STD Tuning Engine Engine emergency shut off not working.
dieselsmoke300d
To many things I say: Bah Humbug!
65
10-05-2012, 03:00 AM #1
Ok so I just noticed this yesterday and figured it's important enough to ask about. My engine shuts off fine with the key. So the vacuum shut off works fine. But yesterday when I went to shut it off with the lever while working on something, it just sputtered like crazy but refused to shut off. Now I figure this would be bad if it didn't stop via key at some point. I didn't find any info elsewhere since this isn't ever supposed to fail, hence the fact that it's a "failsafe". So what am I looking at here?
This post was last modified: 10-05-2012, 03:01 AM by dieselsmoke300d.
Matt.
'85 300SD Turbo
'92 Subaru SVX
'83 Pontiac Firebird S/E
'88 Pontiac Firebird
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
ronnie
10-05-2012, 06:19 AM #2
see if there is a bind in the linkage, or to much slop that maybe is not allowing it to reach full shut off.
ronnie
10-05-2012, 08:37 AM #3
I've had it where a piece of that little fuel return line was getting in the way of all that linkage there.
Volker407
naturally aspirated
157
10-05-2012, 10:39 AM #4
In my case the external linkage dampener was turned in too much. A long 13mm or 14mm nut and a big srewdriver fixed it.
Gruß
Volker
Volker407
Gruß
Volker
10-05-2012, 11:28 AM #5
(10-05-2012, 10:39 AM)Volker407 In my case the external linkage dampener was turned in too much. A long 13mm or 14mm nut and a big srewdriver fixed it.
Gruß
Volker
Word, I've seen that too.
Gruß
Volker
ronnie
10-05-2012, 05:19 PM #6
that went though my mind too after I posted
ronnie
