STD Tuning Drivetrain Gearbox Controller 722.6 ver 2
  • 2 Vote(s) - 5 Average
whipplem104
06-30-2015, 05:05 PM #139
Just an add to what Ole said, and I assume it is the same with his controller, that the set rpm is when the solenoids are activated. So you need to know the time it takes to start to pull the shift down. For instance it may be .5 seconds to fill the clutch and start to pull down the rpm. Depending on your acceleration speed during this time you would adjust for this. So say in 1st gear you are accelerating at 1000rpm per second. With the .5 second scenario you would target your wot rpm shift point at 500 rpm below your target rpm. In 2nd you will be accelerating slower but you would have potentially a slower or faster fill for the different clutch. So again log the rpm acceleration and dial in from there. I do not know if this controller has logging but this is the easiest way to do this. Start well shy of your target rpm and then log and then adjust appropriately. You then may have to make some very small changes for the fact that you are at a different rpm/torque value and close the gap.
whipplem104
Messages In This Thread
Gearbox Controller 722.6 ver 2 - by olefejer - 06-02-2012, 04:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2012, 03:06 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-03-2012, 08:05 PM
RE: Gearbox Controller 722.6 ver 2 - by HoleshotHolset - 06-06-2012, 12:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-06-2012, 12:45 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 06-07-2012, 01:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-08-2012, 05:36 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-10-2012, 09:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2012, 12:11 PM
RE: Gearbox Controller 722.6 ver 2 - by Kozuka - 06-11-2012, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-12-2012, 01:32 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 06-13-2012, 02:04 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-20-2012, 02:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-20-2012, 03:10 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-21-2012, 05:40 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-22-2012, 04:31 PM
RE: Gearbox Controller 722.6 ver 2 - by Turbo - 07-02-2012, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-03-2012, 03:28 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-09-2012, 12:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-30-2012, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-30-2012, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 07:50 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 09-18-2012, 07:58 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 09:45 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-19-2012, 10:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-20-2012, 10:51 AM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-20-2012, 06:36 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-21-2012, 01:11 PM
RE: Gearbox Controller 722.6 ver 2 - by kotka - 09-24-2012, 09:53 AM
RE: Gearbox Controller 722.6 ver 2 - by JustPassinThru - 09-24-2012, 12:19 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-03-2012, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 10-08-2012, 11:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2012, 10:19 AM
RE: Gearbox Controller 722.6 ver 2 - by GWG001 - 10-16-2012, 06:53 AM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-16-2012, 01:37 PM
RE: Gearbox Controller 722.6 ver 2 - by DirtDiesel - 10-21-2012, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 10-21-2012, 02:15 PM
RE: Gearbox Controller 722.6 ver 2 - by hean500e - 01-17-2013, 11:10 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-19-2013, 02:37 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-19-2013, 03:13 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 01-24-2013, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-26-2013, 03:46 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-29-2013, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-30-2013, 11:38 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 12:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-01-2013, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 02-02-2013, 03:35 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-02-2013, 12:33 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 09:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-02-2013, 01:17 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-03-2013, 07:11 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-03-2013, 08:31 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 09:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 02:44 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 03:41 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 04:04 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 02-14-2013, 01:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-14-2013, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 02-14-2013, 09:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-15-2013, 01:41 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-17-2013, 02:11 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2013, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-18-2013, 05:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-21-2013, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-22-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-23-2013, 04:40 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-23-2013, 09:25 AM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 03-13-2013, 10:44 AM
RE: Gearbox Controller 722.6 ver 2 - by SurfRodder - 03-13-2013, 08:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 04:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-18-2013, 07:47 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 11:57 PM
RE: Gearbox Controller 722.6 ver 2 - by SuperCow - 03-21-2013, 08:55 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-21-2013, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-22-2013, 02:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-22-2013, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 03-23-2013, 01:34 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-26-2013, 02:41 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-26-2013, 11:28 AM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 03-27-2013, 06:52 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-10-2013, 09:42 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-12-2013, 06:22 AM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-12-2013, 09:51 PM
RE: Gearbox Controller 722.6 ver 2 - by oleg213 - 07-20-2013, 01:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-21-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by _siim_ - 11-17-2013, 10:13 AM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 02-12-2014, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-12-2014, 04:48 AM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 08-08-2014, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 08-08-2014, 08:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-09-2014, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 08:02 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 08:14 AM
RE: Gearbox Controller 722.6 ver 2 - by peter - 12-07-2014, 07:46 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 04:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 06:11 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 12-19-2014, 09:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 12:32 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 12-19-2014, 06:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 06:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-21-2015, 10:42 PM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-22-2015, 02:57 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-22-2015, 04:01 AM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-24-2015, 01:44 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-25-2015, 06:30 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-25-2015, 04:43 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 05:08 PM
RE: Gearbox Controller 722.6 ver 2 - by THE DIGGER - 01-26-2015, 01:48 PM
RE: Gearbox Controller 722.6 ver 2 - by F.R.A.S - 01-26-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-26-2015, 09:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-27-2015, 03:45 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-27-2015, 11:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-28-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 01:00 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-31-2015, 04:17 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-31-2015, 01:57 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 07:41 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 02-08-2015, 04:38 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-09-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 03-03-2015, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-03-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-06-2015, 10:10 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-06-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by tgg416 - 03-20-2015, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:24 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-25-2015, 06:42 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:57 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-26-2015, 08:42 AM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-26-2015, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by swecias - 05-25-2015, 05:23 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-25-2015, 05:46 AM
RE: Gearbox Controller 722.6 ver 2 - by DiseaselWeasel - 05-28-2015, 12:26 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-28-2015, 04:09 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-29-2015, 03:30 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-29-2015, 09:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 06-30-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Henning Bruun - 07-01-2015, 01:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-05-2015, 07:34 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 06:38 AM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 07-17-2015, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-14-2015, 04:27 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-14-2015, 07:40 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-15-2015, 07:27 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 08-16-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-16-2015, 11:31 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-17-2015, 06:07 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 02:59 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-22-2015, 07:28 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 10:04 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-23-2015, 06:21 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 08-16-2015, 12:17 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-17-2015, 06:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-18-2015, 03:16 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:25 PM
RE: Gearbox Controller 722.6 ver 2 - by m1tch - 08-20-2015, 02:10 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-21-2015, 01:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 09:55 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-24-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 01:51 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-25-2015, 10:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 03:17 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-28-2015, 05:36 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:44 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-12-2015, 11:12 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-12-2015, 01:39 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-04-2015, 03:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 09-04-2015, 05:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-05-2015, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 09-05-2015, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by INC - 09-06-2015, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-06-2015, 10:34 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-09-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-10-2015, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-10-2015, 06:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-11-2015, 01:18 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-11-2015, 12:18 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-11-2015, 03:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-10-2015, 01:47 PM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 10-06-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:08 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 06:46 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:13 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 10-11-2015, 07:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 10-13-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by wanger - 10-16-2015, 02:51 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 10-16-2015, 10:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:55 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-26-2015, 03:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-26-2015, 12:48 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-28-2015, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 04:28 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 03:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-03-2016, 03:31 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:36 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 01-03-2016, 05:52 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-03-2016, 05:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-04-2016, 11:48 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-05-2016, 08:15 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-06-2016, 07:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-07-2016, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-08-2016, 02:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-08-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-06-2016, 11:58 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-09-2016, 05:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 02:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 02:25 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 07:39 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-11-2016, 12:59 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:31 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 03-11-2016, 08:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:23 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-12-2016, 03:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-13-2016, 06:20 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 03-12-2016, 03:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-13-2016, 08:58 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 05-18-2016, 03:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2016, 10:40 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-02-2016, 03:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-03-2016, 03:24 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-22-2016, 03:32 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-22-2016, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-28-2016, 03:26 AM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-06-2016, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 01:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 02:56 PM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-08-2016, 05:14 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2016, 04:27 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-06-2016, 07:06 PM
RE: Gearbox Controller 722.6 ver 2 - by elvis100 - 06-25-2016, 05:54 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-14-2016, 02:18 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 05:49 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 08:40 PM
RE: Gearbox Controller 722.6 ver 2 - by ho55 - 09-15-2016, 04:08 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-18-2017, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2017, 12:07 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-21-2017, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-22-2017, 01:16 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:01 AM
RE: Gearbox Controller 722.6 ver 2 - by hents99 - 05-18-2017, 05:32 AM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:33 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2017, 04:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-20-2017, 02:19 AM
RE: Gearbox Controller 722.6 ver 2 - by 606110 - 06-25-2017, 04:00 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2017, 03:37 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 07-04-2017, 04:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-01-2017, 02:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-03-2017, 03:49 PM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 11-30-2017, 02:31 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-06-2017, 12:53 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-05-2017, 08:12 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-05-2017, 07:19 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-06-2017, 02:56 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-06-2017, 01:15 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-06-2018, 03:08 AM
RE: Gearbox Controller 722.6 ver 2 - by 3zooz - 06-20-2020, 02:20 PM
 14 Guest(s)
 14 Guest(s)
