STD Tuning Engine 606 head gasket on a 603
  • 1 Vote(s) - 5 Average
winequip_td
05-09-2012, 09:57 PM #1
When installing the MLS gasket from a 606 on a 603 besides from modifying a couple of holes what torque specs do I use? the 606 or 603 ones?
winequip_td
dieselmerc
05-11-2012, 09:11 AM #2
they are the same, my advice is to put on a 603 gasket, you will have problems with mls, due to the "expand creeks" or what to call them betwen the cylinders. combustion leaks in to them when using mls and you get pressure in water system =no good
dieselmerc
winequip_td
08-19-2012, 08:11 PM #3
Here are some pictures of my modified 606 gasket installed on a 603
winequip_td
aaa
08-19-2012, 10:23 PM #4
The pictures are not there.
aaa
dieselmerc
08-20-2012, 07:58 AM #5
my advice is to run stock 603 gasket
dieselmerc
winequip_td
08-25-2012, 11:46 PM #6
Sorry for some reason It didn't post.
The copper stuff is head gasket spray, don't worry about the over-spray on the pistons I cleaned that afterwards.
This post was last modified: 08-25-2012, 11:55 PM by winequip_td.
winequip_td
Siekkinen
08-30-2012, 03:04 PM #7
(05-11-2012, 09:11 AM)dieselmerc they are the same, my advice is to put on a 603 gasket, you will have problems with mls, due to the "expand creeks" or what to call them betwen the cylinders. combustion leaks in to them when using mls and you get pressure in water system =no good
That is so true. I put om603 original gasket with copper clue to my car and its still working Big Grin I have heard so many time about those om606 gaskets because they just dont work and makes pressure to cooling system almost immediately after first start or after couple days. If you still want to use it, careful installation is the key to succeed. Sometimes they work Big Grin
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
mantahead
08-30-2012, 03:18 PM #8
hi,
has anyone tried a copper gasket on 603 or 606?
what gasket you recommend for 606(standard mls?)
mantahead
hi,
Siekkinen
08-31-2012, 08:29 AM #9
(08-30-2012, 03:18 PM)mantahead hi,
One guy here in finland tried a copper gasket and its much worse than om606 gasket Big Grin it didnt work at all. For 606 you should put original gasket. But there is same problem that is with 603 engine. Head and block both need to be extremely straight or gasket wont hold pressure. You could put copper clue on both sides of the gasket to get better chance to succeed.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
mantahead
08-31-2012, 08:40 AM #10
(08-31-2012, 08:29 AM)Siekkinen
hi
some people say that the copper gaskets have to be heated and tempered before they are put on.??
mantahead
hi
Siekkinen
08-31-2012, 08:48 AM #11
(08-31-2012, 08:40 AM)mantahead some people say that the copper gaskets have to be heated and tempered before they are put on.??
I think that he did everything possible to get it working. I am using 603 gasket with glue and it holds 2,2bar (32psi) boost easily. And thats enough to get 400hp/650Nm with hx40 holset. Big Grin
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
dieselmerc
08-31-2012, 02:14 PM #12
on 606 original headgasketis good
dieselmerc
mantahead
08-31-2012, 04:15 PM #13
hi,
do you guys run standard compression ratio?
Whats the advantages of lower CR apart from running more boost?
mantahead
hi,
Siekkinen
08-31-2012, 05:43 PM #14
(08-31-2012, 04:15 PM)mantahead hi,
Yes we use standard CR. You dont need to lower it if you arent really building a drag car Big Grin bigger and lighter valves and better valve springs are needed if you want more than 550-600 horsepower from 606 but compression ratio is thing that you dont need to worry about.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
winequip_td
09-06-2012, 08:02 PM #15
Has anyone tried this before me with any success? I glued the gasket down as well as disassembling the gasket and gluing each layer. I can't see why it would not work it works for the 606 with success.
winequip_td
aaa
09-06-2012, 08:23 PM #16
The MLS is more sensitive to how good your surfaces are. The specs for surface quality when machining 606 heads are slightly stricter than 603 heads.
aaa
dieselmerc
09-08-2012, 03:58 AM #17
it doesent work because 603 has "expand" creeks betwen the cylinders wich is the engine coolant water, and some of the compression leaks betwen cylinders and the coolant gets pressurized. 606 doesn´t have those "creeks" so theay usualy to get some leak betwem cylinders but it doesn´t matter on them
This post was last modified: 09-08-2012, 03:59 AM by dieselmerc.
dieselmerc
