STD Tuning Drivetrain Swapping rear cover between 717.4XX transmissions
03-26-2012, 03:09 PM #1
Hi!
I've aquired a reasonably priced 717.417 5-speed out of a W202 C-Class. Now the thing is - it doesn't have any speedo drive.
I will probably have to fit the rear cover of a W124 5-spd. trans. (.411 or .412).
What I don't know - are the rear covers interchangeable?
[Image: gb1.jpg]
(W123 early 4spd, W123 gas 4spd, W202 5spd)
Thanks a lot in advance! Smile
Jan
DiseaselWeasel
Hi!
[Image: gb1.jpg]
Jan
03-27-2012, 08:00 AM #2
how does the speedo work on the 202 5-speed? is it a sensor?
Im wondering if that might be really complex, like the covers might work, but the newer 5-speed may not have a worm gear on the output shaft for a speedo cable.
Might be a major job to retrofit it back to a cable speedo, might be easier to grab a W202 speedometer gauge and wire that into your older dash than to retrofit the newer gearbox with something to drive a speedo cable
03-27-2012, 02:13 PM #3
(03-27-2012, 08:00 AM)dropnosky how does the speedo work on the 202 5-speed? is it a sensor?
I guess - but not on the gearbox... My guess is it uses one of the ABS sensors? As there's nothing on the gearbox itself.
(03-27-2012, 08:00 AM)dropnosky Im wondering if that might be really complex, like the covers might work, but the newer 5-speed may not have a worm gear on the output shaft for a speedo cable.
All I need is a socket for the output flange nut... Dodgy Then I'd see if there is.
(03-27-2012, 08:00 AM)dropnosky Might be a major job to retrofit it back to a cable speedo, might be easier to grab a W202 speedometer gauge and wire that into your older dash than to retrofit the newer gearbox with something to drive a speedo cable
The W202 has that awefull digital mile counter, though... Undecided
Thanks for your reply!
Looks like I'll just have to give it a go Smile
Jan
This post was last modified: 03-27-2012, 02:19 PM by DiseaselWeasel.
DiseaselWeasel
Jan
04-02-2012, 06:44 AM #4
Oh and btw; can you see the possibilities here? Wink
[Image: diesel.jpg]
DiseaselWeasel
[Image: diesel.jpg]
EDH_Performance
04-13-2012, 02:30 AM #5
Both covers are easy to swap! And just swap the drivewheel for the speedo gear and you are good to go! Done it heaps of timesWink
EDH_Performance
04-13-2012, 02:38 PM #6
the w124/w126 speedometer are electric and have a normal odometer
04-24-2012, 05:22 AM #7
Which ones do have a electronic speedo?
(04-13-2012, 02:30 AM)EDH_Performance Both covers are easy to swap! And just swap the drivewheel for the speedo gear and you are good to go! Done it heaps of timesWink
Thanks! That's what I was hoping to hear Big Grin Off to buy more gearboxes...
Cheers,
Jan
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Cheers,
Jan
04-24-2012, 03:25 PM #8
All w124 / w126 chassis Mercedes 300e 300d / 300sd,sdl 560se,sel,sec 500se,sel,sec 380se,sel,sec 280se,sel are electric speedometer pick up auto or manual
aaa
04-24-2012, 05:01 PM #9
Most w124s are cable driven. The 500e has an electronic speedo, might be the same system as the w202s (not sure where the pickup is).
aaa
04-25-2012, 06:31 AM #10
This is great news! Dieselweasel, post some pics if and when you do it!
Big Grin
Big Grin
04-25-2012, 03:24 PM #11
I will. Could be a while, though... I'm hopefully getting a W123 diesel 5-speed by tomorrow. But... My W124 200TE wagon could do with a 5-speed. If I don't swap that for a 250TD... Big Grin Oh well, how quickly things can change. I'll keep you updated!
DiseaselWeasel
04-29-2012, 06:59 AM #12
Got a 5 speed kit now. Only missing the gearbox crossmember.
[Image: 5gkit.jpg]
But by the looks of things I can use a auto-crossmember:
L to R: W123 4spd | W202 5spd | W123 5spd | W123/W115 auto
[Image: 5g11.jpg]
(Quick montage of 3 pics)
DiseaselWeasel
[Image: 5gkit.jpg]
[Image: 5g11.jpg]
serverman777
04-30-2012, 10:48 AM #13
Whats up with that sticker on the w202 trans? 186?
'84 300 SD w126 Race Car Wink
'85 500 SEL w126 Scraped
serverman777
04-30-2012, 01:41 PM #14
I don't know. Maybe a reference tag from/for production?
DiseaselWeasel
05-16-2012, 02:02 AM #15
Number 6 arrived. This time a 717.435 from a 190E 2.6.
[Image: 717435-1.jpg]
Question: is this for DM or SM flywheel??
[Image: 717435-3.jpg]
DiseaselWeasel
aaa
05-16-2012, 03:47 AM #16
Hard to tell how long that shaft is from that pic. I'm guessing single mass. If you can see the tip of the shaft extending beyond the bellhousing, it would be single mass.
aaa
05-16-2012, 01:27 PM #17
(05-16-2012, 03:47 AM)aaa If you can see the tip of the shaft extending beyond the bellhousing, it would be single mass.
The shaft certainly islonger than the bellhousing. Hmmm... My W202 gearbox is the same - does this mean it's SMF too!? It's from a 1998 C180. But I thought the C180 got the DMF by 1996 too?? Hmm...
Thanks!
Cheers,
Jan
DiseaselWeasel
Thanks!
Cheers,
Jan
05-18-2012, 07:10 AM #18
Another difference in the rear covers...
Left: 717.411 (W124). Right: 717.435 (W201 2.6):
[Image: 5g7.jpg]
DiseaselWeasel
[Image: 5g7.jpg]
