STD Maintenance General Boost pressure 8.5 PSI, how do I increase?
tazulica
10-25-2012, 09:11 PM #1
My engine is pulled from a '79 300SD. Today I installed a new boost gauge and the maximum pressure read is 8.5 PSI. I removed the ALDA seal and turned the screw 1 1/2 CCW until it stopped (it wouldn't turn more than that).
I drove the car again and the boost is the same. Is there any other way to increase it another 3-4 PSI?
Thanks!
tazulica
Thanks!
aaa
10-25-2012, 11:15 PM #2
Pinch the wastegate hose shut as a test for whether the wastegate needs adjusting.
aaa
10-26-2012, 01:43 AM #3
You could try using a manual boost controller like this
http://www.ebay.com/itm/NXS-MANUAL-BOOST...ae&vxp=mtr
