STD Tuning Engine turbochargers hx35 vs gtx3071r
mao76
09-12-2012, 02:41 PM #1
hi boys according to you it has less lag a turbocharger hx35 or a gtx3071r on double pads on a bmw330d
This post was last modified: 09-12-2012, 04:20 PM by mao76.
mao76
mao76
09-13-2012, 10:03 AM #2
help my
This post was last modified: 09-13-2012, 10:03 AM by mao76.
mao76
help my
mantahead
09-13-2012, 10:40 AM #3
(09-13-2012, 10:03 AM)mao76 help my
you need to compare different exhaust housings as they will make a difference on spool up.
mantahead
mao76
09-13-2012, 11:16 AM #4
with ar48 recovery a lot of lag, the turbocharget gtx3071r, making some calculations should give 400cv to 4000 turns with a pressure of 38psi, but with ar63,
mao76
lpumb3
617 300sd
141
09-17-2012, 09:29 AM #5
i found a place on line that has holsets and garretts , for short money . the holsets are for the 4bt cummins , and the garretts are for NPR cab overs 3.9 4cyl .Part Number: 466409-9002 looks pretty Smile btu theres different arrangments for exhaust etc on there . i think a saw sprinter turbos , for 612 motor ? the diesel store .com
This post was last modified: 09-17-2012, 09:30 AM by lpumb3.
lpumb3
