STD Tuning Drivetrain Gearbox Controller 722.6 ver 2
  • 2 Vote(s) - 5 Average
olefejer
09-05-2015, 02:44 AM #172
(08-28-2015, 05:36 AM)jupel Hello all!
After 1500 km driving with Ole's controller I have to say - it's usefull thing, but It's need shift firmness calibration table - both rpm, tps 10x10 point at least, because 10 point is not enought. In that case shifting in high or low rpm with the same trottle would be not the same. Smoth shift on high load and kick on the low load with equal tps position or smooth shift and sliding on high load. When it sliding it's look like this - speedoometr jump up, gears shifting 3-4-5, or 4-5 depending of current gear and your car, in fackt, driving on 1st gear despite of the "5" gear indicator displayed.
update: Ole, is it ok, that odometr count mielage when car is  stopped? very slowly anyway
first 10 x 10 point is a lot to play width, but ok it is a suggestion, and thanks for all suggestion, a lot of feature in the controller is from suggestion in here.
Yes when you shift in manual the hardness is not the same depending on RPM. they gets harder when high RPM correct. i will keep that in mind. if i find a solution for that.
In Automatic mode it is better as a specifik TPS point is linked to a specifik Speed. = almost a specifik RPM shift point.
the 3-4 shift jump up in RPM is normal,
but 4-5 is normally weary good, i have not on any car i have driven seen jump in 4-5 try to use "Rate Last shift" if it jump 4-5 tell it was to soft, do it more time if required.
Regarding you gear indicator not Working, write me direct, we can try to solve it.
As you use probably internal speed, it can be that its count slowly have to check, but it is not my intention.
1996 MB SL320 Now OM606 7 mm pump elements (myna), KKD manifold, HE341VE, 3,5" downpipe, 3" exhaust, big IC, 722.6 gearbox controller, also controls (Turbo VNT, EGT, BOOST, EGP.)
olefejer
Messages In This Thread
Gearbox Controller 722.6 ver 2 - by olefejer - 06-02-2012, 04:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2012, 03:06 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-03-2012, 08:05 PM
RE: Gearbox Controller 722.6 ver 2 - by HoleshotHolset - 06-06-2012, 12:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-06-2012, 12:45 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 06-07-2012, 01:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-08-2012, 05:36 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-10-2012, 09:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2012, 12:11 PM
RE: Gearbox Controller 722.6 ver 2 - by Kozuka - 06-11-2012, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-12-2012, 01:32 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 06-13-2012, 02:04 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-20-2012, 02:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-20-2012, 03:10 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-21-2012, 05:40 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-22-2012, 04:31 PM
RE: Gearbox Controller 722.6 ver 2 - by Turbo - 07-02-2012, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-03-2012, 03:28 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-09-2012, 12:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-30-2012, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-30-2012, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 07:50 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 09-18-2012, 07:58 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 09:45 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-19-2012, 10:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-20-2012, 10:51 AM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-20-2012, 06:36 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-21-2012, 01:11 PM
RE: Gearbox Controller 722.6 ver 2 - by kotka - 09-24-2012, 09:53 AM
RE: Gearbox Controller 722.6 ver 2 - by JustPassinThru - 09-24-2012, 12:19 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-03-2012, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 10-08-2012, 11:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2012, 10:19 AM
RE: Gearbox Controller 722.6 ver 2 - by GWG001 - 10-16-2012, 06:53 AM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-16-2012, 01:37 PM
RE: Gearbox Controller 722.6 ver 2 - by DirtDiesel - 10-21-2012, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 10-21-2012, 02:15 PM
RE: Gearbox Controller 722.6 ver 2 - by hean500e - 01-17-2013, 11:10 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-19-2013, 02:37 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-19-2013, 03:13 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 01-24-2013, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-26-2013, 03:46 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-29-2013, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-30-2013, 11:38 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 12:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-01-2013, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 02-02-2013, 03:35 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-02-2013, 12:33 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 09:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-02-2013, 01:17 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-03-2013, 07:11 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-03-2013, 08:31 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 09:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 02:44 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 03:41 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 04:04 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 02-14-2013, 01:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-14-2013, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 02-14-2013, 09:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-15-2013, 01:41 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-17-2013, 02:11 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2013, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-18-2013, 05:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-21-2013, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-22-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-23-2013, 04:40 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-23-2013, 09:25 AM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 03-13-2013, 10:44 AM
RE: Gearbox Controller 722.6 ver 2 - by SurfRodder - 03-13-2013, 08:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 04:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-18-2013, 07:47 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 11:57 PM
RE: Gearbox Controller 722.6 ver 2 - by SuperCow - 03-21-2013, 08:55 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-21-2013, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-22-2013, 02:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-22-2013, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 03-23-2013, 01:34 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-26-2013, 02:41 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-26-2013, 11:28 AM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 03-27-2013, 06:52 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-10-2013, 09:42 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-12-2013, 06:22 AM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-12-2013, 09:51 PM
RE: Gearbox Controller 722.6 ver 2 - by oleg213 - 07-20-2013, 01:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-21-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by _siim_ - 11-17-2013, 10:13 AM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 02-12-2014, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-12-2014, 04:48 AM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 08-08-2014, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 08-08-2014, 08:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-09-2014, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 08:02 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 08:14 AM
RE: Gearbox Controller 722.6 ver 2 - by peter - 12-07-2014, 07:46 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 04:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 06:11 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 12-19-2014, 09:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 12:32 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 12-19-2014, 06:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 06:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-21-2015, 10:42 PM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-22-2015, 02:57 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-22-2015, 04:01 AM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-24-2015, 01:44 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-25-2015, 06:30 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-25-2015, 04:43 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 05:08 PM
RE: Gearbox Controller 722.6 ver 2 - by THE DIGGER - 01-26-2015, 01:48 PM
RE: Gearbox Controller 722.6 ver 2 - by F.R.A.S - 01-26-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-26-2015, 09:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-27-2015, 03:45 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-27-2015, 11:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-28-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 01:00 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-31-2015, 04:17 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-31-2015, 01:57 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 07:41 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 02-08-2015, 04:38 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-09-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 03-03-2015, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-03-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-06-2015, 10:10 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-06-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by tgg416 - 03-20-2015, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:24 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-25-2015, 06:42 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:57 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-26-2015, 08:42 AM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-26-2015, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by swecias - 05-25-2015, 05:23 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-25-2015, 05:46 AM
RE: Gearbox Controller 722.6 ver 2 - by DiseaselWeasel - 05-28-2015, 12:26 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-28-2015, 04:09 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-29-2015, 03:30 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-29-2015, 09:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 06-30-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Henning Bruun - 07-01-2015, 01:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-05-2015, 07:34 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 06:38 AM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 07-17-2015, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-14-2015, 04:27 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-14-2015, 07:40 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-15-2015, 07:27 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 08-16-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-16-2015, 11:31 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-17-2015, 06:07 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 02:59 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-22-2015, 07:28 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 10:04 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-23-2015, 06:21 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 08-16-2015, 12:17 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-17-2015, 06:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-18-2015, 03:16 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:25 PM
RE: Gearbox Controller 722.6 ver 2 - by m1tch - 08-20-2015, 02:10 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-21-2015, 01:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 09:55 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-24-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 01:51 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-25-2015, 10:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 03:17 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-28-2015, 05:36 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:44 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-12-2015, 11:12 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-12-2015, 01:39 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-04-2015, 03:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 09-04-2015, 05:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-05-2015, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 09-05-2015, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by INC - 09-06-2015, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-06-2015, 10:34 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-09-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-10-2015, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-10-2015, 06:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-11-2015, 01:18 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-11-2015, 12:18 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-11-2015, 03:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-10-2015, 01:47 PM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 10-06-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:08 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 06:46 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:13 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 10-11-2015, 07:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 10-13-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by wanger - 10-16-2015, 02:51 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 10-16-2015, 10:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:55 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-26-2015, 03:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-26-2015, 12:48 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-28-2015, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 04:28 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 03:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-03-2016, 03:31 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:36 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 01-03-2016, 05:52 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-03-2016, 05:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-04-2016, 11:48 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-05-2016, 08:15 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-06-2016, 07:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-07-2016, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-08-2016, 02:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-08-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-06-2016, 11:58 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-09-2016, 05:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 02:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 02:25 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 07:39 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-11-2016, 12:59 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:31 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 03-11-2016, 08:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:23 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-12-2016, 03:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-13-2016, 06:20 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 03-12-2016, 03:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-13-2016, 08:58 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 05-18-2016, 03:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2016, 10:40 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-02-2016, 03:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-03-2016, 03:24 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-22-2016, 03:32 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-22-2016, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-28-2016, 03:26 AM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-06-2016, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 01:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 02:56 PM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-08-2016, 05:14 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2016, 04:27 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-06-2016, 07:06 PM
RE: Gearbox Controller 722.6 ver 2 - by elvis100 - 06-25-2016, 05:54 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-14-2016, 02:18 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 05:49 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 08:40 PM
RE: Gearbox Controller 722.6 ver 2 - by ho55 - 09-15-2016, 04:08 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-18-2017, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2017, 12:07 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-21-2017, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-22-2017, 01:16 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:01 AM
RE: Gearbox Controller 722.6 ver 2 - by hents99 - 05-18-2017, 05:32 AM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:33 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2017, 04:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-20-2017, 02:19 AM
RE: Gearbox Controller 722.6 ver 2 - by 606110 - 06-25-2017, 04:00 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2017, 03:37 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 07-04-2017, 04:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-01-2017, 02:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-03-2017, 03:49 PM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 11-30-2017, 02:31 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-06-2017, 12:53 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-05-2017, 08:12 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-05-2017, 07:19 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-06-2017, 02:56 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-06-2017, 01:15 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-06-2018, 03:08 AM
RE: Gearbox Controller 722.6 ver 2 - by 3zooz - 06-20-2020, 02:20 PM
 10 Guest(s)
 10 Guest(s)
