STD Tuning Engine 320CDI in G wagen
320CDI in G wagen
320CDI in G wagen
Atli
03-06-2012, 04:10 AM #1
Hi guys.
I just bought E320cdi 2000.
How impossible is it to swap the engine and transmission into my G wagen?
Is it doable? I guess I need all the engine wiring? Do the computer need all the sensores ans etc.
Atli
Atli
Hi guys.
Atli
olefejer
03-06-2012, 02:50 PM #2
(03-06-2012, 04:10 AM)Atli Hi guys.
Atli
Has been done but how i don't know
http://suchen.mobile.de/fahrzeuge/showDe...=156843036
olefejer
Atli
INC
03-06-2012, 02:53 PM #3
Atli
Engine + all sensors and wiring
EZS + ELV module and wiring
Transmission contoler and wiring
ABS controler, wiring, and ABS sensors.
Yes its possible if you have all working donor car.
INC
Atli
bad3gakk
om605 - kkk27 - w124
52
03-07-2012, 09:42 AM #4
If you will be tuning this.. id look into commander6 or maybe nira ECU's...
bad3gakk
zeeman
03-07-2012, 06:44 PM #5
(03-07-2012, 09:42 AM)bad3gakk If you will be tuning this.. id look into commander6 or maybe nira ECU's...
You also need the dash cluster, ignition key and computer from the same car.
zeeman
huseyin55amg
03-08-2012, 06:01 AM #6
i own 3 G wagens and 2 of them have 606a fitted with mechanical IP's.
can the 320cdi run without the electronics i wonder ? are you a member of the various G wagen clubs on the net ?
btw, good luck with this project, and keep us posted.
rgds hus
huseyin55amg
rgds hus
bad3gakk
52
03-09-2012, 05:03 PM #7
the CDI engine is a common rail engine... It cant run without electronics, the fuel pressure behind the injectors are constant, and the injectors are opened by an electronic pulse... Under given circumstances many times each time the cylinder compresses..
As you may understand, this is insanely precise timings...
But, this danish bmw project.. (yellow 3series tourer) I think this was fitted with a mechanical pump, and normal pressure operated injectors... but the works this will require..
This post was last modified: 03-09-2012, 05:06 PM by bad3gakk.
bad3gakk
huseyin55amg
03-10-2012, 01:31 PM #8
(03-09-2012, 05:03 PM)bad3gakk the CDI engine is a common rail engine... It cant run without electronics, the fuel pressure behind the injectors are constant, and the injectors are opened by an electronic pulse... Under given circumstances many times each time the cylinder compresses..
guess i will stick with the 606a then....!
huseyin55amg
raudmees
07-07-2012, 02:45 AM #9
Here is one guy that did this.
Read from about here
http://translate.google.se/translate?sl=...50&act=url
But the whole thread is actually quite interesting
raudmees
07-07-2012, 12:44 PM #10
Standalone engine mgmt for the common rail motor:
http://www.specialist-components.co.uk/e...anagement/
raudmees
07-07-2012, 05:41 PM #11
What will the standalone common rail cost?
raudmees
Mark_M
07-08-2012, 06:20 PM #12
(07-07-2012, 05:41 PM)raudmees What will the standalone common rail cost?
The cost for the standalone system as far as the Landrover Jaguar TDV6 is concerned is £3560. I looked into it a couple of months ago and walked away from that idea.
Mark_M
raudmees
07-09-2012, 05:28 AM #13
(07-08-2012, 06:20 PM)Mark_M
Does it include engine, gearbox and three months vacation in Rio de Janeiro?
raudmees
07-09-2012, 09:02 AM #14
Aaaand this is why I'm building a 617
Mark_M
07-09-2012, 12:13 PM #15
(07-09-2012, 05:28 AM)raudmees
I wish! I started looking because I noticed the Jaguar TDV6 engine and box were relatively cheap. I saw complete units for £1500 which isn't for nothing but its 270BHP stock and they were all pretty low mileage and really good engines. Trouble is its twice the engine cost for the electronics to make it run.
I have a 605 and mechanical pump for the project now.
Mark_M
