STD Tuning Drivetrain Gearbox Controller 722.6 ver 2
  • 2 Vote(s) - 5 Average
olefejer
02-18-2017, 12:07 PM #254
(02-18-2017, 08:37 AM)jupel Hi Ole! Is it possible, to take signal from abs on old revision controller? I try to make it, but it work unstable, and as i see the signal from abs sensor must be divided by 3? Can you help to solve it?
Hi
Yes no-matter how old the controller is you can connect it to ABS, sensor
But correct the newest ones has a real automotive ABS sensor chip that is used for both external Speed and RPM, that is more immune to noise then the older type.
If the speed show 3 times to much, you goto
"Setup Parameters" -> "External speed %"  standart is 100 set it to 33
Then test and see if it fits,
1996 MB SL320 Now OM606 7 mm pump elements (myna), KKD manifold, HE341VE, 3,5" downpipe, 3" exhaust, big IC, 722.6 gearbox controller, also controls (Turbo VNT, EGT, BOOST, EGP.)
olefejer
Hi
Messages In This Thread
Gearbox Controller 722.6 ver 2 - by olefejer - 06-02-2012, 04:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2012, 03:06 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-03-2012, 08:05 PM
RE: Gearbox Controller 722.6 ver 2 - by HoleshotHolset - 06-06-2012, 12:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-06-2012, 12:45 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 06-07-2012, 01:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-08-2012, 05:36 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 06-10-2012, 09:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2012, 12:11 PM
RE: Gearbox Controller 722.6 ver 2 - by Kozuka - 06-11-2012, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-12-2012, 01:32 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 06-13-2012, 02:04 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-20-2012, 02:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-20-2012, 03:10 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 06-21-2012, 05:40 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-22-2012, 04:31 PM
RE: Gearbox Controller 722.6 ver 2 - by Turbo - 07-02-2012, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-03-2012, 03:28 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-09-2012, 12:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-30-2012, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 07-30-2012, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 07:50 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 09-18-2012, 07:58 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-18-2012, 09:45 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-19-2012, 10:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-20-2012, 10:51 AM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 09-20-2012, 06:36 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-21-2012, 01:11 PM
RE: Gearbox Controller 722.6 ver 2 - by kotka - 09-24-2012, 09:53 AM
RE: Gearbox Controller 722.6 ver 2 - by JustPassinThru - 09-24-2012, 12:19 PM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-03-2012, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by thegooch27 - 10-08-2012, 11:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2012, 10:19 AM
RE: Gearbox Controller 722.6 ver 2 - by GWG001 - 10-16-2012, 06:53 AM
RE: Gearbox Controller 722.6 ver 2 - by 2996 - 10-16-2012, 01:37 PM
RE: Gearbox Controller 722.6 ver 2 - by DirtDiesel - 10-21-2012, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by aaa - 10-21-2012, 02:15 PM
RE: Gearbox Controller 722.6 ver 2 - by hean500e - 01-17-2013, 11:10 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-19-2013, 02:37 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-19-2013, 03:13 PM
RE: Gearbox Controller 722.6 ver 2 - by johan84 - 01-24-2013, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-26-2013, 03:46 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 01-29-2013, 02:10 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-30-2013, 11:38 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 12:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-01-2013, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 02-02-2013, 03:35 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-02-2013, 12:33 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-01-2013, 09:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-02-2013, 01:17 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-03-2013, 07:11 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-03-2013, 08:31 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 09:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 02:44 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 03:41 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-11-2013, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-11-2013, 04:04 PM
RE: Gearbox Controller 722.6 ver 2 - by raysorenson - 02-14-2013, 01:28 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-14-2013, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 02-14-2013, 09:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-15-2013, 01:41 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-17-2013, 02:11 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2013, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-18-2013, 05:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-21-2013, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-22-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-23-2013, 04:40 AM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 02-23-2013, 09:25 AM
RE: Gearbox Controller 722.6 ver 2 - by kmaser - 03-13-2013, 10:44 AM
RE: Gearbox Controller 722.6 ver 2 - by SurfRodder - 03-13-2013, 08:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 04:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-18-2013, 07:47 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-18-2013, 11:57 PM
RE: Gearbox Controller 722.6 ver 2 - by SuperCow - 03-21-2013, 08:55 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-21-2013, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-22-2013, 02:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-22-2013, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TheDon - 03-23-2013, 01:34 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 03-26-2013, 02:41 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-26-2013, 11:28 AM
RE: Gearbox Controller 722.6 ver 2 - by Mark_M - 03-27-2013, 06:52 PM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-10-2013, 09:42 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-12-2013, 06:22 AM
RE: Gearbox Controller 722.6 ver 2 - by syche - 05-12-2013, 09:51 PM
RE: Gearbox Controller 722.6 ver 2 - by oleg213 - 07-20-2013, 01:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-21-2013, 12:44 PM
RE: Gearbox Controller 722.6 ver 2 - by _siim_ - 11-17-2013, 10:13 AM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 02-12-2014, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-12-2014, 04:48 AM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 08-08-2014, 02:58 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 08-08-2014, 08:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-09-2014, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 08:02 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 08:14 AM
RE: Gearbox Controller 722.6 ver 2 - by peter - 12-07-2014, 07:46 AM
RE: Gearbox Controller 722.6 ver 2 - by barrote - 12-16-2014, 04:34 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-16-2014, 06:11 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 12-19-2014, 09:31 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 12:32 PM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 12-19-2014, 06:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-19-2014, 06:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-21-2015, 10:42 PM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-22-2015, 02:57 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-22-2015, 04:01 AM
RE: Gearbox Controller 722.6 ver 2 - by MrHope - 01-24-2015, 01:44 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 04:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-25-2015, 06:30 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-25-2015, 04:43 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-25-2015, 05:08 PM
RE: Gearbox Controller 722.6 ver 2 - by THE DIGGER - 01-26-2015, 01:48 PM
RE: Gearbox Controller 722.6 ver 2 - by F.R.A.S - 01-26-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-26-2015, 09:23 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-27-2015, 03:45 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-27-2015, 11:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-28-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 01:00 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-31-2015, 04:17 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 01-31-2015, 01:57 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 01-31-2015, 07:41 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 02-08-2015, 04:38 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-09-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by MAMG - 03-03-2015, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-03-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-06-2015, 10:10 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-06-2015, 11:36 AM
RE: Gearbox Controller 722.6 ver 2 - by tgg416 - 03-20-2015, 04:05 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:24 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-25-2015, 06:42 PM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-25-2015, 06:57 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-26-2015, 08:42 AM
RE: Gearbox Controller 722.6 ver 2 - by DanielK - 03-26-2015, 10:42 AM
RE: Gearbox Controller 722.6 ver 2 - by swecias - 05-25-2015, 05:23 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-25-2015, 05:46 AM
RE: Gearbox Controller 722.6 ver 2 - by DiseaselWeasel - 05-28-2015, 12:26 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-28-2015, 04:09 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-29-2015, 03:30 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-29-2015, 09:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 06-30-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by Henning Bruun - 07-01-2015, 01:08 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 07-05-2015, 07:34 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 06:38 AM
RE: Gearbox Controller 722.6 ver 2 - by Druk - 07-17-2015, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by seconika - 07-17-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-14-2015, 04:27 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-14-2015, 07:40 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-15-2015, 07:27 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 08-16-2015, 08:52 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-16-2015, 11:31 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-17-2015, 06:07 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 02:59 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-22-2015, 07:28 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 10:04 AM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 08-23-2015, 06:21 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 08-16-2015, 12:17 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-17-2015, 06:44 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:07 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-18-2015, 03:16 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-18-2015, 03:25 PM
RE: Gearbox Controller 722.6 ver 2 - by m1tch - 08-20-2015, 02:10 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-21-2015, 01:06 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-22-2015, 09:55 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-24-2015, 01:58 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-24-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 01:51 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-25-2015, 10:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 08-25-2015, 03:17 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 08-28-2015, 05:36 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:44 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-12-2015, 11:12 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-12-2015, 01:39 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-04-2015, 03:09 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 09-04-2015, 05:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2015, 02:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-05-2015, 01:35 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 09-05-2015, 02:57 PM
RE: Gearbox Controller 722.6 ver 2 - by INC - 09-06-2015, 03:30 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-06-2015, 10:34 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-09-2015, 05:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-10-2015, 01:46 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-10-2015, 06:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 09-11-2015, 01:18 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 09-11-2015, 12:18 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-11-2015, 03:52 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-10-2015, 01:47 PM
RE: Gearbox Controller 722.6 ver 2 - by street_666 - 10-06-2015, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:08 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 06:46 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-09-2015, 02:13 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 10-09-2015, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 10-11-2015, 07:56 AM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 10-13-2015, 02:05 PM
RE: Gearbox Controller 722.6 ver 2 - by wanger - 10-16-2015, 02:51 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:49 AM
RE: Gearbox Controller 722.6 ver 2 - by Eric78 - 10-16-2015, 10:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-17-2015, 04:55 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-26-2015, 03:19 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-26-2015, 12:48 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-28-2015, 03:05 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 02:09 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 02:50 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 10-29-2015, 03:20 PM
RE: Gearbox Controller 722.6 ver 2 - by erx - 10-29-2015, 04:28 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 03:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-03-2016, 03:31 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:36 PM
RE: Gearbox Controller 722.6 ver 2 - by mat_91 - 01-03-2016, 04:50 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 01-03-2016, 05:52 PM
RE: Gearbox Controller 722.6 ver 2 - by Petar - 01-03-2016, 05:02 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-04-2016, 11:48 AM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-05-2016, 08:15 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-06-2016, 07:25 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-07-2016, 04:12 PM
RE: Gearbox Controller 722.6 ver 2 - by swampmonkey - 01-08-2016, 02:34 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 01-08-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 01-06-2016, 11:58 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-09-2016, 05:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 01:40 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 02:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-10-2016, 02:25 PM
RE: Gearbox Controller 722.6 ver 2 - by whipplem104 - 03-10-2016, 07:39 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by STDGer - 03-11-2016, 12:59 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:31 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 03-11-2016, 08:15 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-12-2016, 12:23 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-12-2016, 03:03 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 03-13-2016, 06:20 AM
RE: Gearbox Controller 722.6 ver 2 - by erx - 03-12-2016, 03:51 PM
RE: Gearbox Controller 722.6 ver 2 - by Tito - 03-13-2016, 08:58 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 05-18-2016, 03:55 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2016, 10:40 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-02-2016, 03:26 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 06-03-2016, 03:24 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-03-2016, 03:36 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-22-2016, 03:32 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-22-2016, 02:17 PM
RE: Gearbox Controller 722.6 ver 2 - by Sultzi - 05-28-2016, 03:26 AM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-06-2016, 04:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 01:04 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-07-2016, 02:56 PM
RE: Gearbox Controller 722.6 ver 2 - by -Mackan- - 06-08-2016, 05:14 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-11-2016, 04:27 PM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 06-06-2016, 07:06 PM
RE: Gearbox Controller 722.6 ver 2 - by elvis100 - 06-25-2016, 05:54 AM
RE: Gearbox Controller 722.6 ver 2 - by TurboTim - 08-14-2016, 02:18 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 05:49 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 09-05-2016, 12:15 PM
RE: Gearbox Controller 722.6 ver 2 - by mower16 - 09-05-2016, 08:40 PM
RE: Gearbox Controller 722.6 ver 2 - by ho55 - 09-15-2016, 04:08 AM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-18-2017, 08:37 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-18-2017, 12:07 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 02-21-2017, 02:19 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 02-22-2017, 01:16 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:01 AM
RE: Gearbox Controller 722.6 ver 2 - by hents99 - 05-18-2017, 05:32 AM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-18-2017, 05:33 AM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 05-19-2017, 04:14 PM
RE: Gearbox Controller 722.6 ver 2 - by Fishman - 05-20-2017, 02:19 AM
RE: Gearbox Controller 722.6 ver 2 - by 606110 - 06-25-2017, 04:00 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 06-30-2017, 03:37 PM
RE: Gearbox Controller 722.6 ver 2 - by ross - 07-04-2017, 04:20 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-01-2017, 02:49 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 08-03-2017, 03:49 PM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 11-30-2017, 02:31 PM
RE: Gearbox Controller 722.6 ver 2 - by olefejer - 12-06-2017, 12:53 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-05-2017, 08:12 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-05-2017, 07:19 PM
RE: Gearbox Controller 722.6 ver 2 - by Evgeniy1987 - 12-06-2017, 02:56 AM
RE: Gearbox Controller 722.6 ver 2 - by s1984 - 12-06-2017, 01:15 PM
RE: Gearbox Controller 722.6 ver 2 - by jupel - 09-06-2018, 03:08 AM
RE: Gearbox Controller 722.6 ver 2 - by 3zooz - 06-20-2020, 02:20 PM
 9 Guest(s)
 9 Guest(s)
