STD Tuning Engine drilling air fittings..?? 300sd
cho
09-21-2012, 07:22 AM #1
hi guys
I have read from some old std posts that some guys
do the drilling of air fittings...to equalize a bit of garret boost?
I assume that you (I) have to drill banjo bolt back on manifold and one on alda a 1mm or so, wider and put a bit wider hose..say 4 or 5mm?
correct?
why I wanna do it....I have a loooong turbo lag and sudden heavy boost
thanks
cheers
ChO
cho
hi guys
correct?
thanks
cheers
ChO
09-21-2012, 08:08 AM #2
I don't think it would alleviate the lag. It would alleviate the suddenness though.
Have you looked into the higher stall torque converter? Might help with lag.
cho
09-21-2012, 08:22 AM #3
(09-21-2012, 08:08 AM)aaa Have you looked into the higher stall torque converter? Might help with lag.
thanks, please do elaborate me your last sentence
not a english native, so I have problems with eng.tech terms... Sad
edit: you suggest installing new torque conv. if I understand you correctly..?
This post was last modified: 09-21-2012, 08:31 AM by cho.
cho
09-21-2012, 08:52 AM #4
The 1985 torque converter had a higher stall speed, allowing the engine to reach higher rpm faster, which will lessen the lag.
cho
09-21-2012, 09:09 AM #5
ok,got it Smile thanks mate
cho
09-21-2012, 09:30 AM #6
Check your ALDA lines as well-they may be dirty and partially clogged,
or
Adjust / remove the ALDA so that the fueling curve is a bit smoother
or
cho
09-21-2012, 11:39 AM #7
already did Smile, banjo's & lines are fine and clean...
I'm thinking of ALDA removal but some guys reported significant
fuel consumption issues... well,... no win win here I guess ...
tx
cho
tx
09-21-2012, 11:53 AM #8
Significant fuel usage if you always mash the pedal Big Grin
A small, GENTLE adjustment may help you
09-21-2012, 12:17 PM #9
Try adjusting the ALDA It only affects off boost fueling
This post was last modified: 09-21-2012, 12:18 PM by willbhere4u.
cho
09-24-2012, 02:30 AM #10
thanks guys,..
ALDA has been already adjusted also..."until smoke appears"
a year back.... basically I don't have a weak power problem,......
sudden (power) boost is issue I would like to resolve Smile
some KKK turbo might help Smile
cho
thanks guys,..
cho
10-11-2012, 08:17 AM #11
I just found this one considering lag:
A downpipe with a smaller inner diameter offers less airflow, slightly reducing top-end horsepower. However, the smaller pipe diameter increases the speed of exhaust flow, thus allowing your turbocharger to spool faster, increasing response and low-end power.
is this true?
how to do calculation how much HP I will lose with 2 inch pipe instead
2.5 inch which I have now?
beers
ChO
cho
is this true?
beers
ChO
10-11-2012, 10:09 AM #12
I would keep the 2.5" downpipe. Do you have a boost gauge installed?
cho
10-11-2012, 12:53 PM #13
(10-11-2012, 10:09 AM)Simpler=Better I would keep the 2.5" downpipe. Do you have a boost gauge installed?
have one 5 bar 1st class rated, not installed yet....will tee soon
if above theory is correct I might consider 2 inch with muffler only
I dont use top speed anyway... so 5 or even 10 mph lost is ok..
edit: kind a funny post on superturbo diesel forum Smile))
This post was last modified: 10-11-2012, 12:54 PM by cho.
cho
10-11-2012, 09:24 PM #14
Turn your ALDA out a bit.
