STD Tuning Engine warner borg matchbot
Turbo
04-04-2012, 04:52 PM #1
I sat down and was analyse my upcoming project and this was informative in some ways but you really need to be careful because the input have a pretty big impact of the out put, and some of the input is just better guessing
Though I do hope that Garrett will have this feature soon because I am little curious about what I would be able to do with the GTX****R series, specially if I will rebuild two turbocharger with AVNT system on both, but like always taste comes with cost, in that case little bit too expensive
I can not say That I am really happy about the turbocharger I found for the 4000-6000rpm from Warner Borg but it do seams to works
anyone else with some experience with this modelling?
You can see what I was starting to do if you paste below address
http://www.turbodriven.com//performancet...rsin=92044&
give it another try
[/quote]
can not make it work
This site does not want to show all the url, it is quite long since it have a lot of information, if I edit the topic it is all there but not when I look what I have posted like everybody else sees, any one know what I have made wrong?
This post was last modified: 04-04-2012, 05:00 PM by Turbo.
Turbo
give it another try
[/quote]
aaa
04-04-2012, 05:51 PM #2
Use code tags, not quote tags. Of course it's way easier to just click on the link and see the numbers on the website.
aaa
Turbo
04-05-2012, 12:29 AM #3
Thanks
The link is actually it is working properly, I just presume that since not the complete address could not been seen it was not working Blush
Turbo
Thanks
