Gearbox Controller 722.6 ver 2
(02-18-2017, 12:07 PM)olefejer(02-18-2017, 08:37 AM)jupel Hi Ole! Is it possible, to take signal from abs on old revision controller? I try to make it, but it work unstable, and as i see the signal from abs sensor must be divided by 3? Can you help to solve it?
Hi
Yes no-matter how old the controller is you can connect it to ABS, sensor
But correct the newest ones has a real automotive ABS sensor chip that is used for both external Speed and RPM, that is more immune to noise then the older type.
If the speed show 3 times to much, you goto
"Setup Parameters" -> "External speed %" standart is 100 set it to 33
Then test and see if it fits,
Hi
