been watching this build for a little while now and I'd be happy to be at even half your power! You've got some skills and the money you've spent on this must be a serious amount. What do you do for a living btw?
I currently have a 190d 2.5 na and I'm planning on putting in an om606 in the near future.
Were there any major issues you had with this conversion? Do you think the standard manifold and turbo is able to fit in a right hand drive car despite the steering box being in the way?
hooblah
EDH_Performance
11-29-2012, 11:14 AM #335
210cc pump was to much for this china turbo...
Listen to the strange sound everytime the turbo hits boost!
Minute after the compressor wheel came apartSmile
[Image: 20121129_152614.jpg]
[Image: 20121129_153043.jpg]
This post was last modified: 11-29-2012, 11:15 AM by EDH_Performance.
EDH_Performance
300SD81
11-29-2012, 11:21 AM #336
I hope none of that ended up in your engine!
300SD81
EDH_Performance
11-29-2012, 11:25 AM #337
(11-29-2012, 11:21 AM)300SD81 I hope none of that ended up in your engine!
No, it didn`t Big Grin found all the piecesSmile
(11-27-2012, 06:07 PM)hooblah You crazy mofo! I can't wait to see this when it's done!
you got pmSmile
This post was last modified: 11-29-2012, 11:26 AM by EDH_Performance.
EDH_Performance
you got pmSmile
majesty78
11-29-2012, 01:27 PM #338
Looks like Turbobanditen Turbocharger ?
majesty78
EDH_Performance
11-29-2012, 01:42 PM #339
(11-29-2012, 01:27 PM)majesty78 Looks like Turbobanditen Turbocharger ?
Nope, it is from www.ksr.as Big Grin
Costs like 450 dollarsSmile
Did 2.5 bar+ whole his life, poor turbo chargerSmile I machined antisurge in the compressor housing to make it perform better, and it didWink
EDH_Performance
Siekkinen
11-29-2012, 03:52 PM #340
(11-29-2012, 11:14 AM)EDH_Performance 210cc pump was to much for this china turbo...
How dear you use chinese turbos on these engines? Big Grin
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
EDH_Performance
11-29-2012, 03:55 PM #341
(11-29-2012, 03:52 PM)Siekkinen
I maxed the 140cc pump just fine, at 2.5 barsSmile But now there is some serious upgrade on the turbo frontBig Grin
EDH_Performance
11-29-2012, 04:23 PM #342
Working Tacho would be nice ;-)
hansebanger77
EDH_Performance
11-29-2012, 04:32 PM #343
(11-29-2012, 04:23 PM)hansebanger77 Working Tacho would be nice ;-)
Tacho works fine, the speedometer doesn`tBig Grin I never drive fast you know, always 20km`hWink
EDH_Performance
Ksteen2
11-30-2012, 03:00 AM #344
This showes that Dieselmekken's diesel pumps works great Wink
to much fuel :p xD
Ksteen2
to much fuel :p xD
dieselmeken
12-01-2012, 09:58 AM #345
(11-30-2012, 03:00 AM)Ksteen2 This showes that Dieselmekken's diesel pumps works great Wink
to much fuel :p xD
My 7,5mm pumps kills turbos, not good WinkWinkWinkWink
dieselmeken
to much fuel :p xD
12-01-2012, 03:00 PM #346
(11-29-2012, 04:32 PM)EDH_Performance
Working speedometer would be nice :-)
hansebanger77
EDH_Performance
12-02-2012, 09:05 AM #347
(12-01-2012, 03:00 PM)hansebanger77
No, because then you can find yourself speedingWink
EDH_Performance
maKe-
12-02-2012, 07:21 PM #348
That highway pull. Big Grin
I rrreally need om606 in my w210 badly.
maKe-
majesty78
12-11-2012, 05:49 AM #349
Although it is no 7.5mm pump, I like to share my great experience with Göran from Dieselmeken:
He was so kind to make a short clip of rebuilding my Common Rail injectors:
Rebuild from 320CDI to AMG C30 spec.
Göran definitely knows his stuff :-)))
majesty78
Bangaway
606 Turbo > Porsche Turbo
129
12-11-2012, 09:50 PM #350
Dieselmeken you're becoming famous on youtube! If you could put on your "to do list," how to remove and install a pump for amateurs like me who pick up a set of wrenches once every six months, that would be great.
This post was last modified: 12-11-2012, 09:51 PM by Bangaway.
Bangaway
