STD Tuning Engine balanced performance injectors, check. Now ...
300SD_KY
super turbo diesel
121
05-18-2012, 08:15 PM #1
i'm looking to upgrade:
a. my injector pump: dieselmenken, you've got my attention. i'm running 65-cetane biodiesel. Others?
plus add
b. a performance aftermarket electronic fuel pump
denso aeromotive walpro ... chime in
300SD_KY
plus add
05-19-2012, 01:44 AM #2
Walbro*
They make AWESOME fuel pumps for the money. GSL 392 is the one I like and have used for years.
http://www.gsl392.com/
Walbro*
yatzee
05-19-2012, 08:30 AM #3
how many extra psi is ideal when building up a car?
1991 350SDL, burning oil and slow
1991 500SL, yet another project car
1984 190D, swapped 3.6 m104 with a megasquirt
yatzee
Purplecomputer
Slowness 220D
897
05-19-2012, 08:35 AM #4
(05-19-2012, 01:44 AM)Captain America Walbro*
not to hijack this thread, but why would adding a fuel pump help? I thought pushing more fuel makes the car smoke.
Purplecomputer
yatzee
05-19-2012, 08:44 AM #5
(05-19-2012, 08:35 AM)Purplecomputer not to hijack this thread, but why would adding a fuel pump help? I thought pushing more fuel makes the car smoke.
On pre 2004 tdi's, it helps responsiveness and reduces the strain on the IP - I assume it's the same with these cars? I'm curious what 1 of the vets says.
yatzee
Purplecomputer
Slowness 220D
897
05-19-2012, 09:47 AM #6
(05-19-2012, 08:44 AM)yatzee
Me too, I would like to know if that would help on an old 240D
Purplecomputer
05-21-2012, 02:13 AM #7
On my 300's I have always battled getting enough fuel to the IP. Seems as though any little restriction or negative pressure in the tank starves the engine. There are many threads where guys have only measured about 10 psi @ the IP inlet. With around 30 psi, the car(s) responded and ran much better. If it smoke, you just need more boost, thats all. More fuel will help a 616 engine too, just not as much as a 617a
Plus the lifter pump is a horsepower parasite.
This post was last modified: 05-21-2012, 02:14 AM by Captain America.
w123love
Stockish
354
05-21-2012, 03:21 PM #8
I’ve been considering bypassing my lift pump since I put in my Walbro pump a while ago. It seems to get starved of fuel the lower it gets in my tank, mostly at low RPM’s. Is that a bad idea? The FRC-8 I have is supposed to push at 30 PSI.
The VEGEWGN
w123love
The VEGEWGN
05-21-2012, 03:30 PM #9
What do you mean it gets starved of fuel? A fuel pump will only make pressure based on a restriction in the line. Most inline EFI pumps will make 100psi if that is what you restrict the line to. OK the FRC -8 will make 9-12 psi if you dead head the line (no return) and flow 28gph
This post was last modified: 05-21-2012, 03:34 PM by Captain America.
05-23-2012, 02:57 AM #10
Why not adjust/replace the spring or whatever in the stock lift pump that gets worn out, to get the fuel pressure back up?
ronnie
05-24-2012, 08:47 PM #11
that's what I did, replaced the fuel pump spring with one from a 617a(i have a 616), and the relief valve spring. With some stretching on the relief valve spring I am now running 28psi at cruising speed, about 25 at full throttle.
I would have to wonder how much power the lift pump takes? It would seem to me not enough to worry about unless every single hp mattered.
ronnie
05-25-2012, 02:13 AM #12
(05-24-2012, 08:47 PM)ronnie that's what I did, replaced the fuel pump spring with one from a 617a(i have a 616), and the relief valve spring. With some stretching on the relief valve spring I am now running 28psi at cruising speed, about 25 at full throttle.
Agreed. How much did you stretch the spring?
ronnie
05-25-2012, 05:46 AM #13
less then a 1/4" or so if I remember right.
ronnie
