STD Tuning Engine 7mm elements, what's your take?
toyfreak
08-31-2012, 06:02 PM #1
I have just been informed about this website that sells 7mm elements for 40 euro each. Think they are any good or just the cheap chinese elements?
http://www.dieselkontor.de/product_info....ts_id=3271
toyfreak
dieselmeken
09-01-2012, 02:57 AM #2
(08-31-2012, 06:02 PM)toyfreak I have just been informed about this website that sells 7mm elements for 40 euro each. Think they are any good or just the cheap chinese elements?
They work,but its the old Ford Transit element with flat head, no retard notch at low idle, max 120cc of fuel.
dieselmeken
Mark_M
09-01-2012, 03:46 AM #3
I had seen these a while ago as well and wondered if they would do a job. They are cheap that's for sure. Thanks for letting us know what they are dieselmeken.
Mark_M
awk
09-01-2012, 05:24 AM #4
they fit only m pumps? or mw also?
awk
Deni
09-01-2012, 07:11 AM #5
Interesting. Which Ford Transit used them? Would they be any better than 6mm elements? What is their disadvantage over the stock elements? Like rough idle etc?
Thanks
Deni
Deni
Thanks
Deni
Volker407
naturally aspirated
157
09-01-2012, 08:29 AM #6
I can recommend Tomniks elements (Tomnik is a member here). They are a little more expensive than others, but the quality is the best I have seen so far AND they are designed for the stuff we do here.
That helps to avoid issues like rough idle, having to do troubleshooting and so on.
Like dieselmeken said, the original Bosch elements e.g. miss a retard notch for the stuff we do.
Gruß
Volker
Volker407
Gruß
Volker
dieselmeken
09-01-2012, 09:52 AM #7
(09-01-2012, 07:11 AM)Deni Interesting. Which Ford Transit used them? Would they be any better than 6mm elements? What is their disadvantage over the stock elements? Like rough idle etc?
Thanks
Deni
Not for MW, only M-serie. Ford Transit, the old York 2,4 diesel between 74-78 i think it was.
These old element is not to be recommended if you shall have your car for daily drive, for race / drifting they are OK but you can get hard nailing on low idle
dieselmeken
Thanks
Deni
