STD Other Projects My 1985 300D
My 1985 300D
My 1985 300D
Gasoline Fumes
Diesel Fumes?
54
05-21-2009, 04:20 AM #1
I guess I should introduce my car. My neighbor bought a 1984 300D and got a 1985 "parts" car with some deer damage and a slipping tranny. In exchange for helping him get the '84 roadworthy, he gave me the '85. Broken odometer says 186,089 miles.
[Image: 300dfront.jpg]
[Image: 300dlside.jpg]
[Image: 300drside.jpg]
[Image: 300drear.jpg]
[Image: 300dint.jpg]
[Image: 300deng.jpg]
It sat in an orchard for a couple of years because of the slipping tranny. I got it running and then let it sit for a couple more years. My neighbor "borrowed" a few parts from it and the turbo became partially seized. Just recently I got it running again and the turbo freed itself up once it warmed up and had fresh oil running through it. Right now the idle is pretty rough and it doesn't start as quickly as my neighbor's car.
I like small, lightweight Japanese cars that handle good. So why do I have a large German sedan that handles like a boat? I don't know, but I kinda like the damn thing. Being able to run it on WVO certainly adds to its appeal.
I want to simplify/lighten the car, put a manual transmission in place of the auto, dramatically improve handling and get more power out of it.
For looks, I want to:
replace the US headlights with the E-Codes (I have them already)
lower it a little (especially in the front)
possibly remove the side molding
black-out most of the chrome
add a front air dam (90s Dakota is a pretty close fit, just needs to be shortened)
And those awful front seats have to go. I might replace them with a pair of 80s Acura Integra seats I have. I just wish I had matching rear seats.
There is some old crash damage to the left rear quarter panel. It was badly patched with Bondo. The filler had become a water trap, so I pried most of it off. I'm not sure whether I want to try replacing the whole panel, my body working skills aren't great. And I'm still learning how to weld.
More recent pics:
Cleans up nicely
[Image: washed.jpg]
Not its good side
[Image: IMG_7362x.jpg]
Dakota airdam
[Image: Dakota-airdam.jpg]
Gasoline Fumes
More recent pics:
Cleans up nicely
[Image: washed.jpg]
Not its good side
Dakota airdam
MB TECH
05-21-2009, 07:22 AM #2
Its always good to see someone bring one back from the field instead of letting it rot. Keep us posted with updated pics.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
Gasoline Fumes
Diesel Fumes?
54
06-11-2009, 12:45 PM #3
I did a compression test. They ranged from 300-350 PSI. Should they vary that much?
It sounds like it has a miss at idle, could that be an injector?
There isn't much more progress, but I found a complete and unused tool kit at the junkyard in a W126. Big Grin
Gasoline Fumes
06-11-2009, 01:50 PM #4
(06-11-2009, 12:45 PM)Gasoline Fumes I did a compression test. They ranged from 300-350 PSI. Should they vary that much?
It shouldn't vary that much but what are you going to do about it? Did a valve job first right? Did you double check your adjustment numbers (as well as compression numbers).
Crack the injector lines to find the culprit.
06-11-2009, 10:28 PM #5
I love this 90s dakota air dam idea. Can you take a larger picture? I immediately want to do the same thing.
I don't see any cracks in the dash, pretty amazing. How does the left rear door open? is it squeezed by the accident damage?
Gasoline Fumes
Diesel Fumes?
54
06-12-2009, 12:46 AM #6
(06-11-2009, 01:50 PM)winmutt
I haven't done a valve adjustment yet, that's next on my list.
I tried cracking the lines, but it was spitting diesel at me. I'll have to do it again with a rag over them.
(06-11-2009, 10:28 PM)dropnosky I love this 90s dakota air dam idea. Can you take a larger picture? I immediately want to do the same thing.
Attached should be two more pics of the air dam. I'm going to cut it in the middle and take out a piece so it will be the right length. The Blazer/Jimmy air dams are close too.
The dash has about 3 small cracks in it. Hopefully I don't add any, I have the dash out to access the mouse nests that the car has acquired.
The door works fine, but the gap is tighter than the others and it doesn't sound quite the same as the other doors when you close it. The trunk floor is buckled a little on that side, I don't know if the suspension was affected or not.
CARFAX 05/31/1997
Florida
Police Report
Case #545066340
Accident reported Involving left side impact with another motor vehicle
This post was last modified: 06-12-2009, 01:30 AM by Gasoline Fumes.
Gasoline Fumes
CARFAX 05/31/1997
Florida
Police Report
Case #545066340
10-04-2010, 08:46 PM #7
Oh shit! That airdam look bitchin!!
How much length needs to be taken off to make it fit?
This is somthing im going to start looking for right away at the junk yard!
Beautiful!!
Especially on a slammed CD...oooohhhhhhhhhhh
This post was last modified: 10-04-2010, 08:51 PM by garage.
Beautiful!!
10-04-2010, 10:24 PM #8
(10-04-2010, 08:46 PM)garage Oh shit! That airdam look bitchin!!
Beautiful!!
Its amazing how perfect it works on the 123. makes me wonder if 90% of all the small/midsize pickup air dams would work.
Beautiful!!
10-04-2010, 11:52 PM #9
At Ecology junkyards they will let you take parts out to your car if you leave them your lisence and they mark the piece.
I cant wait to start cruising through the domestic isles more looking for airdamsBig Grin
This is cool
This is cool
Gasoline Fumes
Diesel Fumes?
54
10-05-2010, 12:09 AM #10
I hate to admit it, but I sold the 300D a while back.
You can sort of see how much needs to be removed by the overhang on the other side. I think it was around 2". I wasn't too concerned about making the seam look good since the license plate would mostly hide it. I was looking at the Blazer airdams too, I think they're about the same size. Bigger trucks will just need their airdams shortened a bit more. They're not hard to find, but I still have the Dakota airdam if anybody wants it.
Gasoline Fumes
10-05-2010, 10:25 AM #11
Well its probably a good time to go buy another oneTongue
Its made out of a like plastic/abs type of material correct?
So if i cut out 2inches of the center, how would be the best way to go about getting it molded back together? Fiberglass?
any ideas?
any ideas?
Gasoline Fumes
Diesel Fumes?
54
10-05-2010, 01:33 PM #12
I never gave it much thought, I was just happy to find an air dam. I was thinking I'd end up sandwiching something on both sides of it and bolting/screwing the whole thing together. Nobody would notice as long as it's all painted black. Maybe the section that was cut out can even be used as the front layer of the "sandwich."
I'll get another Merc when I find a cheap, rust-free 300D-T with a 5-spd and LSD. Tongue
Gasoline Fumes
10-05-2010, 03:48 PM #13
(10-05-2010, 01:33 PM)Gasoline Fumes I never gave it much thought, I was just happy to find an air dam. I was thinking I'd end up sandwiching something on both sides of it and bolting/screwing the whole thing together. Nobody would notice as long as it's all painted black. Maybe the section that was cut out can even be used as the front layer of the "sandwich."
Hmm well im gonna have to work with it to make that fit, because i LOVE the way it looks.
How about a 300CD, with a 5 speed, manual windows and sunroof, and LSD...that sounds sweeeeet.
A 240CDT i like the sound of that!
This post was last modified: 10-05-2010, 03:49 PM by garage.
Gasoline Fumes
Diesel Fumes?
54
10-05-2010, 06:33 PM #14
(10-05-2010, 03:48 PM)garage How about a 300CD, with a 5 speed, manual windows and sunroof, and LSD...that sounds sweeeeet.
Sounds good! Can I have 15" Bundts and Euro bumpers on it too? Big Grin
Gasoline Fumes
10-06-2010, 11:57 AM #15
(10-05-2010, 06:33 PM)Gasoline Fumes
OF COURSE!
as long as i can have my factory turbocharged om616 with 7mm elements..
OF COURSE!
10-09-2010, 12:58 AM #16
and 1,000,000 hp and torque....
10-10-2010, 09:24 AM #17
(10-09-2010, 12:58 AM)Captain America and 1,000,000 hp and torque....
GEEZ Captain! First of all with my superduper 4speed tranny and ice cold air intake..i have atleast 1,000,000 ft lbs of torque, and my horsepower CANT be far behind
300D50
Graphite Moderator, ala RBMK
10-11-2010, 04:20 AM #18
wowza, you guys are weaklings! my 616 that drinks it's own oil puts out 1.21GW (1,622,636.73 hp)! [Image: icon_mrgreen.gif]
This post was last modified: 10-11-2010, 09:31 PM by 300D50.
300D50
10-15-2010, 11:08 PM #19
I think my car is making negative horsepower at the moment... Sad
10-17-2010, 01:34 PM #20
What happened now?
What happened now?
