STD Tuning Body Mods Double din
Double din
Double din
83300d
05-28-2012, 08:12 PM #1
Not a body mod, but checking out my center console for a double din DVD player and wondered if anyone has done one already? Trying to avoid the pitfalls traps etc etc
Afraid to post this on benzworld and offend the purists Undecided
83300d
w123love
Stockish
354
05-28-2012, 09:45 PM #2
Double din obviously would not go in without some serious modifying of the console, particularly around the the AC controls (obviously). One may consider the possibility of a DVD player head unit that has a screen that rotates out of a single DIN unit. They are much more expensive of course, but could be a solution given the head unit has enough room in the rear.
[Image: Universal_Single_Din_w_7_inch_GPS_Sat_Navigation.jpg]
The VEGEWGN
w123love
The VEGEWGN
83300d
05-29-2012, 02:55 AM #3
Used to run a car audio install company, so thinking its just a matter of relocating the heater controls but haven't opened up the console yet. Will keep you informed
83300d
05-29-2012, 07:43 AM #4
The heater controls are electrical vacuum switches-they don't need 2 bays to operate. You will spend some time but they can be chopped down.
05-29-2012, 09:04 AM #5
(05-29-2012, 07:43 AM)Simpler=Better The heater controls are electrical vacuum switches-they don't need 2 bays to operate. You will spend some time but they can be chopped down.
what would be extremely cool is if made a touch screen page that looked like the heater controls from the stock setup, but you could control them through the screen layout and just eliminate the stock controls behind the screen.
w123love
Stockish
354
05-29-2012, 01:42 PM #6
I would really like to see someone go the route of messing with the HVAC controls. I’m too much of a wimp to attempt to even try to get my AC to work. But it would be a real milestone if one was able to get a touch screen in there.
The VEGEWGN
w123love
The VEGEWGN
05-29-2012, 02:48 PM #7
You could remove the ash tray and use that area!
83300d
05-29-2012, 08:55 PM #8
Ya was thinking remove the ashtray - dont smoke anyways - move the heater controls down there and install the double din where the heater controls and stereo currently sit.
Would put the screen up higher and in plain sight, and not have to cut up the heater controls too much - already got a second set of controls to play with - other than trying to install a boost gauge or something right in the middle.
Going to tear it apart next week - I work 4 on and 4 off and heading back to work tonight so no time this week - and measure it all up. Might have to buy some real wood to make the center console, or some carbon fiber looking paper to finish it off.
Will post pictures when its done incase someone else wants to try
83300d
mbz123
11-14-2012, 03:53 AM #9
(05-29-2012, 08:55 PM)83300d Ya was thinking remove the ashtray - dont smoke anyways - move the heater controls down there and install the double din where the heater controls and stereo currently sit.
Any progress with this? Looking into doing same.
mbz123
83300d
11-20-2012, 09:10 PM #10
Yes I am trying to decide how to finish it off - woodgrain or otherwise. When I get a moment I will post some pictures.
83300d
300td
11-29-2012, 10:18 PM #11
(05-28-2012, 08:12 PM)83300d Not a body mod, but checking out my center console for a double din DVD player and wondered if anyone has done one already? Trying to avoid the pitfalls traps etc etc
in my 85 300td i put in a double din by removing the ashtray. i also had to cut pieces of the dashboard off but they were behind the ashtray any ways so you cant see that i cut anything
i took off my ac controls to see if i could put my headunit in that space but there was a bunch of electrical crap right behind it, how did you get around them? did you move all the elecrical stuff or did you set the headunit a lower to clear the elecrtics, cause right now my head unit is down where the ashtray is, but i would like to move it up to where the ac controls are
This post was last modified: 11-29-2012, 10:28 PM by 300td.
love my w123 Heart
really want a w114 Sad
300td
love my w123 Heart
jellydonut
1987 W124 250D
21
10-09-2013, 07:12 PM #12
You could try to find a taxi console on ebay or something.
[Image: A6WyATZ.jpg]
It's bigger than double DIN, but they usually come with an insert that make them double DIN. The ash tray is moved to the rear with a cool hatch that opens front and back. I imagine it would be nice for hiding switches for stuff.
I have this in my W124, which I am regrettably having to scrap due to rust. Sad
jellydonut
